might need two for serious speed in the dark, but one's plenty fine to help me carve a path through traffic in the morning.
GCinDC wrote:get a new CA if you don't have one and save money on batteries and converters... CA plugs right into this, which solders easy to light wire.
boppinbob wrote:I purchased 2 of the 1800 lumen cree's off ebay. They shipped fast from China and they come with a 8v lipo rechargable battery and it comes with a wall wart charger. Very bright. I've had them for a couple of months no complaints. I bought it from
lifebike2011 he is very concerned about his feedback and is a top rated seller with over 12000 positive ratings. PS This sounds like a plug, I know. Just relaying my experience.
http://www.ebay.com/itm/1800-Lumen-CREE-XML-T6-LED-Bike-Bicycle-Light-HeadLight-headLamp-/180872011136?pt=LH_DefaultDomain_0&hash=item2a1ccfdd80#ht_5565wt_1159
Scruffoid wrote:oK
The light is bright enough to be used by itself i am really happy with it. Only issue that i am having is how much power it appears to be drawing.
Anyone else got one of these plugged into the AUX voltage port on their CA. When mine is plug into it is says its using 200W of power. Seems really high LOL.
Scruff
Scruffoid wrote:Nah its all been sorted out with Justin and Hyenas help
Turns out the new Aux Voltage plug on the CA requires the wires to be hooked up in a particular way inside the controllers.
In my case the CA-DP plug had pin 2 and 3 connected at the plug then both connected to gnd in the controller.
To get it to work properly i needed to connect pin 3 to gnd and pin 2 to the mosfet side of the shunt. After doing this i also needed to re zero my CA units amps measurement.
End result is that no the CA says that the light is consuming 9W of power at 75V so all good![]()
Scruff
rui_fujino wrote:I'm planning to solder my own cable to CA...do you know where I need to solder inside the CA?
Scruffoid wrote:rui_fujino wrote:I'm planning to solder my own cable to CA...do you know where I need to solder inside the CA?
There is pretty comprehensive pictures of the internals of the CA's at ebikes.ca
Go and look and see if your version is there.
Not really clear what you are actually thinking of hooking up there TBHPower to light or something else?
Scruff
Architectonic wrote:How are you guys sealing up the back of these lights?
parabellum wrote:Architectonic wrote:How are you guys sealing up the back of these lights?
What for?
rui_fujino wrote:parabellum wrote:Architectonic wrote:How are you guys sealing up the back of these lights?
What for?
you mean for water proofing right?
Return to Items for Sale - New
Users browsing this forum: No registered users and 7 guests
