Doc's ULTIMATE TORQUE ARMS fit most of the frame UPDATE 2013
Re: Doc's ULTIMATE TORQUE ARMS fit most of the frame UPDATE
Postby Kin » Fri Jul 13, 2012 12:02 pm
cwah wrote:I'd like to reduce the size of the torque arm. I tried to cut them with a hacksaw but it's like doing nothing.
Any idea how to do cut them?
To be clear, why try to reduce it? If you're overhanging the edges of your dropout, you could just leave it overhanging. It's going to be a pita to cut. Is your hacksaw fresh and with the metal-cutting profile? You might get luck with some diamond dremel cutters (amazon has some cheap third party sellers) and running water, or a few of the ceramic disks (36 pack is like $6). Also, if you're obstruction is something barely obstructing, for my personally made torque arm I had .06 inches overlap with the wider weld on one of the sides, well, rather than cutting .06 inches off, I just beveled away with a grinder the amount that my torque arm stuck over the weld. (So I beveled a little .06" base triangle that cleared the weld.)
New to endless-sphere? Notice a lot of signatures recommending Ebike.ca? That's because it's the best place for a quality and manageable, (but still 'real'), first build. Justin is a solid supporter of electric bike development, and a good source of equipment.
My hat off a thousand times to the green people that effectively run this forum. The ES Mods are superb.
Kin
Postby Doctorbass » Fri Jul 13, 2012 5:26 pm
Just to let you all know once again, This metal is the same as the one used to make some cutting tools... so to cut it you must have great special tools or...alot of patience...... or.. a laser or waterjet cutter :wink:
The cheapest way is using a grinder...
Doc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby Kin » Fri Jul 13, 2012 5:54 pm
Yes! Very true. I probably shouldn't have suggesting making sure the hacksaw had the right profile.
But that's why dremel disks rule :). It's diamond bit disks and ceramic disks are just grinding away a thin groove. I would really dislike grinding any serious amount from something tiny like the torque arm.
Kin
Postby cwah » Fri Jul 13, 2012 7:01 pm
Thanks Guys, this torque arm makes me think about my Kryptonite U lock. So tough! lol
But an angle grinder should be able to cut it. Going to get one.
Find out best events to do in London: http://www.whatonlondon.co.uk/
cwah
Postby Doctorbass » Thu Jul 19, 2012 11:50 pm
Hello Guys,
Please, dont delay all your great project to wait for the next batch. I'm really busy these days and the vacancy coming so my load is high and i might delay the T-A few more weeks.
Like i said, i never expected that they become so popular and to sale so many of them... it appear i'm victim of their succes :lol:
Preparing all them and managing and making follow up on all sales around the world is taking time for me and i dont have alot time now and summer is already at the second half..
ill inform you all once i have more free time to manage that.
I hope you understand guys and i dont want to disappoint you all.
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby tedcs » Sat Jul 21, 2012 10:08 am
Very nice piece of work :!:
Everything I know is wrøng.
tedcs
Postby Emoto » Sun Jul 22, 2012 10:27 am
Doctorbass wrote:Hello Guys,
Doc
Hi doc
Well looks like ill have to make my own then, if i start with mild steel will they be hard enough if i heat them with a blow torch then dip in oil, for a cromotor
Just a quick flight http://vimeo.com/30385026
Emoto
Postby sardini » Thu Aug 02, 2012 11:49 pm
Doc take your time
but sooner or later i will need some of this babes for my new HS4080 rear wheel motor
sardini
Postby Mad » Sat Aug 04, 2012 11:41 am
Count me in for 2 sets when ever you can
Thanks in advance
Mad
Postby 2fat » Sun Aug 12, 2012 11:39 am
Hi doc
Well looks like i need 1set with a DP420 epoxy for GT bike, i live in singapore, can you shipping it
Tell me the shipping price ? useing by USPS and email at :- hussin.syed@yahoo.com ....PLS
i pay by paypal
Thanks ...need reply back
Hi doc
i send PM ...Pls reply back ....PLS
2fat
Postby whereswally606 » Sun Aug 12, 2012 12:53 pm
Doc, I have a couple of your torque plates on my norco. I used henkel airplane metal epoxy with a similar shear strength to your dp420. Anyway I also drilled a hole in each one and bolted them to the alu frame on the inside. They work amazingly but drilling the hole was a nightmare. I was wondering whether you might alter the design so that they have a hole drilled for a single bolt like an M4 / M5? I killed a drill and several drill bits last time
Buy a 400W 12Volt 32a server supply fitted to connect typical 4mm bullet plugs £25.30 to the UK, will ship WW. IM me for details
Ebikes: Scott Ransom & Magie Pie 48V limno2,Norco Team Race & Hub motor 12s4p lico zippy 40C
Norco Savage to receive an 80/100 motor with opticals Not halls Thanks Burtie.
