Doc's ULTIMATE TORQUE ARMS fit most of the frame UPDATE 2013
Re: Doc's ULTIMATE TORQUE ARMS will fit most of the frame UP
Postby hjns » Fri Feb 10, 2012 9:26 am
Hi Doc,
Any ideas how to attach these TAs to a front fork in a 2WD setup? BTW, there is no room on the insides of the dropouts.
If you know a good way, I would be jumping to get 2 of them from you.
Thanks!
Henk
High speed commuter w/ modified Lyen 18 FET 4110, 12AWG traces, extra Caps, beefed up shunt, modified Cromotor w/ thermistor, 10AWG phase wires. CAv3B22 with power-throttle limited to 8kW and 130oC motor winding temp, w/ GPS-enabled CA analogger. 20S 13.5Ah Lipo Zippy pack. Fusion FS frame, Fox RL rear shock, Fox F100 front fork, Schwalbe Fat Bob tires, HALO SAS 26inch rims with custom 12G(r) and 14G(f) black Sepim spokes from JRH and laced myself.
Commuter Cromotor build
hjns
Postby Doctorbass » Fri Feb 10, 2012 9:57 am
hjns wrote:Hi Doc,
Thanks!
Hello,
I see the space you have between the lower part of the tube of the fork and the dropout hole.
It seem to have around 1cm distance wich seem to be of to hold great torque of the axel.
I would suggest to gring the torque arm a bit to allot the lower part of the tube. so you could put them outside .
So with one on each side it should be ok.
Use the DP420 epoxy and the procedure i suggested in the thread and that will do the job
Doc
Ta to fork.JPG (7.53 KiB) Viewed 407 times
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby hjns » Fri Feb 10, 2012 10:07 am
Hi Doc,
OK, send me two, and I will give it a try.
PM sent.
Henk
hjns
Postby cwah » Fri Feb 10, 2012 10:09 am
What tool would you use to grind the torque?
And how can you buy DP420 in the UK?
Find out best events to do in London: http://www.whatonlondon.co.uk/
cwah
Postby Doctorbass » Fri Feb 10, 2012 12:29 pm
cwah wrote:What tool would you use to grind the torque?
Many Many hits with the DP420 search words on the forum.. it was discussed many times.. do a little search :wink:
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby migueralliart » Fri Feb 10, 2012 12:37 pm
Doc
Doc how much for 1 set shipped to 33409 USA the thinnest one ...
migueralliart
Postby dimpirate » Fri Feb 10, 2012 12:41 pm
Hey doc or anyone else with advice Got your torque arms, with my setup I have do put TA' s on inside of dropouts. Swing arm is aluminum 135 mm. To add both arms inside I need to widen to 155 mm. Last night I used a car jack and widened to 170 mm, I'm leaving it with the jack till I get back home tonight, hopefully it will widen a bit to make install easier, I'd like to put TA with hub motor on to assure correct alignment.
My question is has anyone done this on aluminum, and how bad this is on the welds? I only went as far as I could with just my fingers (not pushing it much)
dimpirate
Postby Doctorbass » Fri Feb 10, 2012 12:54 pm
dimpirate wrote:Hey doc or anyone else with advice Got your torque arms, with my setup I have do put TA' s on inside of dropouts. Swing arm is aluminum 135 mm. To add both arms inside I need to widen to 155 mm. Last night I used a car jack and widened to 170 mm, I'm leaving it with the jack till I get back home tonight, hopefully it will widen a bit to make install easier, I'd like to put TA with hub motor on to assure correct alignment.
I did the exact same thing with the car jack for my mongoose and giant.
To protect the weld from craking, i just protected the swing arm from bendind from the weld and reported the bending few cm after by holding the swing arm width the same with a metal quick grip tool so by this way, the weld dont force and it's more the arm that force and bend few cm further.
. believe me.. in french it would be easyer to explain... :lol:
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby Doctorbass » Fri Feb 10, 2012 3:07 pm
Update.. 10 feb 2012
new batch of 50 sets in process next week
Expected delivery 20 feb 2012. ( the special Steel material take some time to arrive at the shop)
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby migueralliart » Fri Feb 10, 2012 4:22 pm
I call dibs on a set!! Please let me know when you get em or if I can pay for it already even better.
migueralliart
Postby rojitor » Fri Feb 10, 2012 4:27 pm
wojtek has dp410 for sale,just for your consideration.
rojitor
Postby Doctorbass » Fri Feb 10, 2012 5:21 pm
yeah. that's a great thing :wink:
Dont forget that the work time is 10 minuite with the 410 and 20 minute for the 420.
ALSO.. remember: Work time IS NOT CURING TIME.. curing time at ambient is like 1-2 day and at 100 celsius it's 1h and at 60 celsius it's 2h
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby lazarus2405 » Mon Feb 13, 2012 8:54 am
I didn't find the search term "paint" anywhere in this thread, and I had a thought: If you epoxied these plates to a painted dropout, wouldn't the weak point be the bond between the paint and the frame? Would you recommend sanding off the paint around the dropout before epoxying?
