Very nice work and all ICECubeMaN...One thing that (personally) i don't
like with harness like this is the massive jumble of wires it creates.
There is a very neat and inexpensive way to get around this, and something
that might make your 'job' easier and quicker ICEMaN... Still using the bullets...
once its made, a lil hot glue over them, then slip double walled heat shrink over the lot to makez it look 'pro'You can make small 'bus bar' type setups, i used that 'strip board' to hold the bullets for a
series connection of my 44v 20ah lipo pack on my cruiser. I made a simple jig, drill holes
size of the bullts in a peice of MDF then drilled the same hole pattern in the board and
popped the board on the bullets and soldered them to it...Made for a neat compact
pack without a mess of wires to deal with..
^^^This was the original sent to me by
GGoodrum...i simple copied his idea, as you can
see with this adapter, it also has charging plugs...Personally i don't like or use (anymore)
andersons, shits of things IMHO... Anyhoot...te harness combined with paralel adapter boards
ES Member
Methods now selling some rippers of these..
Makes for a neater pack IMO, with ALOT less jumble of wires and individual connectors to deal with...
....very easy to connect and disconnect them also...Thought it might be of interest to
your future 'customers' and, maybe something to add to your line?
Keepz up the good work anywayz, ICEDuDez
KiM
