RWP wrote:Can anyone help with the charger technology for these cells?
Thanks, Roy
neptronix wrote:...
Also, what is the C rate for charge? we do not know this - but you will have to account for that is well. Most chemistries can be charged at at least 1C, i'm sure these can be charged at 1C as well, but we need to know for sure.
recumpence wrote:They are 2c or 3c charge capable.
Matt
When using LiPo packs, we recommend that you:
Set the cut-off above 2.5V, or nearer 3V in most situations.
Avoid designing your pack so that it has to operate at the maximum allowable discharge
rate.
Stay out of the “zone of temptation.”
cwah wrote:I'd like to order but I don't know how to solder these cell together. Is there a tutorial somewhere to learn how to do that? Or would they create the right pack for us? And I suppose a BMS would be required?
ps: I'm interested on the biggest cell with the highest volumetric density (wh/kg)
ohzee wrote:cwah wrote:I'd like to order but I don't know how to solder these cell together. Is there a tutorial somewhere to learn how to do that? Or would they create the right pack for us? And I suppose a BMS would be required?
Yea I asked the same question earlier. Seems like bare cells , but I was just hoping.
For pre built packs like this sounds like cell man offers the best product.
cell_man wrote:The 2C constant energy type cells are 165Whrs/kg according to the specs on the first page. The power cells are 148Whrs/kg according to my calcs, 13% better than A123 20Ah pouch cells. Attached is the data sheet, just to put the info out there so there is no confusion as to how they stack up.
sangesf wrote:cell_man wrote:The 2C constant energy type cells are 165Whrs/kg according to the specs on the first page. The power cells are 148Whrs/kg according to my calcs, 13% better than A123 20Ah pouch cells. Attached is the data sheet, just to put the info out there so there is no confusion as to how they stack up.
(i.e. "my cells" rock.. (e.g. Longer cycle life/higher c-rate capability).. LOL)
Return to Items for Sale - New
Users browsing this forum: No registered users and 5 guests
