ebike frame
Re: E-bike frame! MUST BE SEEN! FULL FRAME UPDATE 8
Postby oatnet » Mon Nov 21, 2011 11:11 am
es2150 wrote:Can someone give range on a 60v 30ah battery in the proposed 24in. Wheel
Which battery chemistry (or IR?)
Which motor?
What Speed?
What incline?
What headwind?
What rolling resistance on your tires?
Drag Coefficient in your preferred seating position?
How aggressive are you on the throttle?
Answer those - none of which are dependant on the frame or size of the wheel - and you can estimate range with accuracy. If it is 30ah Pb, then you can only discharge 50%, but LiFePO4 80%, so right now we don'e even know how many watt hours you get out of the pack. Assuming Lithium to 80% DOD, the pack has 1800wh and you get 1440 usable. I ballpark 40whm for my duty cycle with hubbies, so I'd get about 36 miles from such a pack.
YMMV, but the frame and wheel diameter are not significant variables in calculating range.
-JD
Member 117 of 16,xxx
179v VW Camper © 164v Vectrix E-Moto © 72v Norco A-line/x5403 © 60v Specialized Enduro Comp/BMC © 72v x5tracycle © 48v TF IO/BMC © 36v Kepler Friction Drive © Spot-Welding a123 © Pelican Front Packs © Vectrix Battery Replacement © MORE !!
Image大鸡巴 Motors
Knowledge is acquired through experience, everything else is just information - Albert Einstein
"Cheater?" I'm not competing, I'm Commuting!
oatnet
Postby Evoforce » Mon Nov 21, 2011 5:37 pm
Max, I would be interested, but not without a full suspension. Am I wrong, or does this frame have rear suspension?
"Energy is all consuming and it is never ending. It just changes form as it morphs through time and space... " Evoforce
        Several 5403 motors,  no time to build projects! Phoenix Racer(5303) crystalyte suspension mtn bike LiFepo4 72/20.  (409) crystalyte 48 volt hardtail.  In process... Phoenix Cruiser(5304)  LiFePo4 48/20.  First electric bike a 2009 XB 502-700 style, 36/20 sla scooter bike.  All charged by solar!
Evoforce
Postby Ypedal » Tue Jan 24, 2012 10:48 am
Any recent udpates on this ?... been a while..
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Postby nicobie » Fri Jan 27, 2012 2:52 pm
It seems like it would be a lot less trouble to just import some of these frames direct from China. They seem to have everything we are looking for. Seeing as they are already in production, they might be cheap.
viewtopic.php?f=6&t=34672
http://strongbicycle.en.alibaba.com/pro ... _bike.html
May your tote always stay tight and your edge eversharp :wink:
my eTownie build thread: viewtopic.php?f=6&t=23701
nicobie
Postby teklektik » Fri Jan 27, 2012 3:04 pm
:idea: !
teklektik
Re: E-bike frame! NOW TAKING ORDERS!
Postby maxwell65 » Sun Jan 29, 2012 8:40 pm
lets make this happen,,,we worked very hard on this design,,,dont send deposits,,,simply email me at maxwellsmart8686@hotmail.com and say you want to be put on the ebike order list,
DO IT NOW BEFORE THE WORLD ENDS!
maxwell65
Re: E-bike frame!NEW DESIGN, NOW TAKING ORDERS!
Postby Willow » Mon Jan 30, 2012 10:33 pm
Maxwell...
I see some impracticalities with your battery arrangements. You have shown in the images both the Headaways and 'Thundersky' type packs.
The problem being that there is very limited room to work on connecting cells together (especially in the eclosure behind the seat). There is also no detail on how your planning on holding those cells firmly in place, so they don't short out against the frame. There is also no detail on controller mounts or mounting anything else, such as a BMS if your using large format cells. The frame itself is overly complex.
You need to make one of these, ride it, re-design it, and then build another, ride it and tweak it untill it's as good as it can be. Then you will be ready to start marketing them.
Willow
Postby darkshirikens » Tue Feb 07, 2012 4:28 pm
I agree with Willow because of the space required to connect everything also so things don't get shorted and wires don't get pinched allot of things have to be thought out i like the space idea in general so it can accommodate a large battery pack Max i think you have a winner after you work out a few minor details and testing the frame with some popular motors used on here cause some would like to commute with more speed and more torque and maybe more powerful motors question is would the dropouts hold up we wont know without so some real testing
Schwinn Sidewinder Crystalyte 7240 controller, X5305 motor, Headway 72v 12ah 50/100 bms done !!!
Next project on way: Crystalyte Ht rear 3525
darkshirikens
Postby o00scorpion00o » Tue Feb 07, 2012 4:38 pm
I actually noticed the updated pics today, nice one Max!
Really nice looking bike, can't wait to see one in the flesh!
o00scorpion00o
Postby chroot » Tue Feb 07, 2012 5:54 pm
I see you updated pictures in 1st page OP. Look like you got full suspension. FREAKING AWESOME! I like it very much and Please tell me which motor are you going use? In picture, It looked like you are going use MAC geared motor?
