wojtek wrote:update: 5403 and 5404 avaiable
What you be the specs on each motor if I would be running 24s 3p?
update: Kenny is willing to send the motors to individual addresses if we get a good number of orders. Lets aim for 30!
Hey Cheeseboy, if it made it doable I might consider going in with you as well, and we could get them both shipped to you in Sydney, and I would get mine from you. Just throwing it out there in case that made it more viable.
Doctorbass wrote:BTW... wojtek, can you ask kenny to make them with 10 awg phase wire instead of 14 or 12 like usual?
it's not really complicated for them i think...
Doc
chroot wrote:@Doctorbass- Which controller recommend for 5403 and 5404 and Edward Lyen recommended me run at 24 fets controller to avoid over stress on the controller like 5303 tend blow up the controller easily.
wojtek wrote:chroot wrote:@Doctorbass- Which controller recommend for 5403 and 5404 and Edward Lyen recommended me run at 24 fets controller to avoid over stress on the controller like 5303 tend blow up the controller easily.
that is exactly what i got: viewtopic.php?f=31&t=19719
re the wires, i am thinking to not only ask about 10awg wire but also upgrade of hall sensors based on Lowracer experience:
"BUT, I must admit that in a 5hours test run one of the china hall sensors is broken!
I've got figured out, that the hall sensors, the ball bearings and the axle are cheap china trash!
Now I change the 3 sensors against HONEYWELL SS40,
and I change the ball bearings against SKF 6004-2RS / SKF 6005-2RS,
and I change the axle against a new selfmade 12.9 STEEL AXLE with build-in torque support!"
I dont know what of those things Kenny will agree to upgrade, but one sure thing - i will push hard for those changes. No point to get motors that will stop running after short period of time. little problem for experienced people who can fix it / upgrade it. But like me, i cant do it so i want it right in first place.
Will see where i go with it. But again, our power lies in good amount of orders, so please keep coming![]()
wojtek wrote:actually Chris [lowracer] said that the axle wasn't too bad. it is only the hall sensors... well won't hurt to ask for an upgrade
Hi Neil,
Nice to hear you get the order.
The wire called less resistance 4 mm2 ( square ) for motor.
But it will make things simple if we called it for Crystalyte X5 motor's phase. So we will understand.
Kind Regards
Kenny
wojtek wrote:290USD/ea for a hub motor + 7speed freewheel
+ shipping costs [motor hubs can be shipped separately to your door, for quote, give me your address]
Min order quantity: 20
5403 and 5404 available
150mm dropouts
Please put your name and country and quantity if interested.
ryan wrote:Can we get some more info on stretching 135mm cromoly dropouts to 150 and/or modding the axel to 135? Is the axel mod something I could get a local machine shop to do for ~$50? I'm considering stretching out a Yuba Mundo to 150mm.
NeilP wrote:I do not know why, but my motor came with what I thought was 10 gauge as standard, but maybe it was 11
.I got my 5304 from Maxwell65 and he says he did not ask for thicker gauge wire, that is just how they cam.
Kenny supplied me with more of the same wire, and I only just installed it back on my motor. [url][/url]
Return to Items for Sale - New
Users browsing this forum: No registered users and 3 guests
