sabb wrote:Max does not reply to my emails. I do not know why but I have no reply's to both emails and no pm's from him.
anybody else want to tell me the amount for a 5403 in a 26" wheel with 135 mm axle and max's paypal so I can send the money.
Stephen
Arlo1 wrote: The stamped stator is lighter so thats a good thing.
Doctorbass wrote:Arlo1 wrote: The stamped stator is lighter so thats a good thing.
Yeah... until it burn... They are not made for abuse like the X5.. and what we all wanted is the X5 desing for his endurance about heat... that's it !
more stator = less heat loss for the same power... and watercooling a less powerfull motor is like accepting using your battery to partially heat water... this is not the goal guys!
we wanted better copper mass and better heat transfer...
Anyway.. do what you want..
I know Max did an awsome job and took alot of time to help us getting a great extreme motor... but the problem is from china...![]()
Kenny is not anymore on my paypal list!!
Doc
Doc
Arlo1 wrote:It means the windings are still getting hot in the first place and you are using the stator to pull the heat away. A continuous watt ratting for a heavy and a light stator is the same the light stator will just burn in less time
Arlo1 wrote:Doctorbass wrote:Arlo1 wrote: The stamped stator is lighter so thats a good thing.
Doc
Doc you are looking at it all wrong. The X5 has a heavy stator to help keep the windings cool but this is not a good thing. It means the windings are still getting hot in the first place and you are using the stator to pull the heat away. A continuous watt ratting for a heavy and a light stator is the same the light stator will just burn in less time but they will both be the same efficiency and from a performance stand point lighter is faster as well with a light stator you have less weight to accelerate there for putting less heat in the motor to move the bike!
Using A heavy stator to help keep a motor cool is the wrong answer its worse then water cooling! The proper answer is to increase efficiency and you can only do this with thicker phase wires or making them spin faster!
flathill wrote:...I wonder what motor the latest Bombers are using?
Return to Items for Sale - New
Users browsing this forum: No registered users and 4 guests
