OFFICIAL Electric Motoped
visuthdy
1 W
1 W
Re: OFFICIAL Electric Motoped
Post by visuthdy » May 10, 2014 10:04 pm
Matt,
Are you planning to make extra install kits for those who already have your drive and want to use it on the motoped :D
Thanks
recumpence
Location: On Earth right now. That can change at any time, though..........
Post by recumpence » May 12, 2014 6:31 pm
Yes. I plan on making subframe mounts that use the standard motoped engine mounts to adapt my drive. Also, one of my customers is developing a kit using my drive with his own mounts as a complete kit for sale.
I am not trying to hijack this thread, though. So, back on topic. :)
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
windtrader
Post by windtrader » May 12, 2014 11:04 pm
It is going to be exciting to see how the e-Motoped performs given the stresses will be quite different than on a regular bike, even a bike running trails. The amount of jumps and jolts and such will probably stress the drive line, motor, controller, etc greater than on a regular bike. Hope we see these before too long.
jansevr
Post by jansevr » May 28, 2014 6:33 pm
some of you might have already seen this if you are a member of the endless sphere or motoped facebook group...for those of you who havent:
ive always been interested in the motoped frames...finally took a few hours to model the frame and play around with a few things. plenty of space for batteries! pictured are 240 40c 5000mah lipo - 4440wh worth. the motor is john in cr's hubmonster
Imagemotoped 5 28 by mjansevreeling, on Flickr
kfong
Post by kfong » May 28, 2014 10:55 pm
Yay! Got my Motoped frame. Quality is great, very happy with frame. The new stiffeners look to be well planned. I had ordered the frame and upgraded suspension. Have not received the front or rear shocks, I assume that will come in a separate box. Packaging was first rate. I will post pics tomorrow.
r3volved
Post by r3volved » May 29, 2014 6:59 am
Awesome
Good to know they've gotten over their shipping hurdles.
Good luck in the build. I'm excited to see some electrification of this frame set
kfong
Post by kfong » May 29, 2014 7:18 am
Unfortunately, I will be going gas on this build. I have too many electrics at the moment and can't get the range I want. I will be looking into how easy it will be to change out giving me the best of both since the motor mount is just 4 bolts. If I see others with an impressive electric setup that might get me to veer from the darkside.
MitchJi
1 GW
1 GW
Post by MitchJi » May 29, 2014 7:59 am
"ive always been interested in the motoped frames...finally took a few hours to model the frame and play around with a few things. plenty of space for batteries! pictured are 240 40c 5000mah lipo - 4440wh worth. the motor is john in cr's hubmonster"
Would you mind posting it with measurements?
Best Wishes!
Mitch
The best quality batteries and lowest priced batteries for DIY EV's are tier 1 OEM Quality Cells from salvaged (wrecked) EV packs. Two examples are Chevy Volt and Nissan Leaf packs.
Nissan Leaf Module specs are here
Chevy Volt Pack Info - Salvage 16kwh Packs Under $2k here
The cells are rated conservatively by GM at 7.8C, Yabert's tests of Volt packs on the DiyEv car forum suggest a higher C rate, 15+ C!.
$1,400 plus $360 freight. Still over $1k less than new lead!
kfong
Post by kfong » May 29, 2014 2:50 pm
It would be great if we had a cad work of the frame in either a STEP file format or any other CAD format. This would make it easier to work out different combinations. With the electric versions having the motor mounts integrated with the battery mounts would create a stronger frame, and would be the approach I would do. There are mounting points on the top bar, I can work with any cad file members have started and correct to dimensions.
Kent
Post by Kent » May 29, 2014 4:20 pm
kfong wrote:Unfortunately, I will be going gas on this build. I have too many electrics at the moment and can't get the range I want. I will be looking into how easy it will be to change out giving me the best of both since the motor mount is just 4 bolts. If I see others with an impressive electric setup that might get me to veer from the darkside.
Even tho your going gas, could you still share your build with us?
72 V, (2x36v, 11.5 ah in series) Cellman, HS3540, 18fet Lyen, Jamis Dirtjumper Hardtail. Its streetlegal w license plate, inspection sticker.
Only by setting an example of good road manners and public courtesy can we convince the general public to take the electric bike seriously as a transportation option. Obey traffic laws!
My build: https://endless-sphere.com/forums/viewto ... =6&t=45706
Going legal: https://endless-sphere.com/forums/viewto ... =3&t=49390
kfong
Post by kfong » May 29, 2014 4:56 pm
Absolutely, I will start a thread on it since it makes a good ebike frame.
recumpence
Post by recumpence » May 29, 2014 5:45 pm
Man, I am so excited to get mine!
