Fechter's Mini Meanwell Limiter Board
Re: Fechter's Mini Meanwell Limiter Board
Postby etard » Fri Oct 14, 2011 7:08 am
We need to start another thread when we get into these, pretty sure it's off topic in this Fechter limiter thread. :lol:
To get back On Topic, I ordered enough parts from Mouser to make 4 limiter boards, so I'm just gonna take some project boards from Radio Shack and build them up. It wil be my first of such endeavors, I hope it's mostly straightforward.
etard
Postby ZOMGVTEK » Fri Oct 14, 2011 6:57 pm
I got mine today, and its HUUUGGE! A serious looking supply for sure.
I started a thread where we can throw all info on these supplies.
viewtopic.php?f=7&t=32829
ZOMGVTEK
Postby hillzofvalp » Sat Nov 26, 2011 8:50 pm
fechter,
Will this circuit for the 24-35V range work okay with the 600W 24V series (SE-600-24) meanwells? Do you have any boards left?
Thanks!
hillzofvalp
Postby fechter » Sun Nov 27, 2011 11:18 am
I haven't seen one of those supplies, but I assume it is similar to the smaller ones.
At that current level, I think the shunt would need to be doubled up, but otherwise should work OK.
I don't have any of the newer boards left, but I have a few of the older ones that require a little modding with jumper wires. They only have one spot for the shunt though, so would take some modding for two shunts.
It wouldn't be that hard to make one on a perf board.
I'll dig around in the files and post the latest configuration when I get a chance.
fechter
Postby hillzofvalp » Sun Nov 27, 2011 11:54 am
Thank you.. I figured the perf board wouldn't be that hard either. It would need to be two beefier shunts in parallel, that each have double the resistance of the one in the BOM, correct?
hillzofvalp
Postby fechter » Mon Nov 28, 2011 3:35 pm
Here's the schematic again:
Mini Limiter Board schematic.jpg (39.7 KiB) Viewed 738 times
Here's the board layout:
Mini Limiter Board Layout.jpg (63.51 KiB) Viewed 738 times
Here's the Mouser BOM:
652-3362F-1-102LF|1
594-K104K15X7RF5TH5|2
512-1N914B|1
66-OAR5R005FLF|1
270-160K-RC|1
270-4.7K-RC|1
512-LM358AN|1
512-LM78L12ACZX|1
For 48v operation, add 24v zener:
78-1N5252B|1
For 36v operation, add 12v zener:
78-1N5242B|1
Optional socket for op-amp:
571-1-390261-2|1
fechter
Postby jana » Mon Jan 16, 2012 9:00 am
Will this work for the 48V 1200W version SCN-1K2-48?
Any left?
jana
Postby fechter » Mon Jan 16, 2012 11:48 am
Sorry, no boards left, but it's not hard to DIY on a perf board.
Not sure about that model. Most power supplies will work with this though. The trick is to find the spot to tie in the sensing line. For that power level, you will need at least two shunts in parallel to handle the current.
fechter
Postby bobale » Mon Jan 16, 2012 12:11 pm
Wait, this just limts current, it doesn't cut charing after the current drops below set point? I'm sure I've seen your schematic for the circuit which does that, but I can't find it now. Can you post it here?
RWD 2807 9Continent rolling on Kenda Flame 26x2.125
12S3P out of Turnigy 4S Hardcase 20C (600Wh)
35A 9FET Infineon Controller (Regen, Cruise control, Speed limit)
Top Speed 27mph (31mph@120%)
bobale
Postby fechter » Mon Jan 16, 2012 1:25 pm
Here it is:
(92.87 KiB) Downloaded 3 times
fechter
Postby bobale » Mon Jan 16, 2012 1:31 pm
bobale
Postby NeilP » Mon Jan 16, 2012 1:43 pm
I got a copy from Richard, hope he does not mind me posting it up
Small one, then a big version too
CC-CV-v4.2.6-NP 800 small.jpg (58.8 KiB) Viewed 602 times
Bigger version
(180.46 KiB) Downloaded 3 times
Mongoose MTB, Fox forks,26x2.3 tyres, 180mm disks. 20s 20Ah LiPo, Lyen 18 FET,5304 in 26 inch EX721. 9k miles 2years
:) Only Irish coffee provides in a glass all four essential food groups: alcohol, caffeine, sugar, and fat :)
“Rightful liberty is unobstructed action according to our will within limits drawn around us by the equal rights of others. I do not add 'within the limits of the law', because law is often but the tyrant's will, and always so when it violates the rights of the individual.”