Keep it up :D
Thank you Justin Lemire-Elmore - You are a HERO!
Tidalforce, Yuba Mundo V4 Cargo bike, Juiced Riders ODK V1 Cargo bike
English is my secondary language - ASL (American Sign Language) is my primary.
chroot
Postby kiqnkf » Wed Feb 08, 2012 6:00 am
VeloV wrote:Re: "I've had more than 4+ years of FEA stress analysis and low cycle fatigue using ANSYS"
.....so how did you make out from all that analysis? ;)
That was maybe the funniest thing I've read on this forum. Nice one!!!
Royce Union D/S Mountain Bike, 500w Chituma front wheel kit
Stealth Bomber, custom electric kit....
NHW10 Prius - Ask, I may be able to help!!!
kiqnkf
Postby maxwell65 » Wed Feb 08, 2012 11:28 pm
hi all,
i updated the 3rd pic ( labelled pic4) it is shown with headway 15AH cells to form a 72v30ah pack,,, for 2160 WH which theoretically should give the bike a 60 mile range (100kms) without any pedal,,,based on 35 wh per mile,,,,that pic in reality shows a true set-up with headways as opposed to the other pic which just shows that in fact there is much more room than needed for a 72v set-up....in reality this is the maximum amount that we will recommend in batteries to be set up,,,as it is way plenty in terms of speed and range,,,,as for those wondering about the wiring,,, there is plenty of room for this,,,in fact it is designed so that one would wire the pack on the outside of the bike and easily put it in place once assembled,,,in case people don't know; the side rails are in fact removable with hex bolts,,,as for keeping the packs in place and to stop the battery leeds from shorting of course it goes with out saying proper shielding such as plastic non conductive encasement will be used and of course we will devise a proper holding device to keep the cells from rambling all over the place.
maxwell65
Postby slayer » Thu Feb 09, 2012 6:21 am
that pic number 4 really looks good Max, i already gave you my email before, just want you to make sure you know i m still in ...thanks
slayer
Postby darkshirikens » Thu Feb 09, 2012 10:52 am
Hi Max,
First i want to say i love the New look of it it is a better look than the old original CAD drawing , However most of us would like something that looks like a regular bike "i personally don't care " but in my state some cops turn a blind eye to a fast bike but we all know that there is always a dick head amongst the !! PIGS !! that don't have any other thing to do but harass people so for legal purposes will this bike have a VIN# and other information so it can be registered as a GAS, carbon producing,earth killing piece of sh** moped cause my state don't want to recognize an electric bike for what is really is ? I just don't want to have to be in a situation where i'll have to quote federal law cause they get pissed when they don't know if its true or not so i made a print out of the federal law just in case they try to take things too far! I'm in for a new bike and long as i have the funds LOL.
darkshirikens
Postby amberwolf » Thu Feb 09, 2012 3:13 pm
@darkshirikens: Note that the federal law means very little, as it only defines an ebike for manufacturers. It has nothing to do with whether they are even legal within any state or municipality, as each of those is free to define things how they wish, choose to not define them at all, or to make them entirely illegal if they choose. :(
So if your state has defined them as illegal, or calls them all mopeds, then that's just the way it is unless you can get people in your state to band together to change that.
I know there are sites like this:
http://www.paelectrics.com/legislation.html
that misinterpret the CPSC law; it's not there for that purpose.
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby darkshirikens » Mon Feb 20, 2012 12:19 pm
Any updates ?
darkshirikens
Re: ebike frame
Postby deepfraught » Wed Mar 07, 2012 11:48 pm
Late to see this thread, but original post has been wiped... keen to know the state of play.
ebony and ivory A2B Metros, testing 5065 and 6374 Commuter Booster beta, Hyena Hadron mkIV tested and H4060 test pending, GNG belt/chain BB drive test pending. Sold Tornaro mid-drive Nuvinci N360 Zoco Rossa and other flakey e-bikes. 2012 Every day pedal commuter 10kkm+
deepfraught
Re: ebike frame
Postby ohzee » Thu Mar 08, 2012 12:00 am
viewtopic.php?f=31&t=37530
Is that not the new/old post ?
Id say it looks very interesting.
ohzee
Re: ebike frame
Postby deepfraught » Thu Mar 08, 2012 1:05 am
I see, that's a different thread to this one, created today. PS: brilliant opportunity for ES-ers :)
deepfraught
Re: ebike frame
Postby maxwell65 » Sat Mar 10, 2012 10:48 pm
hi all,
i posted a brand new post for this thread as it is ready to go to manufacture,,, i will post all buyers (that give their permission of course) on that thread,,,plus a lot of people were becoming confused reading all comments on this thread.so here is in fact the new and final thread of which all updates will be posted ,,,, viewtopic.php?f=31&t=37530
maxwell65
Previous
Return to Items for Sale - New
Who is online
Users browsing this forum: acorless and 4 guests
