Optical sensors available for Astro, Turnigy, etc.
Postby Burtie » Thu Sep 15, 2011 4:10 pm
Not complete kits, but pcbs, application notes and encoder images, to enable you to put together your own optical sensor setups :D
Rotary board (inside Astro or external shaft fitment).jpg (170.57 KiB) Viewed 2527 times
Linear board (for outrunners)
Misc encoder parts.jpg (248.23 KiB) Viewed 2657 times
Descriptions and demo videos of the parts are in the opto thread here:
viewtopic.php?f=2&t=28966&start=30#p434772
Sorry I can not walk though each individual installation with people, but
download the application notes /fitting guides here and have a go :
Astro (internal)
Fitting Astro optos.doc
(1.29 MiB) Downloaded 163 times
External rotary:
Fitting rotary opto sensor.doc
(1.83 MiB) Downloaded 166 times
Linear, for fitting to outrunners:
Fitting the linear opto sensor.doc
(1.39 MiB) Downloaded 205 times
The prices:
a) Rotary/Astro board 22 GBP
b) Linear (outrunner) board 18 GBP
I also have
c) 40mm metal disc and balsa spacer material to help with Astro installation @2 GBP
d) 40mm nylon discs and spacers to help construct your own external encoder wheels to work with a) @ 2GBP
Postage (no tracking) 5 GBP
PM me if you want any, we can sort the funds with Paypal. EDIT May 2013 --> Sorry, currently no boards available
Opto encoder images are available in the post below :)
Burtie
Last edited by Burtie on Thu May 02, 2013 1:45 pm, edited 13 times in total. View post history.
Burtie
Re: Optical sensor boards available for Astro, Turnigy, etc.
Rotary encoder images for 8, 14, 20 and 24 magnet motors
Download the full size image (click to expand it -should get 937x1465 pixels), save it, and print it A4 on a Laser Printer using 'best fit to page', should get you pretty close.
Not sure about american paper sizes :?
You need to fix the image to a 40mm disc to work inside an Astro, I probably have some 40 mm metal discs with a 13mm (1/2 inch) hole if you need.
I also have various nylon parts (spacers +discs) which can be combined to make hubs to for external rotary encoders.
Note
1) You need to use a laser printer, inkjet printouts will not work with these IR sensors, the black portions are too reflective.
2) The black segments are deliberately a few degrees wider than the white ones. This is to compensate for the slightly uneven characteristic of these sensors in this application.
Here is a set of images for the linear encoder, for 14 magnet outrunners :D
Linear (Strip) encoder images for 14 mag outrunners
(54.59 KiB) Downloaded 4 times
For the 80mm Turnigy outrunners, resize the image using your printer options -try the printer settings below:
(Landscape, custom size: 26.50 wide, 18.90 high)
Printer settings strip.jpg (119.8 KiB) Viewed 2576 times
For different size outrunners, you will have to work out how to resize it yourself :wink:
Single linear images:
Linear encoder image for 14 mag outrunners
(28.59 KiB) Downloaded 4 times
For 80mm motors, print Landscape 3.7cm high x 25.71cm wide
For 63mm motors, print Landscape 3.7cm high x 20.28cm wide
Linear encoder image for 20 mag outrunners
(26.46 KiB) Downloaded 4 times
Linear encoder image for 24 mag outrunners
(28.79 KiB) Downloaded 4 times
here is a link to a linear28 image for 28 magnet outrunners (thanks Tsjoechov)
viewtopic.php?f=2&t=28966&start=75
Have fun,
Burtie
Last edited by Burtie on Mon May 13, 2013 12:35 pm, edited 15 times in total. View post history.
Burtie
Postby STGMT » Thu Sep 15, 2011 7:17 pm
Can you make a "kit" with the encoder, sensors board, fixing and all stuff for the turnigy 80-100 ? I want one! :D
STGMT
Postby liveforphysics » Thu Sep 15, 2011 9:58 pm
Burtie- I love your work! Optical is so immune to the flux-noise issues and hall distance issues. This is so great! You are really a major contributor here, solving issues one after another with clever solutions. I am so fortunate to have you here Burtie. You rock!
For ebike parts, don't be a douche, buy from http://www.ebikes.ca or http://www.MethTek.com
Justin saved the forum at great personal expense! The man is a legend and a hero!
liveforphysics
Postby grindz145 » Thu Sep 15, 2011 10:05 pm
Hell yeah! Just made off the shelf outrunners that much more viable. Woohoo!
http://www.endless-sphere.com/forums/viewtopic.php?f=18&t=19548 - Ebike Nerd Podcast
Thanks to Justin @ ebikes.ca! Go there, buy stuff. Support the Revolution :D
grindz145
Postby Arlo1 » Thu Sep 15, 2011 10:45 pm
Thanks burtie!!!!