NeilP
Postby NeilP » Mon Jan 16, 2012 1:44 pm
Ah, looks like Fechter got there before I found it...the one I posted is slightly different I think...I edited it a bit, to match the board the gary at tppacks sent me
NeilP
Postby jana » Mon Jan 16, 2012 2:00 pm
Now I am confused. i need 2 cards to do this?
I thought the Meanwells was constant voltage by default..
jana
Postby NeilP » Mon Jan 16, 2012 2:24 pm
No, just the one board,
There were two designs of board, the basic one with just one adjustment pot that just limits current. They then created a second design, which is the two schematics above.
This second one, also monitors the current flowing into the battery.
When the current drops below the limit (set by VR3) then the board causes the output voltage of the meanwell to drop. the amount it drops is set by VR1 ..the float voltage setting
NeilP
Postby jana » Mon Jan 16, 2012 2:39 pm
Ok, thanks :D
jana
Postby Degull » Wed Jan 25, 2012 9:10 am
The version 4.2.5, with the three pots, was there ever a professionally made board for this design? I have a good relationship with a circuit board manufacturer locally. If there is any interest I can have them made and distribute them here for other members. The meanwell chargers are a great cheap option for newbies like myself and I think it would be a worth while project for everyone.
Degull
Postby hillzofvalp » Wed Jan 25, 2012 9:47 am
That would be nice
hillzofvalp
Postby NeilP » Wed Jan 25, 2012 10:26 am
Yes there was versions of boards for three pot 4.2.5 4.2.6...Gary Goodrum at tppacks sold them ..They are no longer on the site, as there were supposed problems with them...but
I have got three of them and two are up and running on both my meanwell builds.
once the issue with gettting the componets in the correct way around was sorted, they worked fine.
one of the transistors...or FETS..can't remember had slightly diffferent versions..and the pinout was changed..BS107A and then BS107B or something similar.
If you read up you see Richard mentionin ghtat there were problems, but as I said, above that issue with the pinout they work fine.
And again..another BUT....
i am not using mine for current limiting...I have done that with the mod on the board..R37. The issue was supposed to be that these boards caused a buzz...but these things tend to buzz a bit anyway when current limtied .I only use these 3 pot boards as end of charge monitor and for the LED that changes from orange to green when done charging
Speak to Gaary at tppacks he may sell you them
NeilP
Postby wineboyrider » Wed Jan 25, 2012 10:44 am
I've got one from Fechter that I didn't have a chance to put together, because my Meanwell failed just before I got the boards in. :( :( :( :( :(
wineboyrider
Postby Degull » Wed Jan 25, 2012 11:14 am
wineboyrider wrote:I've got one from Fechter that I didn't have a chance to put together, because my Meanwell failed just before I got the boards in. :( :( :( :( :(
I have a 48 volt 500 watt Meanwell that would love to meet that board. I'll take it if you want to sell it!
Degull
Postby NeilP » Wed Jan 25, 2012 5:17 pm
I do have a picture of the PCB for the three pot version..but I am not going to post that up just yet I am afraid. It is not my design..and I can't go sharing something like that without the OK of Gary or Richard first..it is there design and they do have businesses to run, if Richard can OK, it then I can pass it on.
but not till I know I am not going to upset anyone
NeilP
Postby Degull » Wed Jan 25, 2012 7:53 pm
NeilP wrote:I do have a picture of the PCB for the three pot version..but I am not going to post that up just yet I am afraid. It is not my design..and I can't go sharing something like that without the OK of Gary or Richard first..it is there design and they do have businesses to run, if Richard can OK, it then I can pass it on.
Totally understandable. I'm offering to have the boards made but I don't want to step on anyone's toes.
I'm sure that I'm not the only one that would love to get a few these boards. The Meanwell power supplies are well documented here on the forum and they come at a great price. I've been reading about them for a couple of weeks now. These limiter boards basically sum up a bunch of knowledge shared here already. It is much appreciated.
Degull
Postby fechter » Wed Jan 25, 2012 8:26 pm
It's OK to post it.
fechter
Postby NeilP » Thu Jan 26, 2012 2:54 am
OK, here they are
There are three images: A front image, a rear , and then a third that is a composite, so you can see where the tracks coincide as it is a double sided board
But I would check with Gary at tppacks first, before you go spending money and making a load. He may still have some ready to sell. They are not on the site anymore, but he may still have some
NeilP
PreviousNext
Return to Items for Sale - New
Who is online
Users browsing this forum: ziltoid81 and 5 guests