If I like it enough, I may build a gas version too because of the ease and low cost of it. Of course, my electric build will be primary in my stable, though. :-)
Matt
kfong
Post by kfong » May 31, 2014 7:18 am
Here are the pics
after building it I realize they did not send me the rear hub.
Started a thread on my build
https://endless-sphere.com/forums/viewto ... =1&t=60318
shipped in a sturdy box
Parts
top of frame
side view of frame
frame put together
K-ray
Post by K-ray » May 31, 2014 2:55 pm
Sweet!
Good to hear they're shipping out. Thanks for the pics Kfong, loving the look 8)
I have a couple frame sets ordered... will probably do one gas as I've had a new
motor forever in hopes of their production. Am also pretty set on one of John's
Mini's at high volts for the electric version. Thanks for that modeling work Jans...
thats gonna be one serious street bomber :D Giving me some visuals to ponder!
Kevin
efMX Trials Electric Freeride
Post by efMX Trials Electric Freeride » Sep 25, 2014 1:51 pm
noticed that motoped has a new site (and new ownership) ..
http://www.motoped-choose-your-adventure.com
they will be selling complete bikes with and without motors..
these pictures have ice motors..
but the bikes will be available without motors as well for possible electric builds..
trails, waves, and zombies beware :mrgreen:
Last edited by efMX Trials Electric Freeride on Jan 07, 2015 12:33 pm, edited 1 time in total.
some ride & sk8 videos:
metacafe.com/channels/NATAS666DAMIEN
http://www.youtube.com/natas666damien
i have nothing for sale.. :)
Gary Krysztopik
100 µW
100 µW
Post by Gary Krysztopik » Sep 30, 2014 1:45 pm
I have a motoped frame and one of Matt's drives, and I'm waiting for the rest of the kit. I started an unofficial Electric Motoped page and group on facebook. I'm building it as open source and posting my progress as well as trying to keep track of other builds. For anyone else building or interested in building one of these please join up.
Thanks,
Gary
liamcaff
Post by liamcaff » Sep 30, 2014 8:05 pm
Anyone know if it's possible to buy just the motoped frame for a electric build?
recumpence
Post by recumpence » Oct 01, 2014 6:40 am
Gary Krysztopik wrote:I have a motoped frame and one of Matt's drives, and I'm waiting for the rest of the kit. I started an unofficial Electric Motoped page and group on facebook. I'm building it as open source and posting my progress as well as trying to keep track of other builds. For anyone else building or interested in building one of these please join up.
Thanks,
Gary
Hey Gary. Good to see you here!
Matt
Post by efMX Trials Electric Freeride » Jan 07, 2015 12:23 pm
the motoped frame kits are now available again on the website.. :
http://www.motoped-choose-your-adventure.com/parts/
(more parts & accessories will be added as available..)
you can also get complete motoped bikes without motor for electric builds..
im expecting a motoped "pro" roller within days and may start up a build thread..
liamcaff wrote:Anyone know if it's possible to buy just the motoped frame for a electric build?
Perth_ebiker
Post by Perth_ebiker » May 13, 2017 4:24 am
What's happened to the e-motoped since 2015 ? Did they ever bring a production model to market ?
gone_walkabouts
Post by gone_walkabouts » May 13, 2017 6:50 am
Yes, production went ahead as planned- the sold and expanded the range
The bloke who did it had a falling out with his wife who ended up shooting him.
Such a pity but given the style of bike and where it would be today.
Perth_ebiker
Post by Perth_ebiker » May 13, 2017 9:01 am
Wow thanks. That's not quite the response I was expecting ! I see Hi Power make a complete bike based on that frame.
macribs
1 GW
1 GW
Post by macribs » May 16, 2017 3:48 pm
Shot him dead? world can be so ugly and brutal. What happen to counseling or breaking some dinner plates?
Keep your guns locked down and all in the clip none in the chamber.
Post by efMX Trials Electric Freeride » Feb 03, 2018 2:04 pm
Motopeds are still available on the market and available as a frame kit or complete motored bike (ice engine).. the inventor, Cam Woods sold his patent design to pitbike company Motovox and they are still in production.. there is also now a licensed usa manufacturer in Sturgis South Dakota :
https://www.motocruzin.com
I talked with one of the owners of motocruzin recently and they are working on bringing electric and hybrid motopeds to market soon..
motopeds with electric kit are also available from HPC Hi-power Cycles.. :
http://www.hi-powercycles.com/2018-typhoon-pro/
Last edited by efMX Trials Electric Freeride on Feb 03, 2018 2:32 pm, edited 1 time in total.
Post by efMX Trials Electric Freeride » Feb 03, 2018 2:20 pm
Electric kits for motopeds are also available from Race Proven Motors :
http://www.sytyperformance.com/index.ph ... &Itemid=26
