kriskros wrote:i just bought a motor from max... arrived as promised...tried it out... 26.5 mph with an a123 36v,20amp battery![]()
neptronix wrote:kriskros wrote:i just bought a motor from max... arrived as promised...tried it out... 26.5 mph with an a123 36v,20amp battery![]()
Dude, thanks. I have been asking for a speed report for a long time.
Is that pedaling or not pedaling?
jimw1960 wrote:Sent you and email. I'm interested in a rear HS with a 48v controller. Out of curiosity, would the 72v controller work on a 48v battery or would it hit the low-voltage cutoff?
thewmatusmoloki wrote:Sounds great, I'll take an HS motor and 72v controller thanks. Do I just go ahead and transfer the money into this (maxpowerev@hotmail.com) paypal account? i'm in australia so I expect delivery will take a couple of weeks?
methods wrote:Lemlux wrote:I've read elsewhere that Crystalyte is abandoning CA compatibility in favor of their own similar device that is scheduled to come out in June. Are your controllers third party with CA connections?
Thanks.
Untrue
Kenny will wire controllers to be CA compatible. It is up to the retailer to insist that Kenny does this![]()
If the retailer does not insist then it is probable that Kenny will not add the CA connector - which would be very lame.
-methods
wojtek wrote:That is really sad, from my perspective Kenny should use the same cable for his analyst as it is used for CA.
Jozzer wrote:Your already the guy to go to for the guys that other guys go to..
methods wrote:.... and controllers should have connectors for BOTH
methods wrote:wojtek wrote:That is really sad, from my perspective Kenny should use the same cable for his analyst as it is used for CA.
Kenny's "analyst" is nothing like the CA and does very little "analyzing" - it is more like a collection of other basic (and a few cool) features in an fancy box. People will think it is cool (at first) but will quickly see that it is in no way a competitor to the CA as it is missing the most critical feature. You certainly would not want the same connector as the CA - first because the electrical connections are totally different and second because people will quickly find that they still need a CA.
When you start seeing these new boxes on the bars my guess is that it wont be long before they are sitting right next to a CA.
Really different creatures..... and controllers should have connectors for BOTH
-methods
slayer wrote:I just want to add that the cycle analyst direct plug in (CA-DP) will work except the speedometer not working everything else does and you could make mod inside the controller to make it fully fonctional
Also for those who know that now they can buy the cycle analyst with the speedometer sensor seperate (CA-DPS) and they will have every feature
maxwell65 wrote:slayer wrote:I just want to add that the cycle analyst direct plug in (CA-DP) will work except the speedometer not working everything else does and you could make mod inside the controller to make it fully fonctional
do you have pics and instructions to make the sensor less controller fully functional with the CA? we neeeeeed toooo knooowwww
whatever wrote:stainless steel spokes??? stainless = brittle over time = breakages
surprised crystalyte would even supply stainless with all their years of experience
stainless = bad idea
slayer wrote:maxwell65 wrote:slayer wrote:I just want to add that the cycle analyst direct plug in (CA-DP) will work except the speedometer not working everything else does and you could make mod inside the controller to make it fully fonctional
This is the part you need to change : the speed wire from the controller ...the wire speed is at the hall sensor you need to put it where he explains (Justin Lemore) he is showing all the other functions like throttle over ride and all but this is the only mod needed the speed wire...
Part of the appeal of the CA-DP installation is that it picks up the motor speed information from the motor hall signals rather than requiring an external spoke sensor and magnet. However, in a sensorless controller there aren't any hall signals as such. With the previous incarnation of the analog Crystalyte pedal first controllers, there was still a signal line that would toggle at each commutation and could serve as a speedo pulse, but it was prone to glitching at startup and causing false speed readings in the 100's of mph.
On these new boards, there is an LM339 comparator chip that compares the motor phase voltages to a synthesized neutral voltage and the three outputs are conveniently brought out as 3 test point pads on the ciruitboard, so you can trivially solder the yellow CA-DP wire into one of these to get the motor speed reading. From my testing the pulses are very stable even at low speeds (3-4 mph) and during startup:
this is the thread viewtopic.php?f=2&t=26336
Return to Items for Sale - New
