Doc's ULTIMATE TORQUE ARMS fit most of the frame UPDATE 2013
Re: Doc's ULTIMATE TORQUE ARMS will fit most of the frame UP
Postby Doctorbass » Wed Feb 15, 2012 12:12 pm
dimpirate wrote:So I installed docs TA's last night used dp420 followed docs instructions from this thread, everything worked out great motor axle fits beautifully!
I fu$&ed one thing up though on derailleur side here's a picture
Pic is taken close up its about 3mm off... I placed with hub motor on thought I had it in place, couldn't see it though damn :? (TA's inside dropouts)
Like I said alignment is perfect, what do you guys think I should do about this, should I even worry, since most of the axle movement is from side to side. I'll also be using nor lock washers. these are aluminum dropouts...
Would you recommend putting dp420 in gap?
Any suggestions?
Thanks
Fred
Hello Fred,
I see the translation you have in your alingment. no need to fill the gap with epoxy. your axel will sit ok your aluminum dropout and it's on. The torque arm will take the side to side torque no prob :wink: .
The far the axel is from thecenter, the more the torque arm will receive force ( lever effect), but these are so strong that you could have had 10mm off and they would have take the load no prob 8)
I made them overkill to be able to compensate for these kind of error :wink:
enjoy your new build!
Doc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby dimpirate » Wed Feb 15, 2012 12:16 pm
:lol: :D Thanks doc!!! I will be trying them on the road soon!!
dimpirate
Postby monkeychops » Wed Feb 15, 2012 6:51 pm
Hi Doc, and any other readers.
I have a Shimano Derailleur with a hanger bolt like this:
It's not long enough to go through the torque plate and frame. Here is a pic of where i want to put the torque plate:
Basically I think I need a longer bolt, but it's a strange Shimano bolt as you can see, with a thicker section near the head.
Just wondered if anyone had any ideas what to do here?
monkeychops
Postby monkeychops » Thu Feb 16, 2012 6:46 am
Ok, another plan would be to use one of the smaller bolt holes in the frame that are for the rear pannier. As per this pic:
Unfortunately the diameter of these holes is only about 5mm, not 10mm. But I could use a smaller bolt and maybe some sort of sleeve inside the torque plate hole?
Also the torque plate doesn't quite fully overlap with the pannier hole :-(
Grateful for any opinions.
monkeychops
Postby Doctorbass » Thu Feb 23, 2012 10:34 pm
monkeychops wrote:Ok, another plan would be to use one of the smaller bolt holes in the frame that are for the rear pannier. As per this pic:
Maybe it's possible for that kind of interference to just grind the area in conflict?
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby Doctorbass » Thu Feb 23, 2012 10:44 pm
NEW BATCH of 50 set arrived and ready to ship ! :mrgreen:
One set for 25$ include 2 torque arm ( one left and one right for the derailleur)
Here is the dimensions:
39 sets lefts
PM me
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby hjns » Sun Feb 26, 2012 12:55 pm
Doctorbass wrote:NEW BATCH of 50 set arrived and ready to ship ! :mrgreen:
39 sets lefts
PM me
Hi Doc,
They look awesome!
Are mine in the post?
Henk
High speed commuter w/ modified Lyen 18 FET 4110, 12AWG traces, extra Caps, beefed up shunt, modified Cromotor w/ thermistor, 10AWG phase wires. CAv3B22 with power-throttle limited to 8kW and 130oC motor winding temp, w/ GPS-enabled CA analogger. 20S 13.5Ah Lipo Zippy pack. Fusion FS frame, Fox RL rear shock, Fox F100 front fork, Schwalbe Fat Bob tires, HALO SAS 26inch rims with custom 12G(r) and 14G(f) black Sepim spokes from JRH and laced myself.
Commuter Cromotor build
hjns
Postby migueralliart » Sun Feb 26, 2012 5:03 pm
39 sets lefts
PM me
Hi Doc,
They look awesome!
Hahaha I have the same question...
migueralliart
Re: Doc's ULTIMATE TORQUE ARMS fit most of the frame UPDATE
Postby Doctorbass » Sun Feb 26, 2012 5:50 pm
Yes I sent them friday :wink:
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby DAND214 » Sun Feb 26, 2012 7:28 pm
I got a pair! Great piece.
Wish it would of fit, but the axle was too short.
So now I need to build a swing arm around the plates.
I didn't think Aluminum was as bad as it turned out to be.
I put 1k plus miles with a Cute 128 and 6" disc, I just had to have more!
Mac 8t on 15s LiPo 60 amp 12fet controller, with a 8" disc. Didn't last long. About a block. At least it was a short walk home.
It sure would be nice to know where we are all located, ON THIS WORLD.
Fill in your profile. It doesn't hurt.
I know some worry about being found.
I wish someone would find me.
DAND214
Postby Doctorbass » Sun Feb 26, 2012 10:16 pm
DAND214 wrote:I got a pair! Great piece.
The attachment IMG_0026.jpg is no longer available
Maybe i have a suggestion for you that would save money and make it stronger than before while you'll be able to use the torque arms :wink:
I took few minutes with Windows Paint :lol:
As well i forgot to add the area for the disk brake and upper swing arm lever but it's easy with an 1/8 steel plate and few home tools
Doc
swing arm repair.JPG (32.22 KiB) Viewed 463 times
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby DAND214 » Mon Feb 27, 2012 11:23 am
Thanks Doc!
Great idea.
I wanted to use the plates in a new build, talked to a friend and he wants to build a complete new swing arm from 4130. All I want is to fix it, but he wants it to pass a FAA inspection.