Car: Honda Insight gen 1 hybrid
whereswally606
Postby Doctorbass » Sun Aug 12, 2012 1:07 pm
whereswally606 wrote:Doc, I have a couple of your torque plates on my norco. I used henkel airplane metal epoxy with a similar shear strength to your dp420. Anyway I also drilled a hole in each one and bolted them to the alu frame on the inside. They work amazingly but drilling the hole was a nightmare. I was wondering whether you might alter the design so that they have a hole drilled for a single bolt like an M4 / M5? I killed a drill and several drill bits last time
Hi,
It is normal that you killed some drill bit since the metal of these torque arms is domex wich is similar to the one used in the tools... and normal quality drill bit !
No prob to drill holes but they must not be too close to the corner of the axel slot. preferably closer to the external diameter.
DOc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby Doctorbass » Sun Aug 12, 2012 1:08 pm
2fat wrote:Hi doc
i pay by paypal
Please PM me :wink:
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby hjns » Wed Aug 15, 2012 1:52 am
Doctorbass wrote:It is normal that you killed some drill bit since the metal of these torque arms is domex wich is similar to the one used in the tools... and normal quality drill bit !
I drilled two M5 holes into DrBass' TAs and then threaded them M6. No problem, as long as you use the right tools. I used a vertical press drill with cobalt - steel drill bits. I took one of the axle washers and positioned it where the axle would be. Then drew a circle around it. I positioned the drill in such a way that the holes are 1mm out of the circle to make sure the bolts would not interfere with the washers. When drilling, I cooled using some cheap ATF mineral oil.
Henk
High speed commuter w/ modified Lyen 18 FET 4110, 12AWG traces, extra Caps, beefed up shunt, modified Cromotor w/ thermistor, 10AWG phase wires. CAv3B22 with power-throttle limited to 8kW and 130oC motor winding temp, w/ GPS-enabled CA analogger. 20S 13.5Ah Lipo Zippy pack. Fusion FS frame, Fox RL rear shock, Fox F100 front fork, Schwalbe Fat Bob tires, HALO SAS 26inch rims with custom 12G(r) and 14G(f) black Sepim spokes from JRH and laced myself.
Commuter Cromotor build
hjns
Postby 2fat » Thu Aug 16, 2012 4:19 pm
Hi Doc
how to order a Dual troque arms set
Pay 25$ and you get 2 torques arms (One for the left side and one for the right side with the leg for the derailleur.
from you
I live in singapore ,I will pay you by paypal
Send me the cost or the price ?
This is my email :- hussin.syed@yahoo.com
Thanks .....Pls reply back to me at hussin.syed@yahoo.com
2fat
Postby whereswally606 » Fri Aug 17, 2012 4:56 am
Sure Henk, i know it is possible to do it given the right gear, I was in a bind of wanting to get out riding and not having the money to get a proper drill. So i was wondering whether a couple of variant designs incorporating m5 holes would open a great market for our good doctor here. Don't mean to add complication just its easier to use a common drill and bit with the torque arm as a guide to drill through the alu than it is to go through the torque plate itself.
will use a proper cobalt bit next time and a better drill press. Seriously though Doc a couple of water jetted holes to help us make these even easier to fit. Thanks
whereswally606
Postby Kin » Fri Aug 17, 2012 8:15 am
Water jetting holes might not be possible. (At least with the water cutters I've seen, not all I assume there's some mega-awesome one that compensates for this:) There's a splotch when the jet starts cutting into metal, and then it cuts clean from that initial point. Maybe they could put the splot in the very middle of the hole and then make the hole, but I'm not sure. Same thing with lasercutters. But a CNC machine with a carbide bit and the right settings could for certain drill the hole. But doing so would take time, another few minutes and so another few dollars. And if you had to start on a CNC drilling machine and then move to a waterjet machine you'd have to make certain the material was perfectly centered.
