by scriewy » Fri Sep 30, 2011 8:31 am
damcard i think the 135mm will be less dished.
i was checking disk brakes spacing from the frame on 135mm and 150mm frames, in bike stores and they seem same, only the hieght of bracket changes with bigger disk diameter, but i didnt measure it with caliber.
if the disk spacing is the same then that means the motor should be at same distance from the rear fork on disk side, wich leaves you with more space on the freewheel side in a 150mm axle, so if looking at the bike from it's back where freewheel is in right and disk is on left, the motor will be more dished to it's left.
i have the 405, which is same width, and from posts i red about the 400 there was a problem using a disk, not anough space with 6-7 speed freewheels, so i am guessing they moved the motor to the right side on the expanse of speeds so we can use only 3 speed freewheels, what tells me that in 135mm axle the motor is more centered
it's a pitty i wont stay to see the world crumble, u jedi Scum
clyte 405,
went through battle, bloody resurected Dewalts 4x28v 2s2p usable 2.7ah, 52v drops to 44v at 54kmh
78v 2ah Vdrop to 58v at max 66kmh.
72kg rider + 23kg bike.
keywin 20a 30-70v mod to 6 4110 as methods advised for noobs, shunted 38a
clyte 24-72v 40a mod 4310 to 4110, shunted to 77a
17.5.11 - 5000km
at 78v 4ah 72.7kmh Vdrop to 68v
10.11 - 82.1kmh
30.8.12-17000km
a place for lasers as ES is for e-vehicles - laserpointerforums.com
