Doc's ULTIMATE TORQUE ARMS fit most of the frame UPDATE 2013
Re: Doc's ULTIMATE TORQUE ARMS fit most of the frame UPDATE
Postby richirich1113 » Mon Mar 05, 2012 9:40 pm
PM sent
! question, I think that i read that the Crystalyte Hs3540 had a smaller axel ? Are these a perfect fit for this hub ?
Can't wait to get some.
Thanks
KHS full suspension - 26x 2.5 Maxxis Hookworms
Avid Elixer 5 Hydraulic 203mm disks front/back
18 FET Lyen controller / HS 3540
21s - 10ah lithium ion polymer
richirich1113
Postby cwah » Tue Mar 06, 2012 7:13 pm
Find out best events to do in London: http://www.whatonlondon.co.uk/
cwah
Re: Doc's ULTIMATE TORQUE ARMS will fit most of the frame UP
Postby Xanda2260 » Wed Mar 07, 2012 4:43 pm
monkeychops wrote:Hi Doc, and any other readers.
I have a Shimano Derailleur with a hanger bolt like this:
It's not long enough to go through the torque plate and frame. Here is a pic of where i want to put the torque plate:
Basically I think I need a longer bolt, but it's a strange Shimano bolt as you can see, with a thicker section near the head.
Just wondered if anyone had any ideas what to do here?
Dont know if you've solved this, but I had the same issue setting up myntrikes deraileur with these arms. If you mount the deraileur to the torque arm ( wont go through the frame), you can then use the deraileur adjustment to get it shifting again, even though its now 10mm further out.
Hope that helps!
Alex
The White Warrior - viewtopic.php?f=6&t=33918
Homebuilt 40mph+ tadpole!
Xanda2260
Postby whereswally606 » Mon Mar 12, 2012 12:33 pm
thought id post up some videos which include Dr bass Torque arms. this was my install and working bike, hopefully not too boring for peeps and its a way i can log my progress of the bike.
installation part 1
installation part 2
working bike, bench testing. lots of ideas coming together
sorry to hijack your thread Dr Bass, but thought people might benefit from seeing a UK installation.
regards Andy
Buy a 400W 12Volt 32a server supply fitted to connect typical 4mm bullet plugs £25.30 to the UK, will ship WW. IM me for details
Ebikes: Scott Ransom & Magie Pie 48V limno2,Norco Team Race & Hub motor 12s4p lico zippy 40C
Norco Savage to receive an 80/100 motor with opticals Not halls Thanks Burtie.
Car: Honda Insight gen 1 hybrid
whereswally606
Postby Doctorbass » Mon Mar 12, 2012 2:55 pm
cwah wrote:Does the epoxy DP460 works too?
http://www.ebay.com/itm/3M-Scotch-Weld- ... _500wt_814
Yes, pretty well.
really similar strengh as the 420, but the 460 have 60 minute work life and is optimized for magnet bonding.
Doc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby migueralliart » Sat Mar 17, 2012 7:36 pm
Doc how long these arms take to get to the US once you ship them? I paid for my set on feb 23rd and have not received mine.
migueralliart
Postby Doctorbass » Sun Mar 18, 2012 1:22 pm
migueralliart wrote:Doc how long these arms take to get to the US once you ship them? I paid for my set on feb 23rd and have not received mine.
Hello Mike,
According to my records, i shipped yours in the same batch as 5 others during the same week.
I'm sorry that you did not received them, and i guess they was maybe lost in the mail or that i could have made a mistake and have sent them to another member adress.
No worrie, I will ship you another set right on monday. :wink:
I apologize for the inconvenience.
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby richirich1113 » Fri Mar 23, 2012 11:29 am
Here are some pic's with DRBASS torque arms. Thanks Doc these things are awsome!
And yes, I had to dremel the screw heads on the HS3540 to get the new Avid elixer 5 203mm rotors to not rub the caliper.(i need to touch up the grinds alittle)
Here is a link to a great place to get the DP420.
http://www.jdindustrialsupply.com/dp420.html
richirich1113
Postby cwah » Fri Mar 23, 2012 11:50 am
Hello Doc,
Looking for 2 torques arms for my brompton fork. I think I sent you a pm a week ago. Is it ok?
cwah
Postby Doctorbass » Fri Mar 23, 2012 12:54 pm
Thanks for the review rich! :wink:
The picture you showed give a real taste of how easy they can be mounted including the right side with the derailleur threaded hole that you seem to have used perfectly
excellent job! :wink:
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby Doctorbass » Fri Mar 23, 2012 12:57 pm
cwah wrote:Hello Doc,
Hi,
I'm sorry that i did not replied to your request,
Please let me correct that, i'll sent you a PM for your T-A request no prob! :wink:
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby Beachcruzer » Sun Mar 25, 2012 1:42 am
Anybody install these on a Specialized Big Hit FSR? If so, how did it work out? Would prefer not to grind a lot of metal.
