Nice bike light on ebay 24-90V 12w 29.99U$
Re: Nice bike light on ebay 24-90V 12w 29.99U$
Postby Tench » Wed Apr 04, 2012 5:03 am
The one i have also has a 12v rear LED light tapped into it running off the same voltage dropper, then i connected another front led light to switch alternately to act as a low beam with the ebay light as my high beam, this showed up another problem, when i am switched to low beam with the front and rear led's on but the ebay light off the current draw on the voltage dropper is too low to pull the voltage down, i was measuring 50v output :shock: which blew my led's :( so i am going to remove the dropper and put mine on a 3s battery. I will let you know if this makes a difference to the brightness as it will then be able to pull all the current it wants. The dropper was being fed from 18s 75v and appears to be a very poor excuse for a dc dc converter.
Simon.
Project Two viewtopic.php?f=6&t=37489
Project one viewtopic.php?f=28&t=20304&hilit=tench
The uk's first Stealth Bomber
Tench
Postby miuan » Wed Apr 04, 2012 4:06 pm
Simon, the dropper is not at fault. It was already discussed in this thread that it is NOT voltage stabilized, instead it holds stable current to drive the leds it was designed to work with. Since your small leds were too weak to receive such current at 12V, the dropper was increasing the voltage to increase the current until the leds died a quick death. To drive your small leds you will need a 12v stabilized supply, usually a cheap switched wall supply with 300mA or even lower output will do the job.
miuan
Postby NeezyDeezy » Wed Apr 04, 2012 8:30 pm
curious wrote:
NeezyDeezy wrote:When it's plugged in it by default comes on high, without buttons, so depending on what you want to do a switch would work.
Not sure we are talking about the same light. I just got the MJ-808E XML head from geomangear and it does not "remember" the power setting and always comes in the "off" state when plugged in. The remote switch is not an option.
Few notes for those considering it:
- It takes 0.8A on full at 12.5V, there are 3 levels of brightness and no blinker.
- It has a clearly defined round spot (a bit small to my taste, I am used to flood beam) and rather weak flood area.
- The color in the spot is a pleasant white (warmer than my trailtech HID) with no blue tint (if anything there is a very slight greenish tint to it). There is some blue tint in the flood area but not in the spot.
- Mounting may be a problem for some, the light does not pivot and sits very close to the handlebar (uses rubber rings instead of a usual clamp). It may interfere with the cabling because of proximity to the handlebar (it does on our bikeE recumbent had to move things around to mount it).
Hi, I'm really sorry - I didn't mean to lead you astray. I received my magic-shine 1000 lumen light from geoman gear in September 2011, and it DOES come on high on being plugged in. Something must have changed since then with a newer or different model. If you don't want it and can't return it, I might be able to buy it from you.
NeezyDeezy
Postby curious » Wed Apr 04, 2012 11:55 pm
NeezyDeezy wrote:Hi, I'm really sorry - I didn't mean to lead you astray. I received my magic-shine 1000 lumen light from geoman gear in September 2011, and it DOES come on high on being plugged in. Something must have changed since then with a newer or different model. If you don't want it and can't return it, I might be able to buy it from you.
Don't worry, I'll find the use for both units that I got :). One goes on my wife's bikeE and does not need a remote switch. For the other unit I'll figure out something. I actually do like the color temperature of this light (in the main spot). Many other LED lights I've seen produce bluish tint (or just very cold white beam) that makes things look ghostly and unnatural. This one is noticeably warmer and has some very slight green tint which makes grass and foliage look nice at night :)
bike1: hardtail frame, 5304 rear, 850wh a123 66v/33v switchable, Kelly KEB72601, proportional regen;
bike2: bikeE FX recumbent, sensored bafang front on a 16" rim, 16s a123;
bike3: work in progress (slow), long range SWB touring recumbent, >1.5kwh pack TBD, Kelly KBS72101, likely HT35 hub, proportional regen.
curious
Postby Duc998 » Thu Apr 12, 2012 8:26 am
Can anyone confirm this light works off the aux off the CA. Looking to keep it simple and if I can wire the light up to the CA that would be great. Mines a CA-DP.
