by scriewy » Fri Sep 30, 2011 7:59 am
i am in for 5403, just contemplating about 150mm or 135mm and left to know from where the lowest final postage gona be to israel 52481, from you wojtek or from maxwell.
i hope there is ground shipping from luxembourg, even if ground i know from eBay that european postage is high for some greedy reason, hence sea shipment from maxwell might be close or lower to european rates.
tell me please what is it from luxembourg.
also would it be possible to order an extra hub shell/case ?
people that will want more torque should consider this, you lace the extra shell into 20" rim or anything smaller than what you use and just switch the stator if you started with a bigger wheel like 26", so you wont have to disassamble and relace the same motor, it's about 30min work if you start from wheel in bike frame.
it's a pitty i wont stay to see the world crumble, u jedi Scum
clyte 405,
went through battle, bloody resurected Dewalts 4x28v 2s2p usable 2.7ah, 52v drops to 44v at 54kmh
78v 2ah Vdrop to 58v at max 66kmh.
72kg rider + 23kg bike.
keywin 20a 30-70v mod to 6 4110 as methods advised for noobs, shunted 38a
clyte 24-72v 40a mod 4310 to 4110, shunted to 77a
17.5.11 - 5000km
at 78v 4ah 72.7kmh Vdrop to 68v
10.11 - 82.1kmh
30.8.12-17000km
a place for lasers as ES is for e-vehicles - laserpointerforums.com
