Genesis extended swingarms Batch started!
Re: Genesis extended swingarm sale thread.
Postby Farfle » Sat Apr 28, 2012 11:44 am
Doh! did I not knock the powdercoat out of the dropouts? Usps got that thing there quick!
The race bike:
24s5p 50c nano tech
Badass custom mofo outrunner 205x177mm 26kv
Peak power in : 318A at 91v
Peak power out: 24 Hp and 151ft/lb
Build to last...
"It will be assaulted by the elements, It will be ravaged by time and it will be destroyed by the user. BUT, if you Stick to the little rules: K.I.S.S., Overbuild everything, and test, review, revise, repeat. It will last"
Team Farfle blog!! http://www.farfleselectrics.blogspot.com
Farfle
Postby GITech » Sat Apr 28, 2012 11:59 am
ZOMGVTEK wrote:Ruhoh.
:shock: Sweet! 8)
We'll, we can't meet up for a ride for a while though...I broke my collar bone into 3 pieces on thursday. A ~3" dia tree branch was at an angle in my path and it just kicked my front tire out from under me. SOAB! I'm down for the count I guess. :evil:
Nice batt box, do you have a break to bend it with?
Farfle, no hard feelings..I was just kickin up some dirt to try and help... :wink:
One handed typing, bahhh!
Later,
Jay
Ebike: Wallmart Genesis frame, unique Lovejoy 2-speed simplified/redundant drive mounted on custom aluminum swingarm conceptualized by me, machined by Thud. Brushless 80-100~100kv w/halls, 16s6p - 59.9v, 30Ah, 1.7+KWh, Fully Loaded Lyen 12 FET 3077 controller w/ Cycle-Analyst, full custom lighting.
Thanks to Justin at ebikes.ca for saving ES!
Ideas and projects by GITech are protected by: http://creativecommons.org/licenses/by-nc-nd/3.0/
GITech
Postby Hardcarve1 » Sat Apr 28, 2012 2:23 pm
I just had a similar crash the other night when my front tyre went over a half inch stick and slid out while I was apexed on a bend. Only problem was I was entering a small tunnel and whent straight into the concrete wall and then was thrown out onto the path. No broken bones but a serious hematoma on my left elbow.
When in doubt, REV!! it out.
MTB - HXT80-130 direct drive through staton 1:18.75 gerbox, HV160 ecs, Nuvinci hub, 12s A123 9.2ah (retired)
MTB - 9C stock, 12 fet Lyen, 9 speed, 16s A123 20.0ah, 2000lm LED ebike lights.
Line trimmer - HXT80-130, HV110 ecs 12s A123 2.3ah
Hardcarve1
Postby damcard » Tue May 01, 2012 11:42 pm
Whoo Hoo, I got my swingarms, motor, and controller! Thanks for coming through Farfle. What size did you thread the axle to? -Damcard
damcard
Postby ZOMGVTEK » Wed May 02, 2012 8:43 am
GITech wrote:We'll, we can't meet up for a ride for a while though...I broke my collar bone into 3 pieces on thursday. A ~3" dia tree branch was at an angle in my path and it just kicked my front tire out from under me. SOAB! I'm down for the count I guess. :evil:
That's no good... Something like a month to heal?
A member bent the box for me. That made things easy.
I need to get some more batts, I've been using 80-100Wh/Mi...
ZOMGVTEK
Postby Farfle » Wed May 02, 2012 9:40 am
Woot! Glad the box made it there, I think the axle nuts are either 1/2" coarse, or 7/16" coarse. also, the skinny swingarm has to have a spacer between the disk mount and the caliper on the front bolt.
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Postby GITech » Wed May 02, 2012 4:39 pm
Hardcarve1 wrote:I just had a similar crash the other night when my front tyre went over a half inch stick and slid out while I was apexed on a bend. Only problem was I was entering a small tunnel and whent straight into the concrete wall and then was thrown out onto the path. No broken bones but a serious hematoma on my left elbow.
Oooooo, ouch! Sorry to hear that! Do you have elbo pads?! ;) I was wearing full sleeve upper body armor, but all that padding and plastic didn't help with the impact to my collar bone. I wonder if there is body armor that has ridged sholder pads or something that can help protect the collar bone from seeing the full force of a shoulder impact?!
I just had surgury on it last night. They put in a plate and screws. They said it was so bad they had to put in a big plate so it will have to be removed once the bone heals. :|
I need more practice! :twisted:
They said ~2 months before I can do normal stuff carefully. I guess it's a bad break. :roll:
Oh, cool. people on ES can be so nice, like Thud who helped me by doing the machining on my drive train components and making the two rear axle to kart sprocket adaptors I needed at a fair price!