Giant DH Comp 03 build in progress 72v 18s3p 9C 9x7 12fet Infineon controller set 45amps
Duc998
Postby veloman » Thu Apr 12, 2012 11:54 am
Did anyone test it's water resistance? The ebay ad states you need to waterproof it. I'd hate to get caught in rain and kill the light.
FYI, it's on ebay again for $33.99
Mush! Mush you electrons! Push harder!
Main ride: Old School Specialized Stumpjumper FSR, Clyte HT3540, 63v lifepo4, 12fet Infineon set to 26amps. And a bunch of others... viewtopic.php?f=6&t=34236&p=497325#p497325.
veloman
Postby GCinDC » Fri Apr 13, 2012 8:40 am
Duc998 wrote:Can anyone confirm this light works off the aux off the CA. Looking to keep it simple and if I can wire the light up to the CA that would be great. Mines a CA-DP.
I measured 80V (pack voltage) from the aux jack (which I have on my large screen CA, but do not see documentation for, except as an upgrade on in the store:
And since someone cited that it draws 10W, seems like it would work! I'm going to go for it. :mrgreen:
Youtube channel, 2011 Highlights vid. Ebike Nerdcast.
Giant DH Comp: 20s lipo (10Ah), hs3540, 72V 45A 12FET, 900W BMSBattery charger.
GT I-Drive, 20s lipo, 9C, 72V 45A 12FET.
GCinDC
1 GW
1 GW
Postby Tench » Fri Apr 13, 2012 8:47 am
I measured the current draw on mine at under 0.14 amp at 74v, the CA states that upto 500ma can be drawn off the pack voltage wire in the CA so yes you should be able to run it from there.
Tench
Postby Duc998 » Fri Apr 13, 2012 9:15 am
Supersweet thanks guys. I would like the strobe function but ah well can't complain at this price.
Duc998
Postby bobale » Fri Apr 13, 2012 12:16 pm
Some beamshots would be nice :).
RWD 2807 9Continent rolling on Kenda Flame 26x2.125
12S3P out of Turnigy 4S Hardcase 20C (600Wh)
35A 9FET Infineon Controller (Regen, Cruise control, Speed limit)
Top Speed 27mph (31mph@120%)
bobale
Postby Scruffoid » Sat Apr 14, 2012 3:14 am
OK Just bought one of these babies.
I have a nice DSLR camera here as well.
I will post pictures of the beam on this compared to my Led Lenser H14 Beams which is what i currently and using ( 3 of them ).
I bought one of these as it runs from the bike battery so i plan on running 4 lights on teh freeway when im riding home at night. Ill look like a truck to oncoming cars but lucky there on the other side of the road.
Scruff
Hyena Electric Ebike Kit
Crystalyte 3525 Pimped out / 12 FET infineon / xie chang board with 4110 Fets / 22S3P - 90V/15AH Lipo
4KW (45A limited) - 67Km/Hr Max
Build Thread - http://endless-sphere.com/forums/viewtopic.php?f=6&t=38000&p=553791#p553791
Scruffoid
Postby 7lions » Wed Apr 25, 2012 9:03 pm
I picked one of these up and have just started commuting with it. I'm very pleased - its a much more functional "see" headlight than my magicshine, which I'll now mount on my helmet and use as a directed spot.
I did find that the two screws lined up perfectly with the cutouts in my Minoura Space Grip, so I screwed it directly on to the front. That left the bar free for other accessories, and still give up/down adjustment. I'll try and post pics later - the trike got trapped at work by a surprised thunderstorm.
7lions
Postby bobale » Thu Apr 26, 2012 6:20 pm
Scruffoid, 7lions, Image.
bobale
Postby Icewrench » Fri Apr 27, 2012 2:13 pm
There`s a beam shot.
