Fechter's Mini Meanwell Limiter Board
Re: Fechter's Mini Meanwell Limiter Board
Postby auraslip » Fri Jun 17, 2011 10:49 am
Thanks neil - you are the boss and have practically taught me everything I've needed to know about these damn things.
auraslip
1.21 GW
1.21 GW
Postby NeilP » Fri Jun 17, 2011 11:27 am
Hey, thanks for that, but all I have really done is collated the info in my mind from all the multitude of sources, then spewed it back out when asked.
I have built my own twin Meanwell unit recently, so have all the info immediately to hand, I can't take credit for any of the work
Here is a link to recumbents page with all the info set out
http://www.recumbents.com/wisil/e-bent/ ... efault.htm
go bak to his home page, he has loads of other interesting useful stuff there too
Mongoose frame, Fox F100 forks,26x2.3 tyres
180mm disks
100V 20Ah LiPo
Lyen 18 FET 65 Amp,5304 in 26 inch Mavic rim
To illustrate the vain conceit that the universe must be somehow pre-ordained for us, because we are so well-suited to live in it, he mimed a wonderfully funny imitation of a puddle of water, fitting itself snugly into a depression in the ground, the depression uncannily being exactly the same shape as the puddle."
-- Richard Dawkins, in "Lament for Douglas" (14 May 2001)
NeilP
Postby auraslip » Fri Jun 17, 2011 1:38 pm
That site is legit - his black and yellow recumbent trike is probably the most bad ass electric vehicle I've ever seen!
auraslip
1.21 GW
1.21 GW
Postby fechter » Fri Jun 17, 2011 4:04 pm
There's a better picture of where the sensing line attaches on page 4 of this thread.
When using the limiter board, you can leave the limiter resistors in the Meanwell in their original configuration. If you modded the resistor in the Meanwell, it will limit at whichever one is set lower.
fechter
Postby NeilP » Sat Jun 18, 2011 2:04 am
Thanks Richard...I knew I had seen a better one somewhere, I just posted a re link to the first one I came across
180mm disks
100V 20Ah LiPo
NeilP
Postby Gregory » Sat Jun 18, 2011 8:27 am
auraslip wrote:That site is legit - his black and yellow recumbent trike is probably the most bad ass electric vehicle I've ever seen!
I think you are confusing Mr bad ass Matt Schumacher Recumpence with this website guy who is on ES but I don't remember his name.
1) x5305 Hub Motor in a 24" Sun rim with 10G spokes, Kelly 72601 controller, 74V 10Ah Turnigy LiPo 20C Battery and CycleAnalyst
2) Mac 10T rear hub in a 700C "comfort bike" 15S 5Ah LiPo, stock 28A Xie Cheng controller
Gregory
Postby TylerDurden » Sat Jun 18, 2011 8:46 am
Have a Nice Day,
TD
___________________________________________________________
FYI: Adding pictures?
Bored?... take a crack at the unanswered posts
Please post your Watts-at-speed in the survey.
TylerDurden
Postby hillzofvalp » Sun Jun 26, 2011 10:12 am
Here's my situation.. I built a 24V supply from two esp114 server supplies for my 1420i. However, for my 14s5p pack I would like faster charging. Could I split the pack into 7s10p for a quick charge? My supplies max out at around 50A. If necessary I could put in the original server fans for better throughput.
There are some pots inside that may adjust the voltage.. but I've never messed with them. Is 24 volts or a little less okay to charge a pack that is 23.1 nominal? I guess fully charged would be 3.42V/cell... but that's probably over 90% charged. I could then balance on the 1420i
If I need a current limiter, which one would be best from a member of ES? OR-- how could I build one from radioshack parts?
hillzofvalp
Postby fechter » Sun Jun 26, 2011 2:37 pm
I think we'll have to see a picture of the board on that one to make any guesses. I have no experience with that model. There should be some way to do it.
When charging at high rates like that, be careful that no cell group goes over voltage toward end of charge. Bad things could happen fast. 3.65v is the nominal target, but some commercial systems go even higher. 3.42v should be pretty safe and near 90% as you estimated.
fechter
Postby hillzofvalp » Fri Jul 01, 2011 10:03 am
I will take it apart tonight and post some pics. I'm hesitant not having a cut-off because I would like to walk away from the charger every once in while...
WHat guage wire do you guys use over 6 foot to charge at 35-45A? I've got some 10 gauge I thought I might try.
Also, when the battery reaches psu voltage, does the current go to 0?
hillzofvalp
Postby hillzofvalp » Sat Jul 02, 2011 3:20 pm
Before I was to disassemble, I tested it. I hooked up on 7s5p pack... psu stayed on as if nothing happened... but lights flickered a little bit. It blew lukewarm air for 5 minutes. since the pack is at 23.3V I don't think it's pulling very much, no? I see a .4-.5V jump when it is connected to psu.
I am browsing around to find the voltage control pins on this esp114 server supply, because a lot of people have had success adjusting voltage this way on other server supplies.
hillzofvalp
Postby fechter » Sat Jul 02, 2011 3:42 pm
hillzofvalp wrote:I will take it apart tonight and post some pics. I'm hesitant not having a cut-off because I would like to walk away from the charger every once in while...
10ga should be OK. Check it when it's running to see how warm it gets.
Yes, as the battery voltage approches the supply voltage, the current will taper down to near zero.
