Moped Rims and Wheels, 36 hole, 16" 17" 18" 19"
Re: Moped Rims and Wheels, 36 hole, 16" 17" 18" 19"
Postby grindz145 » Thu Feb 23, 2012 10:07 am
gensem wrote:John, prebuilt black moped wheels would rock!
+1 There just is a bigger market for prebuilt stuff. I'm of course willing to dig, but I see you're wheels as recommended equipment for high-power builds.
http://www.endless-sphere.com/forums/viewtopic.php?f=18&t=19548 - Ebike Nerd Podcast
Thanks to Justin @ ebikes.ca! Go there, buy stuff. Support the Revolution :D
grindz145
Postby johnrobholmes » Thu Feb 23, 2012 10:15 am
Right on, I will see what we can pull together when the parts arrive. I could probably charge less for them if I get a worker to help me, and get some spokes precut instead of having to bang em out on my machine.
_______________________
Volt up, gear down!
http://www.HolmesBikes.com -- Custom 15 -12ga spokes
http://www.VoltRiders.com -- Custom wheels, ebikes, and Mopeds
johnrobholmes
Postby auraslip » Fri Feb 24, 2012 6:15 pm
I'm gonna order a set of rims from you. Could you divulge a good set/size of spokes to use with a dmr revolver hub and 16" rim? Spokes get expensive in the bicycle world, but I have a feeling they can be had for less in the motorcycling world.
auraslip
1.21 GW
1.21 GW
Postby johnrobholmes » Fri Feb 24, 2012 6:19 pm
I would need to know the ERD of the rim. One of my steel rims, or one of the alloy ones coming, or one you pick up yourself?
Volt up, gear down!
johnrobholmes
Postby auraslip » Fri Feb 24, 2012 6:25 pm
One of your rims. You have alloy ones coming? I guess I should wait for those. When are they due?
auraslip
1.21 GW
1.21 GW
Postby johnrobholmes » Fri Feb 24, 2012 6:29 pm
The protos should arrive at any time for approval, and then it will take 6 to 8 weeks for the main production.
Volt up, gear down!
johnrobholmes
Postby grindz145 » Fri Feb 24, 2012 8:17 pm
johnrobholmes wrote:The protos should arrive at any time for approval, and then it will take 6 to 8 weeks for the main production.
Hey man can you quote me a wheel build with your 17x1.4" moped wheels and a DMR hub, black spokes and painted black wheel ideally?
grindz145
Postby johnrobholmes » Mon Feb 27, 2012 12:05 pm
With the alloy rims it would be $281 plus shipping. With the steel it would be $241 plus shipping.
Volt up, gear down!
johnrobholmes
Postby Microbatman » Sat Mar 03, 2012 11:32 pm
What guage spoke would you reccommend for Cromotor on 17inch rim?
MotorCrystalyte X5304 20 Inch Rear Wheel DISC Brake Controller Crystalyte 48A72V4110MOSFETS
Batteries A123 24s2p
Charger Mastech 5020
Frame Azonic Steelhead
Grateful/fortunate/blessed to have the resources and family support to enjoy my ebike hobby
Microbatman
Postby auraslip » Sun Mar 04, 2012 1:12 am
Is that per wheel?
auraslip
1.21 GW
1.21 GW
Postby johnrobholmes » Thu Mar 08, 2012 1:36 pm
12ga spokes work well for most light weight rims, but 13ga could work too depending on the total gross weight and vehicle speed.
Yes, that is a per wheel cost. Knock off $100 if you want to lace it yourself.
Volt up, gear down!
johnrobholmes
Postby auraslip » Mon Mar 26, 2012 5:41 pm
Do you have any pricing and weight info for the 18" alloy rims?
auraslip
1.21 GW
1.21 GW
Postby alwhite » Mon Apr 02, 2012 7:08 am
How much for a 19 inch 36 hole steel rim ?, also shipping to 86442.
Thank you in advance
alwhite
Postby hjns » Fri Apr 06, 2012 3:03 pm
Hi John and others,
Just wondering. I would like to make small jumps with my 20 pound rear Crystalyte HT3525 when my front fork (Fox F100 Terralogic) comes back from service. However, I am afraid that with the current crap Chinese lacing, I will break either the spokes or the rim. I myself weigh about 70kg, with a bike of about 10kg, a Lipo pack of 10kg, and the mentioned rear hubmotor (another 10kg). That means that after a jump, the lacing + rim of my rear wheel should be able to withstand the initial impact of 10kg hub/motor without suspension, and the remaining 90kg directly after that with the help of my rear supsension (Fox FLOAT 6.5"). Oh, and on tarmac I reach top speeds of 75km/h, so I prefer a rear wheel that manages that without issues.
My question: what rim, spokes, and tire would you recommend for a 26" outer diameter 2.5" max width configuration if you assume quality is the highest priority? Would these MoPed rims and spokes suffice? And how much would that cost? Thanks very much in advance for your answers!