No tripod involved.
Icewrench
Postby chroot » Fri Apr 27, 2012 2:25 pm
Hi- I bought 2 Solarforce L2P with Manafont UF 3 mode Drop-in. HOLY BAT! It blows! It cost me 19 dollars each on Solarforce L2P flashlight + 16 dollars Manafont UF 3 mode drop-in. I love this flashlight really throw and floody combine.
Solarforce L2P links: http://www.solarforce-sales.com/product_detail.php?t=FB&s=7&id=417
Manafont UF 3 mode P60 Drop-in links: http://www.manafont.com/product_info.php/ultrafire-cree-t6-3mode-memory-led-dropin-module-42v-max-p-5178
I like Justin@ebikes.ca Lumenator but this thing cost fortune compare to mine bang for the buck which it is cheap with excellent throw and floody.
Here the beamshot.
Thank you Justin Lemire-Elmore - You are a HERO!
Tidalforce, Yuba Mundo V4 Cargo bike, Juiced Riders ODK V1 Cargo bike
English is my secondary language - ASL (American Sign Language) is my primary.
chroot
Postby bobale » Fri Apr 27, 2012 3:33 pm
Icewrench, thanks for the beamshot. Chroot, just to clear this up, the beamshot is of the 24-90V 12W light, or of your drop-in flashlight?
bobale
Postby GCinDC » Sat Apr 28, 2012 1:59 pm
runs fine off CA DC out as well. now i have to sort out connection/mount. not sure where to get 2.1mm female and think i'll probably just hardwire it, or use andersons... i think i'll end up cutting a lot of the extra cable before and after the driver..
GCinDC
1 GW
1 GW
Postby Alan B » Sat Apr 28, 2012 2:07 pm
Radio Shack generally carries the 2.1 female connectors.
Alan B
1.21 GW
1.21 GW
Postby parabellum » Sat Apr 28, 2012 2:24 pm
GCinDC wrote: i think i'll end up cutting a lot of the extra cable before and after the driver
Right, good place to start is opening those shrink wrapped connections between driver cable and light, in my it was just twisted wire connection with no solder on it, would got apart with just slight pull. :)
parabellum
Postby bobale » Sat Apr 28, 2012 2:35 pm
This light doesn't come with back cover, and holder on pictures on eBay?
bobale
Postby Icewrench » Sat Apr 28, 2012 3:30 pm
Just a bracket like this..
Icewrench
Postby Duc998 » Sun Apr 29, 2012 8:19 pm
Hey GC I just got mine too, Thanks for you input. Are you going to wire up a on/off switch? I'll need to do one as I'm sure I'll get clothes lined by someone when commuting through the center of Sydney CBD :lol:
Duc998
Postby kevo » Sun Apr 29, 2012 10:40 pm
Good find, nice price for a very decent light!
Thanks Justin of http://ebikes.ca for your amazing talents, dedication and contributions to ES!
Post licensed under "Open Source" http://creativecommons.org/licenses/by-nc-nd/3.0/
kevo
Postby shorza » Mon Apr 30, 2012 12:11 am
download/file.php?id=82030
Judging by the dc-dc converter, it was made to handle between 48v and 72v.
http://translate.googleusercontent.com/ ... A27Mh8QpYg
shorza
Postby Duc998 » Mon Apr 30, 2012 2:42 am
shorza, disregard the dc-dc convertor in that pic, The light has its own dc-dc drive ( that black thing in the shrink wrap as per pic from the ebay seller ). The ebay seller also sells dc-dc convertors so I thought since I'm buying the light from him I'll grab a dc-dc convertor too just incase I change my mind on the light or decide to use the dc-dc convertor elsewhere.
Duc998
PreviousNext
Return to Items for Sale - New
Who is online
Users browsing this forum: No registered users and 2 guests