If you try discharging the the pack a little first, you should see higher currents at first.
fechter
Postby hillzofvalp » Sat Jul 02, 2011 3:46 pm
how does the charging current curve look?
hillzofvalp
Postby fechter » Sat Jul 02, 2011 5:22 pm
It depends on your batteries, but here is a typical charge profile:
A123 Charge Curves.jpg (62.15 KiB) Viewed 633 times
fechter
Postby steveo » Wed Jul 06, 2011 3:08 pm
Hey Everyone
i just purchased 2 1000w meanwell 48v psu
i am having the issue where i connect the psu to a load (my batteries) and the psu powers down.. I've had the same issue with a small 250w psu which i fixed with one of fechters mini meanwell limiter boards....
I was wondering if anyone could help me on where to connect the sense wire for the limiter board on the 1000w meanwell
here is a couple photos of both sides of the psu board
thanks
-steveo
http://www.youtube.com/user/trdfreak03
Project Deathtrap
viewtopic.php?f=6&t=46755
2002 Honda Insight Mk1 hybrid/Gridcharger/Mima & FAS/obd2c&c gauge/50s2p a123 40ah battery/100mpg+ /PP50 bms
For sale/barter thread
viewtopic.php?f=9&t=44316&p=645130#p645130
steveos repairs thread
viewtopic.php?f=3&t=27170
steveo
Postby NeilP » Wed Jul 06, 2011 5:49 pm
What is the white JST style multipin connector, looks like a LiPo balance lead socket?
Are you running the supplies in series or parallel
Try connrecting to a pack that is only a little discharged and see if the supply still drops out
180mm disks
100V 20Ah LiPo
NeilP
Postby steveo » Wed Jul 06, 2011 10:42 pm
I tried a pack that approx 5v difference between supply and battery and it cutout...
I gues if its 2-3v difference it wouLd not
However when charging a batter i can not keep tweaking voltage to keep charger going , it just has to work!
Hopefully i can get the limiter board wired in there
Steveo
Project Deathtrap
steveo
Postby NeilP » Thu Jul 07, 2011 1:39 am
or try the other type of current limit mods, if you can find the control rrsistor on this new board type
What exact model is this ?
180mm disks
100V 20Ah LiPo
NeilP
Postby fechter » Thu Jul 07, 2011 3:50 pm
Here's the datasheet for the switching controller chip:
http://www.onsemi.com/pub_link/Collateral/SG3525A-D.PDF
Looks like the error amp inputs are pins 1 and 2.
If I stare at the pictures long enough, I can probably trace it out.
I also see an optocoupler. These usually tie into the feedback,
fechter
Postby steveo » Sun Jul 10, 2011 8:29 pm
fechter wrote:Here's the datasheet for the switching controller chip:
I will give pin 1&2 a try
I measured 2.5v on each, which is jusy my old psu that has limiter board
Project Deathtrap
steveo
Postby fechter » Sun Jul 10, 2011 11:12 pm
It's pretty hard to trace from the pictures. Do you see anything that looks like a shunt?
My guess is raising the voltage on pin 2 will reduce the output. You could possibly try using a resistor like 100k from pin to the positive output and see what it does to the output voltage. You really want to feed just a little over 2.5v to pin 2 so you need to be careful with jumpers during testing. I think the chip fries if you put a little to much into there. There is probably another part of the regulator circuit that uses the LM358 and that feeds into pin 2.
Near the adjustment pot, there is a spot marked OVP. That might be the 2.5v reference spot.
On most meanwells, the sensing line is connected to one side of the adjusment pot.
The connector has pins marked S+ and S-. These might be remote voltage sensing inputs. You might see what the voltages on those pins look like.
The pins marked RC seem to go to the optocoupler and must be a remote control of some sort. Feeding voltage into the RC input might lower the output voltage. I suspect it's a 5v signal there.
fechter
Postby steveo » Tue Jul 12, 2011 2:01 pm
fechter wrote:It's pretty hard to trace from the pictures. Do you see anything that looks like a shunt?
hey fechter
I see the shunt wires on the opposite side of the capasitors, 3 shunt wires on this psu
do you mean use use a 100k resistor connected to pin 2 on that chip & connect it to the 48v dc output of the power supply?
sounds like that will make things crispy...
-steveo
Project Deathtrap
steveo
Postby fechter » Tue Jul 12, 2011 10:40 pm
steveo wrote:hey fechter
-steveo
Yes, that's probably a risky way to test it.
Measure the voltage on that 'OVP' pad near the voltage adjusting pot. I think it goes to the pot wiper. Otherwise try to get on the pot wiper somehow. That's really where you want to tie in the limiter. On most supplies it's around 2.5v, but some run 5v or more.
What you really want is to feed the reference point with just a little more than 2.5v. Up to 5v should be safe for the input. Depending on the resistances, 100k to the 48v might be in the safe range, but better to not risk that. I use a resistor to feed test points to limit the current.
Take a pic of the shunts. I saw something that sort of looked like one, but I think it was a jumper.
fechter
Postby steveo » Wed Jul 27, 2011 8:45 am
steveo wrote:Hey Everyone
thanks
-steveo
Hey Everyone,
I just want to say that i have gotten the 1000w meanwell to work with fechter's limiter board, The sense wire must tap into the "OVP" spot on the board, right next to the voltage turn pot..
I will post a video on my youtube of it working shortly, stay tuned..
Fetcher does the limiter board limit the current at 14amps?.... thats what i maxed out at!
-steveo
Project Deathtrap
steveo
Postby fechter » Wed Jul 27, 2011 10:58 pm
It should be close to that. It depends on what value resistor was used above the pot. The shunt should be good for 20A in theory, but will get hotter than hell. I think it will be OK at 15A. It can run pretty hot without damage.
fechter
PreviousNext
Return to Items for Sale - New
Who is online
Users browsing this forum: mwkeefer, Rodney64, zerogee and 8 guests
