our new website: http://www.ebikedeal.com (please check website for all new lower pricing)
just received a FRESHLY BAKED BATCH OF CRYSTALYTE HS/HT MOTORS,,,,BOTH SENSORED AND SENSORLESS, plus the new APM's are finally here!
YOUR choice of mounted on rims or just the bare motor.
USA: ALL ORDERS TO USA ARE SHIPPED DIRECT VIA UNITED STATES POSTAL SERVICE,,,SAVE BIG TIME ON SHIPPING FEES,,,SHIP TO CALIFORNIA 38$, SHIP TO MIAMI 30$ SHIP TO MAINE 22$ to get exact cost send me your zip code. these prices are for the full motor laced on a 26"rim with the controller and accessories! NO CUSTOMS! NO HASSLES! USA TO USA,,,,WINNING!
CANADIANS: GET YOURS DIRECT FROM CANADA!AGAIN NO CUSTOMS! NO HASSLES! UN-FRIGGIN-BUH-LEEEV-ABLE!
WARRANTY: ALL OUR PRODUCTS ARE GUARANTEED AGAINST DEFECTS FOR 9 MONTHS AFTER PURCHASE,BUYER MUST ASSUME ALL SHIPPING CHARGES FOR WARRANTY REPAIRS.
Any orders made will be sent out immediately,,,SUPER DUPER FAST! as soon as payments are made in full.
Sensorless
ok here it is from the horses mouth,,,i finally mounted a HS sensor-less motor and a clyte 48v45amp controller,,,and it runs smooth as silk and is fast as well SO FAR MY TOP SPEED HAS BEEN 49KMPH i have not yet brought it up to full speed cause i need a longer straightaway i will post my top speed when i go to the "testing flats",,,,but it seems to be faster than my 5303 and this controller is 45amps where as my other controller was 35amps,,,so I'm sure the 10 amps is giving me the extra speed im sensing... i have heard reports that even at the same amps the new HS is faster) and to top it all off, good torque,,,, as far as I'm concerned there is no reason whatsoever to go with sensored unless of course you don't want to change controllers and use a regular sensored controller with the 5 hall effects wires,,,,but for those on the fence you will not be sorry with the sensor-less set-up,,,its incredible how smooth the starts are,,,,(the only thing is if in fact u are at a dead stop u will notice a slight jitter,to remedy this u just need an ever so slight momentum in forward direction and from there it is literally as smooth as sensored motors)literally just a slight forward movement of just an inch does the trick for a smooth as silk start!!!aside from that u cannot tell the difference between sensored and sensorless,,,any one care to comment?
All our new HS and HT motors come laced with 12G stainless steel spokes on 24" 26" or 700c rims !!!
other sizes can be had for extra charge laced in high quality rim by a pro.
we also offer bare motors without the rim.
Brand new carrier bag available in 24" 26" and 700c sizes
REGULAR PRICE $35.00 SPECIAL only $20.00
Please direct all questions to maxwellsmart8686@hotmail.com or call me at 450-681-1913 (ask for max) or PM me here.
Feel free to post any comments,complaints,insults or questions on this thread,however if you have specific questions for me then it is best to use one of the options above for quickest response.
also note: payments are at a different email address maxpowerev@hotmail.com
Special note: be sure to read the Pay Pal instructions at the bottom of this post in order to save the 3.3% PP fees
Here is a video that shows a direct comparison of the new sensorless HS and HT motors to the old 5X series: [/i][/size] http://www.youtube.com/watch?v=cgssLyUYlcQ
New Crystalyte REAR HT3525, HS3540 Motors. sensorless (less wires = less hassles and problems)and sensored(for those that want to use their sensored controllers) motors both available . These new motors can accept up to 9 speed freewheels, disk brakes. All motors come with Anderson connectors.
both chrystalyte HS(high speed) and HT(high torque)series are capable of accepting 36v to 60v and possibly more,,,,with speeds to 60 kmph and more on the HS (high speed)series.
Legal Shmegal stuff,,,when using these motors consult your local authorities as to the legal safe speed limits allowed on E-Bikes,in Quebec the legal limit is 32kms per hour,,,any faster and the bike must be registered and licensed with proper lighting.MaxpowerEV assumes no liability whatsoever in terms of personal injury,dismemberment,death or property damage when using our products.
Motors available laced in 24" 26" and 700c rims with 12G Stainless Steel Spokes
HS3540 REAR Brushless Motor (7.4kg) 49 kph at 48v on 24" 26" or 700c rims $400
HS3540 REAR Brushless Motor (7.4kg) 49 kph at 48v no rim $350
HT3525 REAR Brushless Motor (7.4kg) 25 kph at 36v on 26" rim $400
ControllersNote that you must not plug #5 (ADJUSTMENT PLUG) until you read directions here: viewtopic.php?f=2&t=27890
All new controllers come standard with plugs for APM,PAS,Throttle,E-Brake, etc.
