Nice bike light on ebay 24-90V 12w 29.99U$
Re: Nice bike light on ebay 24-90V 12w 29.99U$
Postby bobale » Fri Apr 27, 2012 3:33 pm
Icewrench, thanks for the beamshot. Chroot, just to clear this up, the beamshot is of the 24-90V 12W light, or of your drop-in flashlight?
RWD 2807 9Continent rolling on Kenda Flame 26x2.125
12S3P out of Turnigy 4S Hardcase 20C (600Wh)
35A 9FET Infineon Controller (Regen, Cruise control, Speed limit)
Top Speed 27mph (31mph@120%)
bobale
Postby GCinDC » Sat Apr 28, 2012 1:59 pm
runs fine off CA DC out as well. now i have to sort out connection/mount. not sure where to get 2.1mm female and think i'll probably just hardwire it, or use andersons... i think i'll end up cutting a lot of the extra cable before and after the driver..
Youtube channel, 2011 Highlights vid. Ebike Nerdcast.
Giant DH Comp: 20s lipo (10Ah), hs3540, 72V 45A 12FET, 900W BMSBattery charger.
GT I-Drive, 20s lipo, 9C, 72V 45A 12FET.
GCinDC
1 GW
1 GW
Postby Alan B » Sat Apr 28, 2012 2:07 pm
Radio Shack generally carries the 2.1 female connectors.
Alan B
1.21 GW
1.21 GW
Postby parabellum » Sat Apr 28, 2012 2:24 pm
GCinDC wrote: i think i'll end up cutting a lot of the extra cable before and after the driver
Right, good place to start is opening those shrink wrapped connections between driver cable and light, in my it was just twisted wire connection with no solder on it, would got apart with just slight pull. :)
parabellum
Postby bobale » Sat Apr 28, 2012 2:35 pm
This light doesn't come with back cover, and holder on pictures on eBay?
bobale
Postby Icewrench » Sat Apr 28, 2012 3:30 pm
Just a bracket like this..
Icewrench
Postby Duc998 » Sun Apr 29, 2012 8:19 pm
Hey GC I just got mine too, Thanks for you input. Are you going to wire up a on/off switch? I'll need to do one as I'm sure I'll get clothes lined by someone when commuting through the center of Sydney CBD :lol:
Giant DH Comp 03 build in progress 72v 18s3p 9C 9x7 12fet Infineon controller set 45amps
Duc998
Postby kevo » Sun Apr 29, 2012 10:40 pm
Good find, nice price for a very decent light!
Thanks Justin of http://ebikes.ca for your amazing talents, dedication and contributions to ES!
Post licensed under "Open Source" http://creativecommons.org/licenses/by-nc-nd/3.0/
kevo
Postby shorza » Mon Apr 30, 2012 12:11 am
download/file.php?id=82030
Judging by the dc-dc converter, it was made to handle between 48v and 72v.
http://translate.googleusercontent.com/ ... A27Mh8QpYg
shorza
Postby Duc998 » Mon Apr 30, 2012 2:42 am
shorza, disregard the dc-dc convertor in that pic, The light has its own dc-dc drive ( that black thing in the shrink wrap as per pic from the ebay seller ). The ebay seller also sells dc-dc convertors so I thought since I'm buying the light from him I'll grab a dc-dc convertor too just incase I change my mind on the light or decide to use the dc-dc convertor elsewhere.
Duc998
Postby GCinDC » Mon Apr 30, 2012 12:13 pm
Alan B wrote:Radio Shack generally carries the 2.1 female connectors.
so they do. thanks, AB. god help you if you need to find one in the shelves tho... took me 20 min!
Duc998 wrote:Are you going to wire up a on/off switch?
was planning on it after i figured out the mounting, but now that i've got the female connector, might be easy enough to yank power if i need to go dark. :twisted:
thanks for posting the bracket pic. i woulda never figured that out! mighta been nice if it came w/ a couple screws! :lol:
GCinDC
1 GW
1 GW
Postby Tench » Mon Apr 30, 2012 4:25 pm
I have made some modifications to mine, i added a low beam of a "Halo" design around the housing, when i first did this and switched it on it blew the led string because of the rise in the output voltage from the dropper. I have now removed the dropper and got my lights onto a 3s battery, this has also given me a constant brightness on the rear light regardless of the different current draw of the high and low beam front lights.
Pics of the rear light in my build thread.
Project Two viewtopic.php?f=6&t=37489
Project one viewtopic.php?f=28&t=20304&hilit=tench
The uk's first Stealth Bomber
Tench
Postby bobale » Mon Apr 30, 2012 8:18 pm
Now that's a neat add-on, I really like it. Can you post more details?
bobale
Postby Tench » Tue May 01, 2012 1:33 am
Hi bobale, this is the led strip i used;
http://www.ebay.co.uk/itm/320619197082
mounted into a simple collar secured with 2 screws.
Simon.
Tench
Postby bobale » Tue May 01, 2012 6:12 am
bobale
Postby GCinDC » Tue May 01, 2012 7:49 pm
get a new CA if you don't have one and save money on batteries and converters... CA plugs right into this, which solders easy to light wire.
might need two for serious speed in the dark, but one's plenty fine to help me carve a path through traffic in the morning.
