HS35 & HT35 kits with Sensors, with Warranty, with MethTek support
I have in stock, ready to ship the following Hx35 motors. These motors have hall sensors (so they can work with **any** controller) and I personally guarantee against any type of manufacturing defects like cut wires or dead halls for 1 year.
HS3540 laced into a 26” rim
HT3525 laced into a 26” rim
HS3540 laced into a 20” rim
(All hubs are Rear mount compatible with disk brakes. These are the true 35mm stators with deeper cut grooves in the axles for wire clearance. Each has been inspected and modified by me personally.)
I am offering these custom produced hub motors in combination with one of 3 highly upgradeable “wide range” controllers that have been produced to my specification to be fully compatible with all offerings from Justin at ebikes.ca
These controllers have an awesome super wide input voltage range of 36V – 72V with no need to make any resistor modifications – just plug and play. They use genuine IRFB4110 mosfets that we personally procured and provided to the manufacturer. The capacitors are rated to 100V and there is enough capacitance to keep the rail stable driving any hub.
25A upgradeable 6 fet controller, 36V-72V input range, regenerative braking, CA connection, power button, Fwd/Rev control
40A upgradeable 12 fet controller, 36V-72V input range, regenerative braking, CA connection, power button, Fwd/Rev control
If you think you might want to start simple and modify for more performance later this is where I think you should start. The mods to get higher power out of these controllers are straight forward and I can help you with that when you are ready.
Something to think about is the “standard” you settle on. You may not think so now but it is highly likely that you will end up with more than one bike and plug-n-play compatibility can be the difference between quick gear swaps and obnoxious incompatibility headaches. I recommend following the connector standard that Justin has set at ebikes.ca
As an additional option I have 72V 40A Crystalyte sensorless controllers available. If you are looking to put away a “backup” controller this is the one
Crystalyte 72V – 40A Sensorless controller. CA plug, throttle, PAS, E-brake, direction. FB4310 fets. Modifiable.
These kits will be supplied with the latest Large Screen Direct Plug-in CA
I calibrate each CA to the exact controller and motor you are getting so it is ready to go right out of the box. I can also help you tune the settings of your CA for your specific setup. If you buy your CA from me I will always be available to help you if you get stuck.
I have both Thumb throttles and “half twist” throttles. I recommend the “half twist” throttle for 99% of riders. The nice thing about this throttle is that it allows you to rest some weight on the outer edge of the bars which relieves wrist fatigue on long rides. If you have not experienced this you will…. (or your wife will).
1 /2 twist Throttle
Thumb Throttle
There are two more things that must be in an ebike kit that it seems 99% of retailers don’t include: A torque arm and free wheel. A high quality torque arm is an ABSOLUTE MUST. You cannot *reliably* install a high power hub motor without at least 1 torque arm. This is coming from a man who actually had his front hub detach while going 35mph launching me over the bars into the middle of an intersection. The same man (me) who spun out the rear axle on my aluminum frame and ruined the drops on my Kona Stinky Downhill.
Torque arms come in two flavors: “beefy” and “clean”. Both were designed and manufactured by Justin. These are not imitation/copies – these are very high quality stainless steel.
Universal Torque arm with double hose clamp
“clean” Torque arm for mounting with fender holes
When selecting a freewheel the most important thing to realize is that you will be going much faster than you would on a normal bike… so an 11T cog is an absolute must. I have 7spd and 8spd freewheels available
7spd 11-32
8spd 11-32
Water cut inside waster (not typically needed for HS series motors but valuable to have)
My pricing for all parts and kits is identical to the pricing at ebikes.ca. I have everything listed above (and more) in stock, checked out, and ready to ship within 24 hours to anywhere in the world. I am offering FREE SHIPPING to the lower 48 states of the US. For international orders I will charge you the actual shipping cost minus what it would cost to ship domestically.
I ship UPS Ground which is much faster than USPS Parcel Post! You will typically receive your hub within 3-5 days possibly sooner.
Have a look on this webpage to learn more about the differences between the kit options and pricing.
http://ebikes.ca/store/store_nc.php
Let me be very clear on this point: If you are in Canada you should order directly from ebikes.ca. If however you live in the US I can offer very competitive shipping rates (FREE, DUH!) and my personal customer service / support / guarantee on anything you buy from me.
In closing, a few notes:
Warranty
Warranty on HS motors is good for 1 year on any type of manufacturer defect…. Most specifically cut phase or hall wires and blown halls. I will not warranty a motor that has been over-heated/abused…. and believe me I can tell. If you are a “regular guy” with no intention to do anything crazy like increase current limits or over-volt then you have nothing to worry about. The most important thing to know: IF AT ANY TIME YOUR HUB STARTS GETTING LOUD OR LOSING POWER – STOP STOP STOP! This can be an indication of a shorted phase wire, which is actually very easy to fix…. BUT…. If you don’t stop right away permanent overheating damage can occur.
If you ever have a doubt do the following: Pick up the rear end of the bike and apply full throttle. Watch the current on the CA. If it reads anything greater than 2-3 amps then something is very wrong. Don’t ride it – contact me immediately and I will take care of you.
So we are clear - the purpose of this warranty is to alleviate concerns about recent quality control issues that Crystalyte has had regarding "cut wire" issues with their motors. This is not a guarantee that you wont smoke your motor, that your spokes wont get loose from over-powering, or that your controller wont pop if you push it too hard. Everything I am selling here is already into the "over volted" range and these are *performance race parts*. If you want an iron clad warranty then you will have to stick with 36V - 48V gear and I suggest you purchase that from ebikes.ca directly. Reliability is important - so please understand that any time you get above 48V the scales are tipping towards performance over reliability. Burst acceleration, high speeds, extreme ebike grin.
Batteries
This is a personal choice, but at the moment what I would recommend would be an 18S 10Ah Lipo pack from Hobby city. To protect that investment I recommend the HVC/LVC/Parallel boards that I am about to release. You will also need a method to balance and charge… which is not so simple. If you don’t know where to start I would steer you toward Cell_Man with his awesome pre-built A123 packs with integrated BMS. More on this later.
Other Stuff
I also have other goodies for sale that are not offered at ebikes.ca
6x10 Rear 9C laced into a 26” rim
6x10 Front 9C laced into a 26” rim
5x12 Front 9C laced into a 20” rim
3-Speed switches (pigtail must be added to controllers to use these)
HVC/LVC/Parallel boards (in production, not ready for sale)
-methods