Kin
Postby teklektik » Fri Aug 17, 2012 9:57 am
More importantly, there's the question of where to put the hole so that it will never collide with a needed hole for a particular frame. Sometimes less is more.
teklektik
Postby General Lee » Sat Sep 08, 2012 2:39 pm
I did not thrust the "only glue way". So i made my one TA´s especially for my bike. I designed it with a metal plate to screw and glue it to the frame. For this i used the screw hole for the changeable dropout and the screw holes for the brakes. Because i used the screw holes for the brakes i had to push the axle mount position 1,75 cm further back. This way i got place to fit the new holes to mount the brake. Also i got more space between the rear swing and the tire in front. Now i can mount a bigger wheel :wink:
Maybe this helps someone as an idea if you don´t thrust 100% to the "only glue way".
Here i got some pics of it.
http://www.facebook.com/photo.php?fbid= ... =1&theater
Bike: Commencial Supreme Mini DH 6.1
Battery: 72V/20AH LiFePo4
Motor System: Phoenix II Cruiser 7240
Rim: 26" Surly Large Marge DH 60mm
Tyre: Kenda Downhill 2.5
V-Max: 75km/h (APM)
General Lee
10 µW
10 µW
Postby Doctorbass » Sat Sep 08, 2012 4:40 pm
General Lee wrote:I did not thrust the "only glue way". So i made my one TA´s especially for my bike. I designed it with a metal plate to screw and glue it to the frame. For this i used the screw hole for the changeable dropout and the screw holes for the brakes. Because i used the screw holes for the brakes i had to push the axle mount position 1,75 cm further back. This way i got place to fit the new holes to mount the brake. Also i got more space between the rear swing and the tire in front. Now i can mount a bigger wheel :wink:
Just a reminder that the T-A i'm offering are not what you call "only glue way".... they can be bolted also or welded.. they are made of a steel that is PERFECT for weld.
but if done correctly, the "only glue way". work like a charm at ANY POWER! :wink:
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby Bazaki » Sat Sep 08, 2012 5:29 pm
For how many years will this dp420 hold ? Can we trust it for 10 years ?
http://www.elektrischeMTB.nl/
Ebike parts and more
Bazaki
Postby usa_electrophile » Sat Sep 08, 2012 11:21 pm
i'll take two pair
2011 Zero S Electric Moto - purchase from Hollywood Electrics
$450 build 27 MPH ebike, $300 kit on ebay, $100 SLA, $30 used dual suspension NEXT low end bike, +$20 Bell cruiser susp seat
2005 Specialized Demo Pro 8,titanium springs,Chris King Hub,..etc begging for mid-drive motor
Ego Cycle 2 Classic scooter
usa_electrophile
Location: around 20 miles East of Saint Louis Missouri (not east St Louis.. thankfully =)
Postby Doctorbass » Sun Sep 09, 2012 12:05 am
Bazaki wrote:For how many years will this dp420 hold ? Can we trust it for 10 years ?
It's aerospace grade epoxy.. i doubt that the stuff they send in the space would be limited tp 10 years life and some piceces would fly apart in the deep space after that :wink:
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby Bazaki » Sun Sep 09, 2012 5:14 pm
Ok I see :)
Bazaki
Postby ejonesss » Tue Sep 11, 2012 6:50 pm
Doctorbass in a future version it would be nice to have holes where a mending plate could be attached to connect to the frame
http://images.orgill.com/200x200/7572688.jpg
to be attached like http://www.e-bikekit.com/shop/images/pr ... ary/90.jpg
so no glue is required because many of todays bikes are aluminum not steel and could break easier.
stuff for Even Newer 4 to 24-cell Battery Management System (BMS)
32 lifepo4 cells 16s2p 40138 green cells √
16s2p 40138 based pack built assembled (building electrical equiv to $2000 eonyx system.*
ejonesss
PreviousNext
Return to Items for Sale - New
Who is online
Users browsing this forum: No registered users and 3 guests
