wineboyrider wrote:I've got one from Fechter that I didn't have a chance to put together, because my Meanwell failed just before I got the boards in.![]()
NeilP wrote:I do have a picture of the PCB for the three pot version..but I am not going to post that up just yet I am afraid. It is not my design..and I can't go sharing something like that without the OK of Gary or Richard first..it is there design and they do have businesses to run, if Richard can OK, it then I can pass it on.
but not till I know I am not going to upset anyone
Degull wrote:wineboyrider wrote:I've got one from Fechter that I didn't have a chance to put together, because my Meanwell failed just before I got the boards in.![]()
I have a 48 volt 500 watt Meanwell that would love to meet that board. I'll take it if you want to sell it!
fechter wrote:I'm working with Degull to try to get more of these boards made. I first need to review the layouts and make any needed corrections. Hopefully we can make these available again soon.
cor wrote:Hi Neil,
With the access to the voltage control on these power supplies, it is rather simple to add a circuit to allow them to share current.
The basic principle is that a supply has a current sharing input and a sharing output. If the sharing input is not connected then the supply behaves as voltage source and represents the amount of current drawn on its sharing output.
When the sharing input is connected, then the supply compares the sharing input to its own amplified current sense signal and adjusts the output voltage to match the current that is represented at its input. In other words, all connected supplies will behave as current source.
Such a board would look a lot like a mini current limiter.
cor wrote:
Hi Richard,
Let me know if you like help - for example requesting a local (Sunnyvale) PCB house for a quote to produce & populate these. That would allow making them SMT and selling them complete without hassle about populating boards or making kits.
BTW, what was the issue or issues with the 3-pot board? I could see that the float control was iffy in that it had a control range of 5 mV while you probably also need to deal with noise and the opamp offset which is 3mV worst case, so more than half the control range. The noise can be dealt with by careful design and the control range vs input offset just means that the control range should be a little larger and also allow going negative. Or use an opamp with better spec.
NeilP wrote:
If there is another run of these boards..would a mod to them be possible to have a parallel sharing option as well?
NeilP wrote:If there is another run of these boards..would a mod to them be possible to have a parallel sharing option as well?
Degull wrote:A complete SMT solution would be the best no doubt but that might be far off if we have to rework the design and go through a testing phase.
cor wrote:Another interesting option is PCBfabExpress who have a "bare bones" offer that gives you two-sided FR4 boards with plated-through holes, which seems to be something that Richard was already using for the limiter boards.
Degull wrote:That would be amazing addition as well but again that will slow down the whole process for those of us that do not have a limiter already. It looks as though there are no more of these boards floating around for sale and I for one would like to have one now.
Degull wrote:Unless you want to part with the pretty one you took the pics of![]()
fechter wrote:When running multiple supplies in parallel, each one will run at its limit until the pack reaches near full charge, at which point they may not share evenly. I don't think this is a problem. Most of the time they will be in CC mode and sharing according to their individual limits. Once a supply hits CV, the pack is essentially done charging.
fechter wrote:Most of the issues with the 3 pot board were with the setup and testing instructions. There were also some issues with the parts fitting the holes on the board, both of which are easily corrected. It is still a bit tricky to set the cutoff current as you need some way to get the current at the cutoff point (around 100mA?) to make the adjustment. If everyone wanted the same cutoff current, I could use fixed resistors and eliminate the adjustment, but as cor points out, the error in the amplifiers is significant at the low end of the range so some adjustability is nice.
fechter wrote:The simple limiter board was laid out for a particular potentiometer from Mouser that has a tendency to go out of stock, so maybe I can have two sets of holes to fit more than one style of pot. I think I can also add a second set of holes for the shunt resistor to allow currents over 20A.
fechter wrote:I'm still on the road now and don't have the files with me. When I get home I'll look at revising them for the lastest changes.
Return to Items for Sale - New
Users browsing this forum: maca55, nechaus, Wanita and 7 guests
