Crystalyte Motors,NEW APM's all in stock !
Re: HT HS crystalyte motors,IMMEDIATE delivery,ALL ACCESSERI
Postby methods » Sat Jun 18, 2011 6:17 pm
No doubt. If someone wants to buy a single ebike kit and use it for normal non-insane things the sensorless kits Max provides are simple and reliable with no compromise in running performance (though i would ask about *starting off* from a dead stop on a steep hill). I would not hesitate to buy one of these kits for my mom.
Oddly - sensorless is actually *more reliable and efficient* - but since the market is hindered by controllers that can only operate with sensors there is a heavy lean toward the sensored direction. What the market needs is a controller than can leverage sensors (great off the line performance) but also run sensorless (reliability & efficiency once at speed).
-methods
EDIT: One more note.... If somone buys one of these Crystalyte sensorless controllers it is highly likely that it will be compatible with almost any DD motor on the market - even if it has blown halls! A sensorless controller is the best choice for a backup controller since it does not care if your halls are blown. A good buy for sure. If I had my choice I would want a tiny 6 fet sensorless stashed away on the bike at all times.
Jozzer wrote:Your already the guy to go to for the guys that other guys go to..
I sell stuff.... like little morsels of my integrity @ http://www.MethodsTechnology.com
methods
Postby CrazyJerry » Sat Jun 18, 2011 8:51 pm
The Crystalyte 48v 45amp sensorless controller and HS motor that Max is running is also what I am running. Since late April I've topped 1255 miles with zero issues. Last week I ate my first moped. He kept his dignity by sitting up as I overtook him 47mph! Credit given for not quitting as he resumed the aero-tuck immediately after!
The commute to work is 30 hilly miles round-trip. If anything with this new sensorless setup goes south I'll post it as well!
- CrazyJerry
Experimental Daily Commuter:
http://diesel-bike.com/Aurora/aurora.html
Crystalyte Sensorless DD
2,000 miles on build and counting
External Regen and Electric Brake
CrazyJerry
Postby gerrydesign » Mon Jun 20, 2011 7:15 pm
Just wanted to thank Max for the C-lyte motor and accessories I ordered a weeks ago. I just had my 1st ebike initiation last night and literally, my first press on the throttle I thought I was going to do a willie :) I'm running 48V 20aH and a 48V/72V 12 x 4110 MOSFET Extreme Modder Sensorless Controller from Lyen. I still need some schooling to what connector to use. My newb set-up right now is all connected via electric tape.
forever noob
Specialized Rockhopper
Xlyte HS3640
12 x 4110 MOSFET Extreme Modder Sensorless Controller LYEN Edition with custom 36-50 and 55-80 volt setting
http://www.axiate.com
http://www.gerrydesign.com
gerrydesign
Re: HT HS motors,NOW SHIP DIRECT FROM USA! AND CANADA!SAVE
Postby RVD » Tue Jun 21, 2011 3:57 pm
anderson powerpoles. i like them a lot.
buy like 5 feet or so of red/black 10, 12, 14 gauge wires, 25 red, 25 black, and 25 45 amp connectors of andersons, 10 30 amp connectors. get a crimper tool (tricrimp) and a wire cutter. then go wild...
TidalForce S-750, 9C 2807, 14s lipo. Build Thread: viewtopic.php?f=6&t=27525
Dahon Speed D7, e-bikekit 350 watt geared motor, 12s lipo. Build Thread: viewtopic.php?f=6&t=34958
RVD
Postby Doctorbass » Fri Jun 24, 2011 1:16 pm
Max, any news about the problem of using these Crystalyte controllers and the cycle analyst?
In fact the cycle analyst connector of these controller dont work for the current reading and the speed.
You can modify the internal two white and blue wires of the C-A connector plug inside the controller and connect them to the shunt ( the right place!)
so you'll be able to read the current and power.
but for the speed reading, the direct plug in connector of these crystalyte SENSORLESS controller DONT WORK
Max.. any news about a possible mod to allow the cycle analyst user to be able to get power, current ans speed reading with your revisoin of the crystalyte controllers?