Henk
High speed commuter w/ modified Lyen 18 FET 4110, 12AWG traces, extra Caps, beefed up shunt, modified Cromotor w/ thermistor, 10AWG phase wires. CAv3B22 with power-throttle limited to 8kW and 130oC motor winding temp, w/ GPS-enabled CA analogger. 20S 13.5Ah Lipo Zippy pack. Fusion FS frame, Fox RL rear shock, Fox F100 front fork, Schwalbe Fat Bob tires, HALO SAS 26inch rims with custom 12G(r) and 14G(f) black Sepim spokes from JRH and laced myself.
Commuter Cromotor build
hjns
Postby johnrobholmes » Tue Apr 10, 2012 5:54 pm
I've been elbows deep building wheels and waiting for prototype rims and the spoke order lately, apologies for the latent response.
I don't have a good recommendation for you right now hjns, when I get the 19's in I feel I can make a better recommendation. Not sure how tall they will end up.
All I have in stock right now is steel 17's and 16's, listed on the site. The silver alloy 18's still haven't been put up there, all alloys are $80 and up.
Volt up, gear down!
johnrobholmes
Postby hjns » Tue Apr 17, 2012 10:03 am
I ordered some custom length Sepim 12 AWG spokes from John on the 12th of April. Spokes were delivered in Basel, Switzerland today (17th). Thanks John, for the superfast delivery!!
Henk
hjns
Postby MattyCiii » Wed Apr 18, 2012 7:53 am
JRH,
I'm highly interested in the 18" diameter, 1.6" width, black anodized mentioned on page 1. I'd buy 2 right away. Did you get enough interest to move forward on these?
~Matt
1st build: Dahon Jetstream folding bike. Quick, reliable, capable of 30mph. Light enough to lift, folds for easy transport by car/bus/train.
2nd build: RC powered 2009 Norco A-Line. Top speed 31mph. Built like a tank, it's resistant to Boston potholes, can stop on a dime, easily goes up/down curbs when necessary.
3rd build (just started): Scratch build ultimate utility bike.
MattyCiii
Postby Brentis » Wed Apr 18, 2012 8:05 am
Apologies if it was covered in the thread. I read OP but it doesn't answer a ? that can help me & maybe others out.
Is it possible for you to lace a X5 to a 14" MX rim? How about a H series or 9c?
I'd like to potentially convert a pitbike that use 12"/14" knobbies.
Ever done a lace job like a this? :wink:
Thanks John.
:mrgreen:
Ghetto Build 1.
ScootBike Build 2...
Strong Commuter Build 3...
Brentis
Postby johnrobholmes » Wed Apr 18, 2012 8:08 am
I'm still waiting on prototypes (for some unknown reason), I absolutely am trying to move forwards with this in all sizes. I don't want to plunk down so much cash without protos first :mrgreen:
Ive never tried a 14" rim. It would be tough. 16's are already small enough, I don't even know if a 14 could fit around it!
Volt up, gear down!
johnrobholmes
Postby MattyCiii » Wed Apr 18, 2012 8:11 am
Thank you John!
I only just "discovered" I need larger wheels, so I have not suffered the wait for prototypes/stock wheels. I'll definitely be in for two when you've got the stock.
~Matt
MattyCiii
Postby cbr shadow » Wed May 09, 2012 10:54 am
John, I've sent you several PM's and emails through your website in the last 3 weeks but can't get a hold of you. What's the best way to communicate?
cbr shadow
Postby binlagin » Wed May 09, 2012 4:28 pm
I PM'd John late last week and he stated he was out of the country for at-least a week.
Greyborg Motor, 18-FET Lyen Controller
Turnigy 20C @ 30S x 2P
Giant Team DH Bike, Kiwi Dropout adapters
100km/h+
binlagin
Postby johnrobholmes » Fri May 11, 2012 11:47 am
Just got back into town, I'll be back at work Monday. I'll go through emails and respond, but if your question is a "how do I order" email it may get ignored. Please just buy directly from the site. If it isn't on the site yet it isn't available for sale.
Volt up, gear down!
johnrobholmes
Postby neptronix » Sat Jun 02, 2012 3:30 am
Hm... what would give me 22" equivalent? a 2.5" wide/tall moped tire on an 18" rim?
Are you stuck on a DMR revolver? i found this hub and it looks rather beefy..
http://www.universalcycles.com/shopping/product_details.php?id=12521&category=80
Alternately, could a shimano deore do?
I want to run about 20 horsepower.. wondering if this is even doable with bike hubs and spokes.
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Postby johnrobholmes » Sat Jun 02, 2012 7:27 am
Yeah, an 18" would be your best bet.
The DMR hubs are the only front QR20 with 36 hole I can find in the states.
Just got word my prototype rims are here in the states. So when they say 6 weeks for prototyping they mean about 6 months :roll:
Volt up, gear down!
johnrobholmes
PreviousNext
Return to Items for Sale - New
Who is online
Users browsing this forum: friendly1uk and 8 guests
