Greyborg RC + RockShox Boxxer Race
Re: Greyborg RC + RockShox Boxxer Race
Postby gensem » Tue Nov 29, 2011 6:10 pm
I think someone asked about the phase wires gauge earlier.
Red one is a tipical 10awg silicone wire from Wojtek the other ones are the big motor phase wires.
A decent 25mph bike will cost around $1000.
A decent 35mph bike will cost around $2000.
A $1000 35mph bike will get you killed.
Justin we really appreciate what you did!
gensem
Postby Accountant » Wed Nov 30, 2011 3:34 am
General appologies about confusion.
I will try to do some damage control.
Since the data from chinese supplier is not the most reliable information on the earth, i was reluctant to public technical infos.
Official testing was not done jet.
All I can tell is that all 30 motors from first batch are identical.
Kv is about ...something.
120 kg driver with 48 V battery pack of the flat road can reach max speed 51 kmh,in less than 3 seconds (measured by GPS).
Italian friends informed us about max speed higher that 140 km. i was not there, but I trust them.
Best thing we can do at this moment is to publish some videos with different setups, so any one of you that can help that way, please go ahead.
Motor is very solid, and do not get warm very easily, so high speeds are possible.
Our idea was to use it with Greyborg frames. Greyborg bicycles should be something like Harley motorycles.
I want them so reliable that you will use them for 20-30 years with no failures, and they also must have clean design without too many cables.
That is why we prefer to build Greyborgs with 2 speeds only.
We had no intention to compare our motor with X 5400 products.
X54 have 15 kg, and our motor have 10kg. Those are different categories.
We are building bicycles, not racing motorcycles.
Our supplier can manufacture megamonster motors with 20 or 25 kg, but those motors are intendend to be used in car wheels.
Accountant
Postby patrickza » Wed Nov 30, 2011 8:36 am
Need some help picking a rear shock. My local bike shop is trying to rip me off insanely.
Can someone tell me what all I need to buy for the rear shock, and point me to an online store that I can order from. I imagine it's the shock, plus spring, plus bushings. What size bushings does the bike require?
Greyb.org, Cromotor, Headway 83.2v 20AH, Lyen 18 fet: viewtopic.php?f=3&t=45514
Kona Kahuna, x5305, Headway 76.8v 10AH, Crystalyte 72v48A: viewtopic.php?f=3&t=10256
Bladez Scoot, 450W motor putting out 3kW, Headway 38.4v 10AH, Lyen special controller: viewtopic.php?f=35&t=25872
patrickza
Postby gensem » Wed Nov 30, 2011 8:40 am
patrickza wrote:Need some help picking a rear shock. My local bike shop is trying to rip me off insanely.
Im at work atm patrick, but I can check the shock I have when I reach home.
gensem
Postby HAL9000v2.0 » Wed Nov 30, 2011 8:48 am
Bushings are 8mmx30mm and shock from 170-185mm ETE.
Good shocks for reasonable price :Yasusu BNCP401
HAL9000v2.0
Postby gensem » Wed Nov 30, 2011 8:52 am
HAL9000v2.0 wrote:Bushings are 8mmx30mm and shock from 170-185mm ETE.
Are you talking about this Hal?
http://www.yasusu.com/pro_bic02.htm
43 USD, worth trying I guess.
gensem
Postby patrickza » Wed Nov 30, 2011 10:18 am
Thanks HAL and gensem. I'm looking at the bushings now and there are two types with the same measurements. Could you tell me which of these would work:
http://www.chainreactioncycles.com/Mode ... elID=62819
or
http://www.chainreactioncycles.com/Mode ... elID=57750
and also what type of bolt I should buy to connect all the parts.
Apologies for the basic questions, but bike shops around here are useless and only really become interested if you talk about $1000s in business.
patrickza
Postby gensem » Wed Nov 30, 2011 11:16 am
I feel your pain, bike shops are utterly useless for me too...
im not sure about the bushings, Hal/Accountant should know the diference.
gensem
Postby HAL9000v2.0 » Wed Nov 30, 2011 1:48 pm
You need this item
65966 In Stock 30.0mm x 8.0mm
but this is outer dia for manitou shock ONLY! You have to get bushings from shock producer. Each shock have different bushing system.
HAL9000v2.0
Postby HAL9000v2.0 » Wed Nov 30, 2011 1:52 pm
212199 In Stock 8.0mm x 30.0mm - 14mm
In this item 14mm is eye inner diameter. And you can measure on your shock. But what is missing here the width of the eye. That is also important. I will make few sketches to clear this.
