Jeremy Harris wrote:Sounds pretty good, John. Any chance of some pictures, or maybe a drawing of the outline of the motor with some dimensions, please? I may be interested in one, but would want to lace it to an 18" moped rim.
John in CR wrote:Jeremy Harris wrote:Sounds pretty good, John. Any chance of some pictures, or maybe a drawing of the outline of the motor with some dimensions, please? I may be interested in one, but would want to lace it to an 18" moped rim.
Yes I'm going to put pics and stuff in the reserved post above. There aren't spoke flanges, but instead a single thick 4 bolt flange for the rim, which I believe is a 4 bolt 190mm pattern. My calipers don't reach around to measure with enough accuracy to quote though. If the 18 on mopeds is measured like a bicycle wheel, then that would work fine, but if it's like motos, which I expect, then I'd discourage that large a wheel. The Kv is just too high and performance will suffer terribly in what would be what, a 23" OD wheel. If you want to run that size wheel mid-drive is the way to go. IMO mid-drive is where it will ultimately shine the most, because it opens up the potential for high voltages where common hubbies start overheating. The 10" scooter wheel on mine works out to almost a 17" OD wheel. A 23" wheel puts things out in the 70mph range in high in a 23" wheel at 75V, which isn't reasonable without a very aero shell, not at this power level.
Maybe think Hanebrink type bike but with a hubbie as one neat option for in-wheel use while looking more like a fat tire bicycle than a Hanebrink. I'm sure someone will do something like that. I know I want to build one.
John
cassschr1 wrote:What size dropouts are going to be needed?
John in CR wrote:
Custom clamping dropouts is the way to go, and a steel moped frame may be the easiest route if you have limited metal fabrication capacity. Maybe we can get Farfle to do up a batch of customer Genesis swingarms to fit for those insisting on starting with a bicycle.
Jeremy Harris wrote:John in CR wrote:Jeremy Harris wrote:Sounds pretty good, John. Any chance of some pictures, or maybe a drawing of the outline of the motor with some dimensions, please? I may be interested in one, but would want to lace it to an 18" moped rim.
John
Thanks for the honest reply John, maybe I'll re-think things. Having been digging around a bit, is this motor basically similar to the XM2000 motor (info here on a strip down: http://visforvoltage.org/sites/default/ ... ection.pdf ) and the motor in these two threads: viewtopic.php?f=2&t=4516 and viewtopic.php?f=28&t=16807 ?
gensem wrote:John do you plan on having bigger motors available?
Jeremy Harris wrote:I have to say that I'm impressed with the internals of that motor, much better looking and beefier than typical ebike hub motors, with an impressive amount of copper in there. A larger diameter one with spoke flanges would suit me perfectly..................
John in CR wrote:I'll put you on the 20kw hubbie wish list then. Start thinking in terms of wheels 20" OD and smaller, then hubmotors you want do exist, or mods are very easy. Some will run the larger wheels too as long as you don't have steep mountains or larger loads than me (or is it I ?), but the motor is strained, and the performance difference is substantial. It's like swinging an oversized prop, and if you get caught on a hill behind a slow truck, the controllers scream for help.![]()
John
spinningmagnets wrote:With two speeds, low-kV, factory temp-probe, and having an outrunner diameter / width of a dollar bill, this has got to be the best possible motor for a longtail cargobike. Since it has a reverse switch, I assume it is neutrally timed, and that makes a mid-hub an easier adaptation.
http://endless-sphere.com/forums/viewtopic.php?f=3&t=32220#p466764
http://endless-sphere.com/forums/viewtopic.php?f=1&t=9673
John, would you see any problems running this at 48V with a 12-FET?
Return to Items for Sale - New
Users browsing this forum: Yahoo [Bot] and 8 guests