A have a group of student from high school that i suggest them to buy motor and other equipment from you but as for the cycle analyst.. unless you dont have good news about the direct plug in connector for the C-A and your controller, i might need to suggest them to but the non direct plug in version of the C-A and to use the magnetic sensor for the spokes.
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby Bison_69 » Sat Jun 25, 2011 12:07 pm
Hi Doc... (Stephane),
I bought one of those sensorless controler lately and I think you won't expect much from Crystalyte on this one... IMO I think they released this version especially to be used with their new display coming out this month... (which is very limited to compare with the CA)
SG
(166.32 KiB) Downloaded 3 times
Crystalyte e-display 2.jpg (43.88 KiB) Viewed 932 times
APMDisplay_Owners_Manual.pdf
(777.66 KiB) Downloaded 53 times
=>First eBike conversion in progress!...
=>Giant DH Comp 2004 (with damageless torque arms)
=>Crystalyte rear HT hub-motor
=>Lyen 12 x 4110 MOSFET Extreme Modder Controller (from 24 to 100V)
=>Large screen CycleAnalyst
=>Batteries are yet to come --(may be Headway 40152S 15Ah in 20S2P setup)
=>SolidWorks Design - electric Trike for a Montreal friend well known on the forum...Maxwell65
=>"Your tiny little human brains. How do you get around in those things?"
Bison_69
Postby maxwell65 » Sat Jun 25, 2011 5:18 pm
hi doc,
no news yet,,,clyte now has the APM's but they still gave me no info as to what it reads from the controller,,,volts, AH, speed etc.it will be interesting to see what in fact it will do and if it will need a magnet and sensor on the wheel to determine speed.
maxwell65
Postby neptronix » Sat Jun 25, 2011 11:18 pm
The crystalyte controller looks an awful lot like a 12FET infineon..
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Postby Doctorbass » Sun Jun 26, 2011 11:59 am
neptronix wrote:The crystalyte controller looks an awful lot like a 12FET infineon..
yeah.. the exact same board.. i discovered that with the 18 fets boards 18 month ago
and.. they are programmable too!.. but C-lyte dont mention that and dont install any connector for that! :roll:
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby wojtek » Sun Jun 26, 2011 12:12 pm
there is something really wrong about crystalyte.
they did come up with a good motor [excellent weight / power ratio] but there are some ridiculous facts around..
- the cable management with very sharp plastic housing that easily cuts the cable(s)
- releasing the sensorless controller WITHOUT CA cable and at the same time WITHOUT their own solution [still in progress, and nobody knows when ...]
- no sensored option right from the factory [even though the production costs for it are extremely low]
If Ken listened more, the HS /HT series would be a total hit on the market with plenty of happy customers! But no, he does leave us with a bitter taste in the mouth.
WIRES AND CONNECTORS
viewtopic.php?f=31&t=30176
http://endless-sphere.com/forums/viewto ... 31&t=32244
http://endless-sphere.com/forums/viewto ... 31&t=32152
Go-One Evo tested with HS3540, now working on Cromotor
BATMOBILE - Astro 3220 / Nuvinci in progress
Velokraft e-VK3 / Max speed 90km/h downhill - EVKA [for sale]
Steintrike Mungo Sport HS3540-SOLD
Scorpion FS HS3540-SOLD
Kona Dawg BMC v2-SOLD
wojtek
Postby maxwell65 » Sun Jun 26, 2011 3:13 pm
wojtek wrote:there is something really wrong about crystalyte.
hi,
about your comments: "- the cable management with very sharp plastic housing that easily cuts the cable(s)" is that really the case? i looked at the housing and it looks fine to me,,,do you have pics?
"- releasing the sensorless controller WITHOUT CA cable and at the same time WITHOUT their own solution [still in progress, and nobody knows when ...]" i agree thats a bummer,but they do have a version 2 that came out,,,but im still waiting to hear if it works.