I've got some thin ~1/16 3031 alu so it will be easy to bend for my batt box which will hold 20 of the 4s 5000mah hardcase packs in a 16s5p config. I'll post a pic of my sketchup using the frame and batt models you guys posted up here. Thanks for the models guys!!
This pic shows a 203mm line at the bottom bracket location to represent the 203mm BB cartridge (from sickbikeparts) that is on the bike to allow clearence for the the crank from the wide swing arm, motor and lipos. I like the peddles futher apart like this too!
80-100wh/mi?! Wow, is that 'cause you ride off road a lot? How much capacity do you have now?
I've got a question for you ZOM, I've got in my 13AWG wire to rewind my motor with, do you think you might be able to give me a (second :roll: ) hand in doing the rewind? If you have the time of coarse!
Later guys,
Jay :)
GITech
Postby ZOMGVTEK » Wed May 02, 2012 6:15 pm
My pack is 888Wh, I can kill it in a few minutes now.
I don't really do any offroading, nothing is close enough for me to be able to get there and back alone. I was just mostly doing repeated WOT runs, into regen, into WOT, testing out the new motor.
I'm probably going to snag another 24s2p config of the 4S packs if they ever show up in the US warehouse. That should make the range acceptable.
I have zero experience with RC setups, and definitely never rewound a motor. It sounds like a fair bit of work. It might be a fun project, but I don't have a whole lot of spare time lately. I probably have another few weeks before I even manage to get the bike done enough to start taking it anywhere, which would be nice.
ZOMGVTEK
Postby GITech » Wed May 09, 2012 11:23 am
ZOMGVTEK wrote:My pack is 888Wh, I can kill it in a few minutes now.
Ah, your beating it to death! :twisted: Hehe, cool, fun is fun! :twisted:
I've had 16 of the 4s hardcase packs on backorder from the USA WH since the begining of March...so if you want some I'd get you order in ASAP. I've been trying to get HK to say they will be restocked for sure and they have finnaly said that they WILL be restocked so....that's good. It's a big deal for HK to give a straight answer, ya know! :|
No prob man, I've actually begun my rewind (1-1/2 handed :P ). The start came out good, but I can tell that I can't get 6turns of 13awg wire on there for a full rewind...sooooo close, but no go. I just got 14awg wire in today so I will be starting over and do a 14awg 6turn wye wind.
Also here is my latest sketchup with what I think will be the final lipo layout on my build.
Later,
Jay
GITech
Postby boppinbob » Thu May 24, 2012 10:51 am
Farfle check your pm' s. Do u have any swing arms left?!!!
Project bike-Genesis v2100, Crystalyte HS 3540 with 72v40A controller and four 5s8Ah zippy lipos in series.
boppinbob
Postby Farfle » Thu May 24, 2012 11:06 am
Farfle wrote:None left out of this batch, But I will be starting up another as soon as spring term is done.
Sorry man, None left out of this batch, But I will be starting up another as soon as spring term is done.
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Postby boppinbob » Sat May 26, 2012 6:40 am
Not going ahead and snapping one up in January is my bad. I'm regretting it now that I'm going with higher wattage.
boppinbob
Postby vintagerider » Sun May 27, 2012 3:49 pm
is there a waiting list or something would like one also
no electric bike yet but soon
vintagerider
Postby cal3thousand » Thu May 31, 2012 7:23 pm
So I found a Genesis on craigslist today but the homeboy wanted $400 for it :shock:
http://losangeles.craigslist.org/lgb/bi ... 60155.html
So I sent him a few texts:
Me: Is that $400 price for the Genesis bike a typo? ... They sell that bike at Walmart for $159 new. 5:12 PM
+********: I already ugrade that bike too many parts i already upgrafe 5:15 PM
Me: oh... in that case, would you tell me the upgrades? I might be interested 5:17 PM
+********: Shifter buttom bracket rear derauiller crankset tire handle post 5:18 PM
Me: Can you tell me what components are you using? I might be interested, but not for no-name parts 5:19 PM
+********: All shimano parts 5:19 PM
Me: nevermind, good luck selling that thing 5:21 PM
EDIT: More texts:
+********: Ur not interested 5:23 PM
+********: It is shimano parts 5:23 PM
+********: Shimano is a brand name 5:23 PM
:shock: :shock: :?