Thanks Justin of http://www.ebikes.ca/
Also a thanks to Methy at http://www.methtek.com/ :)
And Dave who has some good deals on STUF
RC lipo and most other types of Lithium batteries you MUST know your individual cell voltages while charging and discharging.
Batteries of all kinds need respect they can burn your house down, so don't sleep with them under your bed or any other were you cant afford smoke or fire!
[color=#FF0000][b][size=150]Never above 4.2v never below 2.7v EVER!!!
Arlo1
Postby Burtie » Fri Sep 16, 2011 4:21 am
Thanks for the encouragement guys!
STGMT wrote:Can you make a "kit" with the encoder, sensors board, fixing and all stuff for the turnigy 80-100 ? I want one! :D
I think most of what you need is now here my friend, I have added the encoder images in the 2nd post.
Burtie
Burtie
Postby addicted2climbing » Mon Sep 19, 2011 7:46 pm
Hello Burtie,
Wow this is great to see and I was just about to design in some external hall sensors to my outrunner. However after seeing this, I may change that. I could easily fit your external version, but curious if it would be possible to fit an internal version or a smaller version of your design. I have attached a Jpeg that shows where I would like to fit one of your boards. I am pretty sure I could not fit your stock one, but any chance I could get one specially made to fit between my motor and sprocket? I could design my own mount to hold the black and white flags, and then give you a PCB size with sensor locations to fit in a pocket I machine in the swingarm... I am sure you dont have time for customs,but curious if one could be made with prototyping boards...
If not, can I get a dimension of your external board so I can design it in... Only thing I fear is the external one woudl have issues with dirt on the motor and this will be used in the dirt... Having it hidden in the swingarm would be a much cleaner environment..
The motor is an Aeleon 6354-250KV...
Take care,
Marc
addicted2climbing
Postby Burtie » Wed Sep 21, 2011 5:54 pm
addicted2climbing wrote:Hello Burtie,
...I could easily fit your external version, but curious if it would be possible to fit an internal version or a smaller version of your design. ... I am sure you dont have time for customs,but curious if one could be made with prototyping boards...
Hi Marc,
I can't do 1 off pcbs because of the time/cost, but I can give you the measurements of the ones I have:
Linear board is 51mm x 24mm (could be trimmed down to 43mm x 24mm)
Rotary board is about 51mm square with a 25.4mm (1 inch) hole in the centre
You probably need to protect your outrunner motor from water/dirt to make it reliable, so external linear sensor may not be a bad idea?
Best regards,
Burtie
Burtie
Postby mwkeefer » Tue Oct 04, 2011 8:33 am
Burtie,
You are the MAN! After some trial and error on an old (expendable) motor, I finally got the optical solution working quite nicely and now here I find the optical for my Turnigy and Hyperion motors... Excellent!
-Mike
Regards,
Mike
{My Rides]
2010 Dahon Jack - GNG v1 - LYEN 6FET - 20/40A - 18S2P10AH - Nom:66.6v,1332w
2004 Hard Rock Pro Disc - Recumpence ms eDrive v4 - Astro 3220 4T - 12S2P16AH - HV110 - Left Side Drive - Gearing: 38mph
Nominal Peak Power @ 60 seconds: 5328 watts - Maximum Power: 49.8v, 120A, 5872w
2010 Downtube 8FH - Stock GNG v1 Stock Controller - EB809XC - 12-16S
2012 Downtube Nova 7spd - Stock GNG v2 - 12S2P10AH - EB809 - 12S-16S - 20A/30A,Nom VCC: 44.4, 888w
mwkeefer
Postby Burtie » Thu Oct 06, 2011 12:39 pm
Good to hear you got it working ok Mike :)
I have added some more encoders to the 2nd post in this thread, to support 20 and 24 magnet motors.
Burtie
Burtie
Postby Burtie » Mon Nov 28, 2011 8:02 pm
Just a bump to keep the thread alive..
I just made up a few more boards if anyone wants one to play with, they are ready to go :)
green things.jpg (94.5 KiB) Viewed 2058 times
Burtie
Last edited by Burtie on Wed Jan 16, 2013 9:03 am, edited 1 time in total. View post history.
Burtie
Postby Arlo1 » Mon Nov 28, 2011 8:59 pm
Burtie wrote:Just a bump to keep the thread alive.
Burtie
Uhmmmm... Im broke :( But I have decided this is the way to go for hi power BLDC! So You will be hearing from me soon.
DO you have something with timing avalible for WYE for colossus instead of Delta? Or something that can be switched back and fourth?
Arlo1
Postby Burtie » Tue Nov 29, 2011 4:43 am
Arlo1 wrote:DO you have something with timing avalible for WYE for colossus instead of Delta? Or something that can be switched back and fourth?