-" no sensored option right from the factory [even though the production costs for it are extremely low]" the option is in fact there and hall sensors can be installed on the sensorless versions as the notches for the halls are in the motors,,,,i choose not to order the sensored versions as i was worried that the spacing to allow the 5 hall wires would be too tight along with the 3 phase wires.
all that being said, so far all the people that are using the sensorless versions (no halls) are very happy and impressed,,,and i am very impressed as well,,,i am going to be ordering a huge amount of HS and HT motors for my next shipment as i know first hand this is absolutely the case,,,,there is no way i would commit to another order if this was not the case.i would have to be just plain nuts :shock: ,,,i never ever sell anything unless i am a happy end user,,,and im very happy and very impressed with these new HS and HT motors :D ,,,(i have an HS which im currently using with the sensorless 48v45amp clyte controller,,,i did not try the HT version yet, but from the customers that are using them they are also very happy),,,if you intend on going over 72v45amps then the consensus is you should have the halls as the sensorless is not that smooth on the takeoffs as well as not being able to get to top speed apparently,,,so high volts and amps not so great for sensorless.
IMHO go sensorless if you are staying up to 72v45amps,,,this way you have great reliability by not having the 5 hall sensors and great performance,,,
Go sensored if you have a need for more than 72v45amps,,,,plain and simple.
maxwell65
Postby wojtek » Sun Jun 26, 2011 4:48 pm
there are 2 housings - the first one is fine. But when you take it out, there is another one. When you touch the edges [where the cables are placed] with your fingers, you will feel it...
Im sorry Max - didnt mean to post it in your selling thread- thought it was another one about HT/ HS in general.
I agree about using the crystalyte sensorless kit for low power usage. Today i had another day of offroad riding on my trike with 44v.4v zippys. Great torque of HS in 20inch wheel, very quiet [cant really tell that it is electric from the noise!], good speed [although i cant measure it at the moment]
No issues whatsoever.
wojtek
Postby maxwell65 » Sun Jun 26, 2011 8:14 pm
wojtek wrote:there are 2 housings - the first one is fine. But when you take it out, there is another one. When you touch the edges [where the cables are placed] with your fingers, you will feel it...
no problem to post here,,,we all want to improve as much as possible these new motors,,,if you say there is a sharp edge then we need to rectify this,,,i will look into this further and bring it up to kenny.
maxwell65
Postby wojtek » Mon Jun 27, 2011 1:14 am
excellent - my point is, all those problems can be solved either by end customer or the vendor. But best to make it right on the production line. This will reduce the price and save some time for the vendors. [who would charge for any modifications / improvements]
And save time and the risk of losing the warranty for the end-customer if trying to do it by themselves.
wojtek
Postby methods » Mon Jun 27, 2011 11:57 pm
Justin posted the exact instructions for hooking up a CA tap on the sensorless controllers months ago.
-methods
Doctorbass wrote:Max, any news about the problem of using these Crystalyte controllers and the cycle analyst?
methods
Postby methods » Tue Jun 28, 2011 12:10 am
The manual is in the post right above yours. Read it carefully.... It is not as full featured as it sounds. Example:
"Fuel Gauge"
Ask yourself if that is based on AH (as the CA is) or based on Voltage (which is totally useless for chemistry like LiFe). Even worse, the "fuel gauge" can only be set to an interval of Lead Acid battery... so you cant even try to adjust it to your lipo pack.
The box has some cool features and it integrates with the controller chip nicely but it is not a replacement for the CA. More of a cool gadget than a serious meter.
Think about how the efficiency and torque measurements are being calculated when the box knows nothing of the motor it is hooked to. How could it POSSIBLY claim to make such a measurement? It cant... I guess it is nice that it shows a noob rider that high load and low speed is inefficient - but that is about it.
Kenny could have hit a grand slam with this box but it is missing a couple of very key concepts that the CA does perfectly.
-methods
maxwell65 wrote:hi doc,
methods
Postby eugenem » Wed Jun 29, 2011 8:24 am
Hi Everyone!
I just got the hs3540 kit from Max and now I'm on a hunt for a proper battery.
What kind of a battery can you recommend for the hs3540 and the clyte 48v45a controller? I guess that there's no point in having a 45a controller is the battery is not rated for this kind of a discharge.