Beachcruzer
Postby migueralliart » Wed Mar 28, 2012 12:17 pm
Hello Mike,
Doc
Doc,
Either you have the wrong address(or never had the address) or someone is stealing my mail (which I seriously doubt because everything that comes from Canada required a signature from me to pick it up) I have not received anything.
Info on the payment
Transaction ID # 1D655122T47006255
It's been a month already.
migueralliart
Postby Doctorbass » Wed Mar 28, 2012 1:28 pm
Hello Mike,
Doc
Doc,
Info on the payment
I have your adress and sent you a Pm anout that. i am sorry for the delay and i'm sure we can find a solution.
What is strange is that you said that you sent us payment ( to me and Method) for buying from us but that you not provided your adress? I just want to knwo why ? I did received your payment YES, and i have your adress in my record ( i sent you a Pm to you to doublecheck if it is ok)
you provided me your zip code for the shipping calculation too.
It is NOT everything from Canada that require a signature. I send them in an enveloppe so it's fast, cheap and air shipped as well. If i want a siganture i must charge extra shipping fee.
Please comeback to me by PM to verify if your adress is ok or not.
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby Doctorbass » Wed Mar 28, 2012 1:40 pm
Migueralliart, you pm'd me to say the adress i sent your set is the right adress, thanks. In the same shipment run i sent T-A to 5 different adress and yours was in that batch.
I dont know what happened :|
Anyway i will send you another set on my charge
But please at least doublecheck that you provide us your adress if you want us ( methods and me) to ship you something :wink:
I have 4 others T-A set to ship tommorow and i'll sent you another set at the same time.
Even if you receive the second set of T-A that is late, Pm me
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby migueralliart » Wed Mar 28, 2012 2:06 pm
Doctorbass wrote:But please at least doublecheck that you provide us your adress if you want us ( methods and me) to ship you something :wink: [/b]
Doc
I provided the address to both ... nevermind now. All is good - refunded.
migueralliart
Postby Doctorbass » Wed Mar 28, 2012 2:12 pm
Doc
I sent twice them a set of T-A to your verified adress on paypal and you said you never received them.
I COPY the exact adress paypal have or the adress you provide and PASTE it on the label of the enveloppe containing the T-A so this is impossible that the adress is wrong unless the one people or paypal provide me is wrong.
I have issue a refund ( Date : 28 mar 2012 Hour: 12:05:56 PDT ) due to too much complication sending from Canada to your adress. This is sad but this is teh most profitable way now for us.
I have sent you T-A the exact same way as i sent dozens of T-A from now and that was received fine..
Anyway.. problem solved, no more time to loose with that for both of us.
I have lost two T-A set due to mailing service and you got refunded :wink:
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby Spacey » Wed Mar 28, 2012 2:19 pm
Just for the record I got mine in UK and love them, so easy to install.
Spacey
Postby migueralliart » Wed Mar 28, 2012 2:22 pm
Spacey wrote:Just for the record I got mine in UK and love them, so easy to install.
I agree I got nothing against the T-A I know they are of excellent quality and would've loved to get em but the paypal transaction was getting near the 45 day limit so I had to act I couldn't wait another week. I even have the 3m epoxy that I order originally.
KUDOS to doctorbass cause I know it wasn't his fault and his T-A kick @ss.
migueralliart
Postby hjns » Wed Mar 28, 2012 11:53 pm
For the record, mine arrived safe and sound in Switzerland. Very happy, but still need to install them. :mrgreen:
They look and feel awesome!
Henk
High speed commuter w/ modified Lyen 18 FET 4110, 12AWG traces, extra Caps, beefed up shunt, modified Cromotor w/ thermistor, 10AWG phase wires. CAv3B22 with power-throttle limited to 8kW and 130oC motor winding temp, w/ GPS-enabled CA analogger. 20S 13.5Ah Lipo Zippy pack. Fusion FS frame, Fox RL rear shock, Fox F100 front fork, Schwalbe Fat Bob tires, HALO SAS 26inch rims with custom 12G(r) and 14G(f) black Sepim spokes from JRH and laced myself.
Commuter Cromotor build
hjns
Postby Doctorbass » Thu Mar 29, 2012 12:25 am
Thanks for the feedback guys :wink:
I still have couple left from the last batch that are ready to go for those who are interested in a super strong dropout for super powerfull hub motor 8)
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby Doctorbass » Thu Mar 29, 2012 12:43 am
4 more T-A set ready to ship tomorrow :wink:
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby cwah » Thu Mar 29, 2012 8:51 am
Doc, could you remove my full name or address from the picture on public forum please?
Thanks a lot.
cwah
Postby Doctorbass » Thu Mar 29, 2012 9:02 am
cwah wrote:Doc, could you remove my full name or address from the picture on public forum please?
Thanks a lot.
Done
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby cwah » Thu Mar 29, 2012 9:04 am
thanks doc. Sorry to be a bit anal about privacy :lol:
cwah
PreviousNext
Return to Items for Sale - New
Who is online
Users browsing this forum: NeilP and 6 guests