HAL9000v2.0
Postby gensem » Fri Dec 09, 2011 2:18 pm
My borg arrived, its still on plastic...its a work of art... im really horny :twisted: :twisted: :twisted:
gensem
Postby MadRhino » Fri Dec 09, 2011 3:28 pm
Received my 'Big Black' motor today. :D
Got #3, obviously from a lately cancelled, early order. :twisted:
Had no axle nuts, someone post the size and thread please.
It took only 10 days from Zagreb to Montreal, Canada.
Had no tax or custom fees, thanks Accountant. :wink:
Norco A-Line, 50+ Mph dirt bike and winter commuter... sold
Specialized Demo 8 performance dirt bike
http://img715.imageshack.us/img715/5824/dsc03417ae.jpg
Santa Cruz Heckler, lightweight road racer
Santacruz V-10, performance dirt bike
Work in progress:
Trek Session 10
Fatboy
MadRhino
Postby oatnet » Fri Dec 09, 2011 4:21 pm
gensem wrote:My borg arrived, its still on plastic...its a work of art... im really horny :twisted: :twisted: :twisted:
That's why they leave the plastic on - to keep you from inadverdantly 'staining' it when you open the box. :lol:
-JD
Member 117 of 16,xxx
179v VW Camper © 164v Vectrix E-Moto © 72v Norco A-line/x5403 © 60v Specialized Enduro Comp/BMC © 72v x5tracycle © 48v TF IO/BMC © 36v Kepler Friction Drive © Spot-Welding a123 © Pelican Front Packs © Vectrix Battery Replacement © MORE !!
Image大鸡巴 Motors
Knowledge is acquired through experience, everything else is just information - Albert Einstein
"Cheater?" I'm not competing, I'm Commuting!
oatnet
Postby gensem » Fri Dec 09, 2011 5:08 pm
Its almost sexual... i do feel like humping on the frame... haha
A master piece, its a moto frame build to fit a bicycle envelope and the construction is amazing... trully a masterpiece.
gensem
Postby Andje » Fri Dec 09, 2011 7:35 pm
is there any bamboo inside it?
:P
Norco 125 Dirt Jumper
100v 15ah Lipo Backpack
lyens 18 fet, 100v 100 amps, R12 Regen
x5304- 95km/h
http://endless-sphere.com/forums/viewtopic.php?f=3&t=24594
Norco A-Line Park 2009
144v Kelly 300amp
5403/ future HS60
http://endless-sphere.com/forums/viewtopic.php?f=6&t=35652
Andje
Postby gensem » Fri Dec 09, 2011 7:44 pm
Andje wrote:is there any bamboo inside it?
:P
Nope, no bamboo, and no butterfly... but im still horny.
24 fet controller + greybmotor ll be a pleasure
gensem
Postby markobetti » Sat Dec 10, 2011 2:56 am
gensem wrote:Its almost sexual... i do feel like humping on the frame... haha
:) i know your frame will like humping those wheels you made....
markobetti
Postby patrickza » Sat Dec 10, 2011 7:39 am
Another quick question for HAL. The rear brake adapter doesn't fit over the cromotor shaft. Is it safe to just drill it out to a larger size or will I weaken the part too much?
patrickza
Postby hillzofvalp » Mon Dec 12, 2011 6:48 pm
How much will the greyborg hub be available for?
hillzofvalp
Postby gensem » Mon Dec 12, 2011 8:26 pm
Its still available, 3 or 4 buyer gave up... around 400 euros if nothing changed.
gensem
Postby hillzofvalp » Mon Dec 12, 2011 10:21 pm
put me on the maybe list.. I don't know how much total cost in USD will be to the Chicago, IL area (46385)
do these guys break a sweat at 5-8kW continuous?
hillzofvalp
Postby Alan B » Tue Dec 13, 2011 1:38 am
Depends on how much of that is heat. If you read the threads on this motor it is about a double wide 9C.
Alan B
1.21 GW
1.21 GW
Postby gensem » Tue Dec 13, 2011 3:28 am
hillzofvalp wrote:put me on the maybe list.. I don't know how much total cost in USD will be to the Chicago, IL area (46385)
PM Accountant to place an order.
Dont know how much power they can take, coz Im waiting for a 24fet controller.
gensem
Postby Accountant » Thu Dec 15, 2011 9:26 am
PAYPAL is finaly accepted by Zelena vozila d.o.o.
Web shop will be on soon
Accountant
Postby nicobie » Thu Dec 15, 2011 3:19 pm
That's good news!
May your tote always stay tight and your edge eversharp :wink:
my eTownie build thread: viewtopic.php?f=6&t=23701
nicobie
PreviousNext
Return to Items for Sale - New
Who is online
Users browsing this forum: No registered users and 5 guests
