Shipping price: ( see grid below)
go to page 21 for the last updated desing REV 5
http://www.endless-sphere.com/forums/viewtopic.php?f=31&t=29129&start=300
LIMITED QUANTITY OF THE DOC'S ULTIMATE TORQUE ARM !!
Very simple and versatile torque arm.
Dual torque arms set
You pay 32$ and you get 2 torques arms (One for the left side and one for the right side with the leg for the derailleur.
Can be glued or welded or fixed with screw.
Precision Laser cutted quality steel.
Match perfectly the shape of the 10mm axel of X5, 9c, HS and HT and many popular hub motors
3/8" thick ( .375mil) (9.525mm) ( Your axel will twist BEFORE they break!!)
The Steel is DOMEX 100 ( Weather Resistant Extra High Strenght) : http://www.beauroc.com/uploads/DOMEX_100W.pdf
The disk diameter is 2.000"
NO MORE FEAR ABOUT USING REGEN !!!
Include the M10 x 1.0 Threaded hole to install your rear derailleur
I use one set of each on all my ebikes ( one is welded, one is glued with DP420 epoxy (the one that towed a schoolbus! ).. so imagine the toruqe applied! and a last one fixed with screw. They all work really perfect!!..
32$ per set + shipping (I include the drilling job and threading job for the rear pivot of derailleur M10 thread ( not shown on the picture)
( note that on these following pictures this is the 3/8 AND the 1/2" thick that are shown AND ARE THE OLDER GEN)