48V 40A Sensor less controllers genuine 12 fets 4110 : perfectly matched for above Sensor-less Motors.$160 + shipping.
60V 40A Sensor less controllers genuine 12 fets 4110 : perfectly matched for above Sensor-less Motors.$160 + shipping.
72V 45A Sensor less controllers genuine 12 fets 4110 : perfectly matched for above Sensor less Motors.$160 + shipping.
Here is what the APM will allow you to do:$110 + shipping.NOW FREE WITH HS/HT MOTOR AND CONTROLLER!
Display Speed / without magnetic sensor on the wheel even on
the sensorless controllers!
Display Voltage
Set the PAS and Cruise
you can adjust 9 speed settings from low to high.
Adjust the low voltage cut off / LVC
Adjust the current,,,you can adjust the amps and the volts.
older version controllers not compatible for APM
72V 50A Sensored controllers genuine 18 fets 4110 : for above Sensored Motors.$170 + shipping.NOW LIQUIDATING,,,MAKE ME AN OFFER!
48V 40A Sensored controllers genuine 12 fets 4110 : for above Sensored Motors.$130 + shipping.NOW LIQUIDATING,,,MAKE ME AN OFFER!
IMPORTANT Details about the CONTROLLERS and WIRE HARNESS can be found here: viewtopic.php?f=2&t=27890
IMPORTANT TIPS for your first E-bike build here: viewtopic.php?f=3&t=10370
ACCESSORIES
SPOKE SETS
20" 22" 24"26" AND 700C SIZE $30.00
3 speed LMH (switch low med high),, $15 note: i have LMH switches but they are for the older controllers,not the new sensorless controllers
$20.00 split throttle,, with motor or controller $15
$20.00Thumb throttle,,with motor or controller $15
$20.00 full throttle,,with motor or controller $15
$30.00 LEFT HANDED THUMB throttle,,with motor or controller $25
KEY HARNESS AND CHARGER PORT $25.00 with motor or controller $20.00
SEVEN SPEED CASSETTE $20.00 with motor or controller $18
6" DISK FOR BRAKE $18.00 with motor or controller $15
8" DISK FOR BRAKE $20.00 with motor or controller $17
BRAKE CALIPER $15.00
LMH SWITCH $15.00
CRUISE CONTROL $15.00
CONVERSION WIRES:
FLAT 5 PIN TO XLR CONNECTOR FROM OLDER CONTROLLER TO NEW MOTOR $20.00
FLAT 3 PIN WIRE THAT FITS INTO NEWER CONTROLLER INTO 4 PIN THROTTLE PLUG $15.00
shipping not included (PM me your zip code and state(i.e. Florida,Kansas etc) with what you want to order to receive shipping fee quote)
Canadian residents shipping 1 HS or HT laced on rim series motor and controller anywhere from $20.00 and up,,,send me your zip for an accurate quote.
All orders can be paid by PayPal almost free! or add 3.3% to total amount if paying PayPal by credit card or $5.00 e-Cheque option explained below to: maxpowerev@hotmail.com
NEWS FLASH
YOU CAN USE PAYPAL TOTALLY FREE or 1%,IF YOU HAVE FUNDS IN YOUR PP ACCOUNT,WHEN MAKING A PAYMENT SELECT "PERSONAL" THEN "GIFT" FOR SOME REASON THAT OPTION IS FREE, or 1% THANKS. IF YOU PAY PAYPAL WITH A CREDIT CARD THEN YOU ARE SUBJECT TO FEES.
Here is another PayPal option,,,READ CAREFULLY: There is a PayPal option that allows a flat $5.00 fee as opposed to the normal 3.3%,,,as an example a $400.00 order would cost $13.20 in paypal fees,,,but if you choose the E-Cheque option it will be a flat fee of only $5.00 ,,,,,not bad considering the other option! The only drawback is when you choose the E-Cheque option it will take 3 to 5 days for the payment to clear,,,so if you don’t mind to wait for that bit of time for your order to be sent out then perfect. If however you want the order sent out the same day then you can use the gift option which is instant payment (if of course you have the funds in your PayPal account)also you must be aware that choosing the E-Cheque option will mean that the funds are removed from your bank account registered with paypal and not from your funds in your PayPal account.
for more info pm me here,,,or call 450-681-1913,,, or leave your tel# and time to call, long distance is free for me.
Max Kogan
For those wanting in the next order you can have it mounted on any size rim,20" 22" 24" 26" or 700C,sensored or sensorless,or if you prefer just the bare motor,,,and you too can benefit from "special pricing" . this means if you need something i do not have in stock,and you are willing to pre-pay in full,and your willing to wait for a long time for the next shipment to arrive then you will benefit savings.