Arlin, sorry to hear you are broke, --being broke sucks ballz :(
The sensors and encoder are the same for delta or wye configurations. The only thing that changes is the ideal position of the sensors relative to the encoder.
To get best efficiency in both modes you could use two sets of linear sensors positioned at different points, reading the same encoder strip.
Or two rotary sensor boards, reading both sides of an encoder disc.
The switch between one set to the other could be accomplished using simple logic gates.
Burtie
Postby Arlo1 » Tue Nov 29, 2011 10:29 am
Yeh I was thinking one board with 6 sensors on it. 3 for WYE and 3 for DELTA , Hmmm I need to learn to make pcb! Ok thanks Burtie. And I wont be broke for long. Just till a little while after christmass this is my slow season fixing motorcycles, the ATVs and Snowmobiles help but there is less of them.
Arlo1
Postby Burtie » Mon Jan 23, 2012 5:06 am
Bump to stop the sale thread timing out....
Last edited by Burtie on Wed Dec 12, 2012 7:00 pm, edited 5 times in total. View post history.
Burtie
Postby comradegerry » Sun Mar 04, 2012 8:44 am
Nice work Burtie, your contributions to the Sphere are legend.
PM Sent.
Gerard
comradegerry
Postby dumbluck » Mon Mar 05, 2012 9:51 am
Awesome work I will take some. pm sent
dumbluck
Postby Burtie » Mon Mar 05, 2012 6:17 pm
Thanks very much for the appeciation :)
While testing out boards for some orders recently, I made this short clip showing how the sensors are affected differently by flourescent and incandecent light.
http://www.youtube.com/watch?v=s0T_YolNWy8
Burtie
Burtie
Postby www.recumbents.com » Sat Apr 21, 2012 11:22 am
I'm working on adapting the burtie board to an Astro 3210, using a MKII-LYEN EDITION-12 FET 3077 MOSFET controller. Battery will be 44V LiPo.
I used a polycarbonate plastic washer that I made as a spacer for the washer that the black and white timing image is mounted to, and glued it all together with JB weld. My motor did not have a balancing blob, or if it did it is gone now, so I didn't need to worry about clearance for that. Hopefully balance will be ok. I used a punch to reduce the ID of the washer rather than using tape to fill the slight gap. I'm working on wiring it all up now. I'll post pictures and stuff when I have something working.
Started a new thread to document the build: viewtopic.php?f=28&t=39035
-Warren.
Last edited by www.recumbents.com on Mon Apr 30, 2012 7:56 am, edited 1 time in total.
www.recumbents.com
Postby Burtie » Sat Apr 21, 2012 2:35 pm
Would be great to see your work Warren.
New thread might be best to document your project. These threads in the sale section are a bit temporary and dissappear if not regularly used.
Edit:
Warrens thread is here
Burtie
Postby wojtek » Fri Apr 27, 2012 5:11 am
im very exciting to get one and try to install on my 4 turn wye 3220 as i was unlucky with HV160 controller :)
WIRES AND CONNECTORS
viewtopic.php?f=31&t=30176
http://endless-sphere.com/forums/viewto ... 31&t=32244
http://endless-sphere.com/forums/viewto ... 31&t=32152
Go-One Evo tested with HS3540, now working on Cromotor
BATMOBILE - Astro 3220 / Nuvinci in progress
Velokraft e-VK3 / Max speed 90km/h downhill - EVKA [for sale]
Steintrike Mungo Sport HS3540-SOLD
Scorpion FS HS3540-SOLD
Kona Dawg BMC v2-SOLD
wojtek
Postby kevo » Sat Apr 28, 2012 10:39 am
Bertie,
I would like to order two of these when the next batch is available (Astro 3210 10t).
Thanks Justin of http://ebikes.ca for your amazing talents, dedication and contributions to ES!
Post licensed under "Open Source" http://creativecommons.org/licenses/by-nc-nd/3.0/
kevo
Postby wojtek » Mon Apr 30, 2012 2:16 am
i have received the sensor board! paid on Friday and got it on Monday!
many thanks for fast shipping :) much appreciated!
the board is sent with heavy duty envelope and additionally protected with cartoon box inside. Great job!
wojtek
Postby MattyCiii » Mon Apr 30, 2012 3:40 pm
Burtie,
Are these back in stock? I'd love to order one or more if so.
1st build: Dahon Jetstream folding bike. Quick, reliable, capable of 30mph. Light enough to lift, folds for easy transport by car/bus/train.
2nd build: RC powered 2009 Norco A-Line. Top speed 31mph. Built like a tank, it's resistant to Boston potholes, can stop on a dime, easily goes up/down curbs when necessary.
3rd build (just started): Scratch build ultimate utility bike.
MattyCiii
Next
Return to Items for Sale - New
Who is online
Users browsing this forum: biohazardman, CroArcher, usa_electrophile and 6 guests