I don't suppose this would be a problem with anodized frames?
lazarus2405
Postby Doctorbass » Mon Feb 13, 2012 10:27 am
lazarus2405 wrote:I didn't find the search term "paint" anywhere in this thread, and I had a thought: If you epoxied these plates to a painted dropout, wouldn't the weak point be the bond between the paint and the frame? Would you recommend sanding off the paint around the dropout before epoxying?
I strongly recommand sanding or grinding until you reach the pure metal.
If you bond on the paint, yes it will be only the force that attach the paint to the metal.. not so good!
you need a rough surface... anodization is not rough.. i recommand grinding until you reach the aluminum.
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby dimpirate » Wed Feb 15, 2012 11:25 am
So I installed docs TA's last night used dp420 followed docs instructions from this thread, everything worked out great motor axle fits beautifully!
I fu$&ed one thing up though on derailleur side here's a picture
torque arm.jpg (23.96 KiB) Viewed 276 times
Pic is taken close up its about 3mm off... I placed with hub motor on thought I had it in place, couldn't see it though damn :? (TA's inside dropouts)
Like I said alignment is perfect, what do you guys think I should do about this, should I even worry, since most of the axle movement is from side to side. I'll also be using nor lock washers. these are aluminum dropouts...
Would you recommend putting dp420 in gap?
Any suggestions?
Thanks
Fred
dimpirate
Postby Doctorbass » Wed Feb 15, 2012 12:12 pm
dimpirate wrote:So I installed docs TA's last night used dp420 followed docs instructions from this thread, everything worked out great motor axle fits beautifully!
Any suggestions?
Thanks
Fred
Hello Fred,
I see the translation you have in your alingment. no need to fill the gap with epoxy. your axel will sit ok your aluminum dropout and it's on. The torque arm will take the side to side torque no prob :wink: .
The far the axel is from thecenter, the more the torque arm will receive force ( lever effect), but these are so strong that you could have had 10mm off and they would have take the load no prob 8)
I made them overkill to be able to compensate for these kind of error :wink:
enjoy your new build!
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby dimpirate » Wed Feb 15, 2012 12:16 pm
:lol: :D Thanks doc!!! I will be trying them on the road soon!!
dimpirate
Postby monkeychops » Wed Feb 15, 2012 6:51 pm
Hi Doc, and any other readers.
I have a Shimano Derailleur with a hanger bolt like this:
It's not long enough to go through the torque plate and frame. Here is a pic of where i want to put the torque plate:
Basically I think I need a longer bolt, but it's a strange Shimano bolt as you can see, with a thicker section near the head.
Just wondered if anyone had any ideas what to do here?
monkeychops
Postby monkeychops » Thu Feb 16, 2012 6:46 am
Ok, another plan would be to use one of the smaller bolt holes in the frame that are for the rear pannier. As per this pic:
Unfortunately the diameter of these holes is only about 5mm, not 10mm. But I could use a smaller bolt and maybe some sort of sleeve inside the torque plate hole?
Also the torque plate doesn't quite fully overlap with the pannier hole :-(
Grateful for any opinions.
monkeychops
Postby Doctorbass » Thu Feb 23, 2012 10:34 pm
monkeychops wrote:Ok, another plan would be to use one of the smaller bolt holes in the frame that are for the rear pannier. As per this pic:
Maybe it's possible for that kind of interference to just grind the area in conflict?
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby Doctorbass » Thu Feb 23, 2012 10:44 pm
NEW BATCH of 50 set arrived and ready to ship ! :mrgreen:
One set for 25$ include 2 torque arm ( one left and one right for the derailleur)
Here is the dimensions:
39 sets lefts
PM me
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby hjns » Sun Feb 26, 2012 12:55 pm
Doctorbass wrote:NEW BATCH of 50 set arrived and ready to ship ! :mrgreen:
39 sets lefts
PM me
Hi Doc,
They look awesome!
Are mine in the post?
Henk
hjns
Postby migueralliart » Sun Feb 26, 2012 5:03 pm
39 sets lefts
PM me
Hi Doc,
They look awesome!
Hahaha I have the same question...
migueralliart
Re: Doc's ULTIMATE TORQUE ARMS fit most of the frame UPDATE
Postby Doctorbass » Sun Feb 26, 2012 5:50 pm
Yes I sent them friday :wink:
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby DAND214 » Sun Feb 26, 2012 7:28 pm
I got a pair! Great piece.
Wish it would of fit, but the axle was too short.
So now I need to build a swing arm around the plates.
I didn't think Aluminum was as bad as it turned out to be.
I put 1k plus miles with a Cute 128 and 6" disc, I just had to have more!
Mac 8t on 15s LiPo 60 amp 12fet controller, with a 8" disc. Didn't last long. About a block. At least it was a short walk home.
It sure would be nice to know where we are all located, ON THIS WORLD.
Fill in your profile. It doesn't hurt.
I know some worry about being found.
I wish someone would find me.
DAND214
PreviousNext
Return to Items for Sale - New
Who is online
Users browsing this forum: Bazaki, Bing [Bot] and 3 guests
