outolunch/Cruisin@live.com's FOR SALE thread.
Re: Li-ion Sanyo 18650 2.7ah 3.65v Cells w/solder tabs $2 ea
Postby grindz145 » Mon Aug 15, 2011 8:50 am
ptd wrote:ok, you have'em listed at vdl as 3.7v 2.6ah, which is it ? what's the chemistry ? any bulk discounting ?
at 2.6ah they would be LiCo, a very dangerous chemistry for ebikes, unless you know EXACTLY what you're doing. Very low discharge rates, very high energy density. Don't touch these things unless you're an experienced guru.
http://www.endless-sphere.com/forums/viewtopic.php?f=18&t=19548 - Ebike Nerd Podcast
Thanks to Justin @ ebikes.ca! Go there, buy stuff. Support the Revolution :D
grindz145
Postby MitchJi » Mon Aug 15, 2011 2:39 pm
Hi,
Also listed here:
http://www.diyelectriccar.com/forums/showthread.php?p=254470
I have about 200 of the Panasonic and 150 of the Sanyo both same specs which is 3.65v nominal, range is 2.5v to 4.5v
2.7ah hardly used and all have solderable tabs. Cells are about 2 years old and I don't believe they have been used much
as the BMS attached to them was defective. Voltage would be 3v+ when shipped.
He also does not balance them; just bulk charges. Says they've worked for him...
Bulk charging LiCo :shock:?
Best Wishes!
Mitch
MitchJi
Postby Kin » Mon Aug 15, 2011 10:47 pm
To be honest, it doesn't sound like he's the one who made the pack.
Edit: I say this because in my correspondence he says they don't go out of balance without a BMS, that they can be just bulk charged, and clearly they originally had a BMS [from the DIYelectric link]. So, he is not being fully honest.
New to endless-sphere? Notice a lot of signatures recommending Ebike.ca? That's because it's the best place for a quality and manageable, (but still 'real'), first build. Justin is a solid supporter of electric bike development, and a good source of equipment.
My hat off a thousand times to the green people that effectively run this forum. The ES Mods are superb.
Kin
Postby MitchJi » Tue Aug 16, 2011 2:52 am
Hi,
outolunch wrote:I used these cells to power the first VW conversion with a 120v 235ah battery pack which is still running today.
Kin wrote:To be honest, it doesn't sound like he's the one who made the pack.
It sounds like he meant the same type of cells in the VW conversion, not the same physical cells.
Best Wishes!
Mitch
MitchJi
Li-ion Sanyo 18650 cells 3.6v 2.7ah w/tabs $1.50
Postby outolunch » Sat Jan 07, 2012 6:38 pm
[attachment=0]DSCF0002 (6).JPG[/attachment Sanyo cells pulled from new excess inventory 18650 3.6v nominal 2.7ah
These have tabs for soldering. $1.50 each in quantity email cruisin@live.com
DSCF0002 (6).JPG (119.5 KiB) Viewed 629 times
outolunch
Re: Li-ion Sanyo 18650 cells 3.6v 2.7ah w/tabs $1.50
Postby Kin » Sun Jan 08, 2012 12:38 am
You might want to clarify- where are these coming from? Real sanyo cells, or high quality fakes? Are they old? Remaining capacity?
I am just saying this because I expect anyone interested in the cells will want to know at least that info^
Kin
NEW Deltq Q battery charger program to 131vdc
Postby outolunch » Sun Jan 29, 2012 11:38 am
Operates on 110/220vac. Currently programmed for lead acid but can be reprogrammed for Li-ion. $400.00 plus shipping email me at cruisin@live.com
outolunch
Curtis 1238-6501 AC cont 108vdc $1000.00
Postby outolunch » Sun Jan 29, 2012 11:43 am
New in box email me at cruisin@live.com
outolunch
Curtis 1238-6501 & HPEV AC-31 $1900.00
Postby outolunch » Sun Jan 29, 2012 11:53 am
outolunch
NEW Delta Q charger both 110 and 220v
Postby outolunch » Thu Feb 09, 2012 3:32 pm
New Delta Q 110/220v charger programmable 96-135v with optional temperature sensor and remote charging LED.
$400 plus shipping from CA email cruisin@live.com
outolunch
Li-ion 18650 3.2v 2.7ah cells unused $2.00
Postby outolunch » Thu Feb 09, 2012 3:35 pm
Unused 1860 Li-ion Sanyo and Panasonic 3.2v 2.7ah cells $2.00 in quantitys of 10 or more.
cruisin@live.com
outolunch
NEW Curtis 1238-6501 108v Controller 550a
Postby outolunch » Thu Feb 09, 2012 3:36 pm
New in box Curtis 1238-6501 Controller 108v 550a mprogrammable for most AC motors
cruisin@live.com
outolunch
Re: NEW Curtis 1238-6501 108v Controller 550a
Postby amberwolf » Thu Feb 09, 2012 4:11 pm
And the price is?
It's annoying when people put stuff up for sale without a price. :(
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby neptronix » Thu Feb 09, 2012 4:12 pm
needs pic, specs, price.