So now I have a bridgeport band saw large drill priss and more to use. And I had it all figured out simple, but sibce I can't see to weld anymore I needed help. Boy did I get help. Let you all know how it comes out.
Doc, I think those things are great!
Dan
DAND214
Postby zombiess » Sat Mar 03, 2012 2:28 pm
Hey Doc, just wanted to let you know I got the second pair. Now these are the perfect dropouts for my new swing arm if I don't have the fabricator use some bar stock and do a clamp style. I use them as dropouts on on my current bike, clearance was snug then some blue loctite on the nuts and now I have no worries.
Greyborg Hub Motor, Lyen 18FET, Customized full suspension kids MTB. Top Speed 61 MPH
9C 8x8, 24S2P LiPo, Lyen 12 FET, Diamondback Recoil Comp. Top Speed 42 MPH
GreyborgUSA Dealer
zombiess
Postby Doctorbass » Sat Mar 03, 2012 7:44 pm
zombiess wrote:Hey Doc, just wanted to let you know I got the second pair. Now these are the perfect dropouts for my new swing arm if I don't have the fabricator use some bar stock and do a clamp style. I use them as dropouts on on my current bike, clearance was snug then some blue loctite on the nuts and now I have no worries.
Perfect! :wink:
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby Doctorbass » Sun Mar 04, 2012 3:33 pm
For those who would like to make some holes i these great STRONG torque arms, just be advised that you will need QUALITY drill bit!.. There is no way a wood drill or cheap brand but will work.
An exemple:
Best is using a pressdrill and quality drill bit.
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby richirich1113 » Mon Mar 05, 2012 9:40 pm
PM sent
! question, I think that i read that the Crystalyte Hs3540 had a smaller axel ? Are these a perfect fit for this hub ?
Can't wait to get some.
Thanks
KHS full suspension - 26x 2.5 Maxxis Hookworms
Avid Elixer 5 Hydraulic 203mm disks front/back
18 FET Lyen controller / HS 3540
21s - 10ah lithium ion polymer
richirich1113
Postby cwah » Tue Mar 06, 2012 7:13 pm
Find out best events to do in London: http://www.whatonlondon.co.uk/
cwah
Postby Xanda2260 » Wed Mar 07, 2012 4:43 pm
monkeychops wrote:Hi Doc, and any other readers.
Dont know if you've solved this, but I had the same issue setting up myntrikes deraileur with these arms. If you mount the deraileur to the torque arm ( wont go through the frame), you can then use the deraileur adjustment to get it shifting again, even though its now 10mm further out.
Hope that helps!
Alex
The White Warrior - viewtopic.php?f=6&t=33918
Homebuilt 40mph+ tadpole!
Xanda2260
Postby whereswally606 » Mon Mar 12, 2012 12:33 pm
thought id post up some videos which include Dr bass Torque arms. this was my install and working bike, hopefully not too boring for peeps and its a way i can log my progress of the bike.
installation part 1
installation part 2
working bike, bench testing. lots of ideas coming together
sorry to hijack your thread Dr Bass, but thought people might benefit from seeing a UK installation.
regards Andy
Buy a 400W 12Volt 32a server supply fitted to connect typical 4mm bullet plugs £25.30 to the UK, will ship WW. IM me for details
Ebikes: Scott Ransom & Magie Pie 48V limno2,Norco Team Race & Hub motor 12s4p lico zippy 40C
Norco Savage to receive an 80/100 motor with opticals Not halls Thanks Burtie.
Car: Honda Insight gen 1 hybrid
whereswally606
Postby Doctorbass » Mon Mar 12, 2012 2:55 pm
cwah wrote:Does the epoxy DP460 works too?
http://www.ebay.com/itm/3M-Scotch-Weld- ... _500wt_814
Yes, pretty well.
really similar strengh as the 420, but the 460 have 60 minute work life and is optimized for magnet bonding.
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby migueralliart » Sat Mar 17, 2012 7:36 pm
Doc how long these arms take to get to the US once you ship them? I paid for my set on feb 23rd and have not received mine.
migueralliart
Postby Doctorbass » Sun Mar 18, 2012 1:22 pm
migueralliart wrote:Doc how long these arms take to get to the US once you ship them? I paid for my set on feb 23rd and have not received mine.
Hello Mike,
According to my records, i shipped yours in the same batch as 5 others during the same week.
I'm sorry that you did not received them, and i guess they was maybe lost in the mail or that i could have made a mistake and have sent them to another member adress.
No worrie, I will ship you another set right on monday. :wink:
I apologize for the inconvenience.
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby richirich1113 » Fri Mar 23, 2012 11:29 am
Here are some pic's with DRBASS torque arms. Thanks Doc these things are awsome!
And yes, I had to dremel the screw heads on the HS3540 to get the new Avid elixer 5 203mm rotors to not rub the caliper.(i need to touch up the grinds alittle)
Here is a link to a great place to get the DP420.
http://www.jdindustrialsupply.com/dp420.html
richirich1113
Postby cwah » Fri Mar 23, 2012 11:50 am
Hello Doc,
Looking for 2 torques arms for my brompton fork. I think I sent you a pm a week ago. Is it ok?
cwah
Postby Doctorbass » Fri Mar 23, 2012 12:54 pm
Thanks for the review rich! :wink:
The picture you showed give a real taste of how easy they can be mounted including the right side with the derailleur threaded hole that you seem to have used perfectly
excellent job! :wink:
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
PreviousNext
Return to Items for Sale - New
Who is online
Users browsing this forum: stevetooke and 5 guests