Me: Dude... shimano makes cheap crap all the way up to super amazing expensive parts. 5:24 PM
+********: What shimano tourney altus and alivio is cheap no men 5:25 PM
+********: The tire is mechilen tire does not cheap dude 5:26 PM
+********: 35 each tire dude 5:26 PM
#1: Diamondback Menona 700c (Commuter)
M/C: e-BikeKit geared rear w/BB7 with 12FET 40A Infineon ebikes.ca
GM 48V LiFePO4 10Ah racked; moving to 12S Turnigy 10Ah framed
+ Speedict, XC30TK disc, Alex Adventurer 700c Disc, Tektro 180mm hyd. with 42mm Kenda Urban
#2: Norco VPS Six DH (Fun) WIP
M/C: Clyte HT3525 (Thanks Meth!!!) http://Methtek.com with Lyen 18FET 24S Regen
Battery: 24S Turnigy 10Ah frame (ABS)
#3: Wifey Bike, Giant eSuede fully customized WIP
cal3thousand
Postby vintagerider » Thu Jun 14, 2012 4:50 pm
there seems to be a great interest in these swingarms but very limited can be made by farley, at no fault of his seems be be very smart but also very busy. can we enlist a member with mad skills like farleys to make a batch of these swingarms?, this post is in no way in infringe on his bussiness, but if he is too busy can we get the drawings and make them ourselves? just a thought, :mrgreen:
vintagerider
Postby Farfle » Thu Jun 14, 2012 5:08 pm
I would be perfectly happy to send the new V3 swingarm jigs and machined/ bent/ laser cut partst o somebody who has a welder and some time, its the welding that takes 75% of the time. I can machine and bend the pieces for ten swingarms in an 8 hour day. But it takes 2-3 hours to weld and straighten each swingarm.
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Postby nicobie » Thu Jun 14, 2012 8:04 pm
farfle
:wink:
May your tote always stay tight and your edge eversharp :wink:
my eTownie build thread: viewtopic.php?f=6&t=23701
nicobie
Postby Farfle » Sat Jun 16, 2012 12:45 pm
Bump! V3s are being produced!
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Postby SkyknightJohn » Sat Jun 16, 2012 1:07 pm
good to hear! I'm still interested. PM going out...
Genesis V2100 - Mac 8t and 12s5p a123 from cell_man
SkyknightJohn
Postby boppinbob » Sat Jun 16, 2012 8:38 pm
How long before they are ready to ship?
boppinbob
Postby nicobie » Sun Jun 17, 2012 1:19 pm
Good for you Farfle!
The one I bought from you is really working out nice.
I hope you thought about upping the price a bit....
Nick
nicobie
Postby deVries » Sun Jun 17, 2012 1:43 pm
nicobie wrote:Good for you Farfle!
Nick
You're quite the salesman. Do you plan to do the welding? ;)
Whatever price you paid seems fair enough? :mrgreen:
deVries
Postby Farfle » Sun Jun 17, 2012 2:05 pm
The reason I kept the price low this round is for a few reasons. First, I have finally settled on a good CNC shop, so I get small parts on a predictable time frame. Secondly, I want to hit a price point. For $350 I want to build a good semi-stretch FS frame with built in dropouts. lemme do a quick interest check, Would there be any interest in a few semi-assembled kit bikes? Something like a DIY package with a genesis frame, a decent headset, maybe a budget front suspension fork?
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Postby deVries » Sun Jun 17, 2012 2:25 pm
Farfle wrote:The reason I kept the price low this round is for a few reasons. First, I have finally settled on a good CNC shop, so I get small parts on a predictable time frame. Secondly, I want to hit a price point. For $350 I want to build a good semi-stretch FS frame with built in dropouts. lemme do a quick interest check, Would there be any interest in a few semi-assembled kit bikes? Something like a DIY package with a genesis frame, a decent headset, maybe a budget front suspension fork?
I think there would be interest if you can discount below the shipping costs & what someone can get locally.
The main thing you have going for you is your custom fab work and reasonable prices. I'd say there would be a hell of a lot more interest in a custom cromoly frame you could offer too. Long wheelbase & Surly fat tire could be awesome too. Motor mount like LFP has or in swing arm.
Definitely doing a SwingArm designed to take some hub/geared motor like JohnCR or a Mac geared belt/chain drive would be awesome too. Don't price yourself high imo. Plenty of rich guys can buy other stuff, but it's much harder for us lower budget guys to afford stuff. We don't need another high-end guy hocking wares on ES that are too pricey for most. Imo. :twisted: Most ES members don't have a lot of money. You're young & can still afford to gain a whole hell-of-va lot more experience making things for less $. Later on, you can make "real money" if you are so motivated, or when you have your own family to support. ES is more fun hobby and not a business. Start small, price low, grow to gain a lot of experience 1st. :mrgreen:
deVries
Postby neptronix » Sun Jun 17, 2012 2:39 pm
I'd definitely be interested in a tough steel frame at that price point, given that it has battery space.
That would be the holy grail for eBikes.
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
PreviousNext
Return to Items for Sale - New
Who is online
Users browsing this forum: ROG130 and 5 guests
