johnrobholmes wrote:Here is a light I saw on another moped forum. DX special http://www.dealextreme.com/p/10w-800-lu ... 26v-101461
I hear the beam is funky and square, but for that price it is hard to beat.
NeilP wrote:I will at least try and post a beam shot of these against a know lamp
NeezyDeezy wrote:FYI geoman gear has the 1000 lm magic shine on sale this month -- it's better IMO because it ships from the US.
Good, since I have a remote switch on my recumbent bike. One more question - is it relatively white or has the bluish tint ?NeezyDeezy wrote:When it's plugged in it by default comes on high, without buttons, so depending on what you want to do a switch would work.
auraslip wrote:So do one of these lights start in the ON position? I have my current halogen lights and tail lights rigged up with a simple spst switch to my 12v dc-dc. I like this simplicity.
curious wrote:NeezyDeezy wrote:When it's plugged in it by default comes on high, without buttons, so depending on what you want to do a switch would work.
Not sure we are talking about the same light. I just got the MJ-808E XML head from geomangear and it does not "remember" the power setting and always comes in the "off" state when plugged in. The remote switch is not an option.
Few notes for those considering it:
- It takes 0.8A on full at 12.5V, there are 3 levels of brightness and no blinker.
- It has a clearly defined round spot (a bit small to my taste, I am used to flood beam) and rather weak flood area.
- The color in the spot is a pleasant white (warmer than my trailtech HID) with no blue tint (if anything there is a very slight greenish tint to it). There is some blue tint in the flood area but not in the spot.
- Mounting may be a problem for some, the light does not pivot and sits very close to the handlebar (uses rubber rings instead of a usual clamp). It may interfere with the cabling because of proximity to the handlebar (it does on our bikeE recumbent had to move things around to mount it).
NeezyDeezy wrote:Hi, I'm really sorry - I didn't mean to lead you astray. I received my magic-shine 1000 lumen light from geoman gear in September 2011, and it DOES come on high on being plugged in. Something must have changed since then with a newer or different model. If you don't want it and can't return it, I might be able to buy it from you.
Duc998 wrote:Can anyone confirm this light works off the aux off the CA. Looking to keep it simple and if I can wire the light up to the CA that would be great. Mines a CA-DP.
Return to Items for Sale - New
Users browsing this forum: dotrick and 2 guests