I would really prefer a US supplier because it would get me the battery sooner so any suggestions are welcome.
eugenem
Postby eugenem » Wed Jun 29, 2011 10:41 am
Never mind. I got a 16S 4P A123 pack from cell_man :D
Can't wait to try everything out!
eugenem
Postby eugenem » Fri Jul 01, 2011 7:43 am
I'm a little confused. Which version of CA will work with my setup? The stand alone or direct plugin? I assume all that's required is to plug it into the controller, am I correct?
It also looks like it won't be able to tell my speed, is that correct as well?
Sorry for all of the newby questions. Just trying to figure this out.
eugenem
Postby rui_fujino » Sat Jul 09, 2011 1:45 am
hi guys, has anyone actually done 72v setup with HS3540 yet?
im interested of upgrading to it if the top speed is good with price... :) but then as far as i know all the problems are putting me off from even getting new motor...
how may types of controller is available so far for the sensor-less? i know you can get 72v40 and 72v45a at moment...
Project 1: Apollo slant hard tail MTB 52v lifepo4, conhismotor, 52T-11T gearing 39.6mph top speed (with pedal)
Project 2: Diamondback s:10 Full suspension 20s2p (83.5v 10ah Lipo), 35kg, HS3540 sensored (MethTek), 12FET lyen controller, Bulk 600w balance charger.
Top speed 45mph(72.4km/h)
Project 3: DOPPELGANGER d2 Visceral
Project 5 Specialized Epic20s2p (83.5v 10ah Lipo), 30kg,HS3540 sensored (MethTek), 12FET lyen @ 50A
rui_fujino
Postby maxwell65 » Sun Jul 17, 2011 7:11 pm
eugenem wrote:I'm a little confused. Which version of CA will work with my setup? The stand alone or direct plugin? I assume all that's required is to plug it into the controller, am I correct?
hi,
the CA does not work properly with the new sensorless controllers (unless there is a fix i do not know about),,,clytes new APM's do work and give you speedometer without having a magnet sensor on the wheel,,,plus a host of other functions,,,,i will have stock of these on my next shipment to be arranged this week,,,so figure 1.5 to 2 months.
Here is what the apm will allow you to do:
Display Speed / without magnetic sensor on the wheel even on
the sensorless controllers!
Display Voltage
Set the PAS and Cruise
you can adjust 9 speed settings from low to high.
Adjust the low voltage cut off / LVC
Adjust the current,,,you can adjust the amps and the volts.
maxwell65
Postby bonzo » Mon Jul 18, 2011 9:32 am
The APM misses the MOST important function......AH used!
On the plus side of the new motors, my Dad's HT3540 SMOKES my x5305 at 45 amps vs my 65amps, in accel and top speed.
I weigh 200lbs, and his bike took me to 47MPH. Both bikes are running 24s headway 16Ah. (79-80 volts avg)
bonzo
Postby oatnet » Mon Jul 18, 2011 9:43 am
bonzo wrote:The APM misses the MOST important function......AH used!
Ah is not so useful, because it does not take into account voltage drop from load or DOD - that is why we use WH. AH x V = WH.
-JD
Member 117 of 16,xxx
179v VW Camper © 164v Vectrix E-Moto © 72v Norco A-line/x5403 © 60v Specialized Enduro Comp/BMC © 72v x5tracycle © 48v TF IO/BMC © 36v Kepler Friction Drive © Spot-Welding a123 © Pelican Front Packs © Vectrix Battery Replacement © MORE !!
Image大鸡巴 Motors
Knowledge is acquired through experience, everything else is just information - Albert Einstein
"Cheater?" I'm not competing, I'm Commuting!
oatnet
Postby bonzo » Thu Jul 21, 2011 10:43 am
You cant have WH without AH....(AH X V)
bonzo
Postby oatnet » Thu Jul 21, 2011 12:44 pm
bonzo wrote:You cant have WH without AH....(AH X V)
Yes, AH is part of the WH calculation I enumerated in my post. You also can't have WH without Volts. Independantly, neither AH nor V is useful as a measure of current.
-JD
Image大鸡巴 Motors
oatnet
PreviousNext
Return to Items for Sale - New
Who is online
Users browsing this forum: No registered users and 5 guests