GCinDC
1 GW
1 GW
Postby boppinbob » Tue May 01, 2012 8:05 pm
I purchased 2 of the 1800 lumen cree's off ebay. They shipped fast from China and they come with a 8v lipo rechargable battery and it comes with a wall wart charger. Very bright. I've had them for a couple of months no complaints. I bought it from
lifebike2011 he is very concerned about his feedback and is a top rated seller with over 12000 positive ratings. PS This sounds like a plug, I know. Just relaying my experience.
http://www.ebay.com/itm/1800-Lumen-CREE-XML-T6-LED-Bike-Bicycle-Light-HeadLight-headLamp-/180872011136?pt=LH_DefaultDomain_0&hash=item2a1ccfdd80#ht_5565wt_1159
Project bike-Genesis v2100, Crystalyte HS 3540 with 72v40A controller and four 5s8Ah zippy lipos in series.
boppinbob
Postby aroundqube » Tue May 01, 2012 8:26 pm
Thanks for that find boppinbob. Looks alot more like what I have been looking for.
aroundqube
Postby ohzee » Tue May 01, 2012 9:04 pm
GCinDC wrote:get a new CA if you don't have one and save money on batteries and converters... CA plugs right into this, which solders easy to light wire.
Thanks GC - I have one of these lights coming and I have one of the newer CA's with the adapter.. Looks like I need to get to radioshack.
ohzee
Postby parabellum » Tue May 01, 2012 10:43 pm
boppinbob wrote:I purchased 2 of the 1800 lumen cree's off ebay. They shipped fast from China and they come with a 8v lipo rechargable battery and it comes with a wall wart charger. Very bright. I've had them for a couple of months no complaints. I bought it from
Have you tried them? I have xml 6 based flashlights with similar reflector shape but the beam is to narrow and concentrated in 1 point for headlight use (have posted picture somewhere at the beginning of this tread). Maybe a picture of your light in use?
parabellum
Postby parabellum » Tue May 01, 2012 10:57 pm
Almost forgot, XML t6 is actually about 800-1200 lumen at room temperature, with very optimistic 100 lumens per watt efficacy (in perfect laboratory condition I suppose). I can think of 1800 lumens output in freezing condition at -40C and lot of current killing efficacy. :D
http://www.cree.com/~/media/Files/Cree/ ... ampXML.pdf
parabellum
Postby chroot » Tue May 01, 2012 11:15 pm
wow limit throw lumen area? My solarforce L2P with Manafont Ultrafire drop-in XM-L P60 host and they throwy and floody. I would say near 800-1000 lumen area but don't have the lumen measure. I'll take picture with MTBR's standard preset ISO 100 and 6 seconds exposure and f4/6 shutter setting to compare yours.
@Greg- Thanks for the picture and perfect for me to compare yours to my solarforce L2P flashlight with modded manafont UF drop-in.
Thank you Justin Lemire-Elmore - You are a HERO!
Tidalforce, Yuba Mundo V4 Cargo bike, Juiced Riders ODK V1 Cargo bike
English is my secondary language - ASL (American Sign Language) is my primary.
chroot
Postby Scruffoid » Wed May 02, 2012 8:18 am
OK Got my light fitted and working on my bike.
Here is a snap i took about 30 minutes ago with it.
Will let you know what it is like to ride with after the ride home tonight, But i think it doesnt look to bad. Its actually raining here as well so i will give it a good run tonight in the wet :)
Scruff
Hyena Electric Ebike Kit
Crystalyte 3525 Pimped out / 12 FET infineon / xie chang board with 4110 Fets / 22S3P - 90V/15AH Lipo
4KW (45A limited) - 67Km/Hr Max
Build Thread - http://endless-sphere.com/forums/viewtopic.php?f=6&t=38000&p=553791#p553791
Scruffoid
Postby Scruffoid » Wed May 02, 2012 8:22 am
As a comparison this is a pic of the Led Lenser H14 lamp which is rated at 200 Lumens. I would trust that the 200 Lumen rating on this device is factual.
This is a focusable light and it is not zoomed in at all in this shot.
Scruff
Scruffoid
Postby rui_fujino » Thu May 03, 2012 4:37 pm
This seems to be great deal, I've already got a strong light like this but I use normal batteries to power it and cos of that, the brightness of the battery decreases as battery dies...I was wondering if I should buy this and forget my headlight or buy this and replace the light with mine?
Project 1: Apollo slant hard tail MTB 52v lifepo4, conhismotor, 52T-11T gearing 39.6mph top speed (with pedal)
Project 2: Diamondback s:10 Full suspension 20s2p (83.5v 10ah Lipo), 35kg, HS3540 sensored (MethTek), 12FET lyen controller, Bulk 600w balance charger.
Top speed 45mph(72.4km/h)
Project 3: DOPPELGANGER d2 Visceral
Project 5 Specialized Epic20s2p (83.5v 10ah Lipo), 30kg,HS3540 sensored (MethTek), 12FET lyen @ 50A
rui_fujino
PreviousNext
Return to Items for Sale - New
Who is online
Users browsing this forum: No registered users and 4 guests