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Postby oatnet » Thu Feb 09, 2012 5:04 pm
amberwolf wrote:It's annoying when people put stuff up for sale without a price. :(
I'm more annoyed by the repetitious cross-posting. This user has alread listed the same item
here, in items for sale NEW:
viewtopic.php?f=31&t=36272&p=526021#p526021
and 10 minutes later, in items for sale USED:
viewtopic.php?f=9&t=36273&p=526024#p526024
Not to mention here:
viewtopic.php?f=31&t=27133&p=392029#p392029
and here:
viewtopic.php?f=31&t=24366&p=352876#p352876
and here:
viewtopic.php?f=31&t=22935&p=333539#p333539
etc etc etc. You can read through his posts to see more.
I don't understand why he keeps creating new threads, instead of bumping his old ones. I would probably cut him some slack if he participated on the forum by contributing knowledge, but he has only posted here to sell stuff. OTOH, the more stuff for sale here the better. OTOOH, dunno if I would buy from someone who doesn't have a reputation on E:S. {conflicted]
-JD
Member 117 of 16,xxx
179v VW Camper © 164v Vectrix E-Moto © 72v Norco A-line/x5403 © 60v Specialized Enduro Comp/BMC © 72v x5tracycle © 48v TF IO/BMC © 36v Kepler Friction Drive © Spot-Welding a123 © Pelican Front Packs © Vectrix Battery Replacement © MORE !!
Image大鸡巴 Motors
Knowledge is acquired through experience, everything else is just information - Albert Einstein
"Cheater?" I'm not competing, I'm Commuting!
oatnet
Re: Li-ion 18650 3.2v 2.7ah cells unused $2.00
Postby migueralliart » Thu Feb 09, 2012 5:05 pm
email sent
migueralliart
Re: outolunch/Cruisin@live.com's FOR SALE thread.
Postby amberwolf » Thu Feb 09, 2012 6:03 pm
@Oatnet (and others that used the report button instead of posting): You're right, so I merged *ALL* his sale threads for all items into his oldest sale thread. Since he usually doesn't come back to post in them anyway when people ask questions, it doesnt' really matter if all the items are all mixed up.
All future sales posts in the market by outolunch will be moved to this thread. All sales posts by outolunch outside the market will be deleted.
amberwolf
Postby neptronix » Thu Feb 09, 2012 6:08 pm
Good move amberwolf. Maybe he will take notice :P
Looks like he never responds to his sales threads. This is verging on spammer classification IMHO
neptronix
Curtis 1238-6501 108v 550a controller $800
Postby outolunch » Thu Feb 09, 2012 8:41 pm
New Curtis 1238-6501 Controller for sale cruisin@live.com
outolunch
Postby nicobie » Fri Feb 10, 2012 3:17 pm
He told me that he is a salesman for this company.
http://minibms.mybigcommerce.com/
May your tote always stay tight and your edge eversharp :wink:
my eTownie build thread: viewtopic.php?f=6&t=23701
nicobie
Postby neptronix » Fri Feb 10, 2012 7:15 pm
nicobie wrote:He told me that he is a salesman for this company.
I'd say they could probably use a better salesman; one who will post the price, picture, and location of the goods.
neptronix
NEW DeltaQ 131v battery charger $425.00
Postby outolunch » Tue Feb 14, 2012 7:03 pm
At East Bay Conversion located in California, we have excess stock in new DeltaQ battery chargers. These chargers that look like a Elcon and will accept both 110v and 220v input, have heat sinks making fans unnessary. Programming available for differant type of batteries including Li-ion cells. I can be contacted at EBEVCONVERSION.GMAIL.COM
outolunch
Re: NEW DeltaQ 131v battery charger $425.00
Postby oatnet » Tue Feb 14, 2012 8:32 pm
EBEV wrote:At East Bay Conversion located in California, we have excess stock in new DeltaQ battery chargers. These chargers that look like a Elcon and will accept both 110v and 220v input, have heat sinks making fans unnessary. Programming available for differant type of batteries including Li-ion cells. I can be contacted at EBEVCONVERSION.GMAIL.COM
This is just the spammer "cruisin" branching out to new user id's. The link below shows it using both id's to spam diyelectriccar:
http://www.diyelectriccar.com/forums/showthread.php?p=267945
Image大鸡巴 Motors
oatnet
Postby Ypedal » Wed Feb 15, 2012 10:16 am
as much as we all enjoy a good deal and a discount, this type of activity will not continue.. one way or another ! :twisted:
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Postby amberwolf » Mon Apr 16, 2012 3:59 pm
Outolunch has now posted four different sale threads (one a week or two ago, which I deleted but let slide, three today which I deleted but am no longer letting slide) outside this thread, despite repeated warnings not to do so.
Outolunch has now earned a 1-month ban, as well as removal of those other sale threads.
EDIT (added, 5-3-12): For the creation of username "evnut" as a way to get around the temporary ban, the "outolunch" username has been permanently banned. The "evnut" username has been deleted, as will future usernames by this person as they are discovered, for flagrant disregard of moderation instructions about commercial for-sale postings, then for further ignoring and going around temporary bans to try to get the point across.
amberwolf
PreviousNext
Return to Items for Sale - New
Who is online
Users browsing this forum: No registered users and 3 guests
