Hyena's super awesome isolated high current balance charger
Re: Hyena's super awesome isolated high current balance char
Postby Staunch Trooper » Tue Jun 26, 2012 8:43 pm
OOh, hot unit, is that the one destined for westmont choppers?? Image
Staunch Trooper
Postby fabiograssi » Tue Jun 26, 2012 9:49 pm
1 for me!
PM sent!
fabiograssi
Postby skyliner » Wed Jun 27, 2012 3:09 am
1 for me.
PM sent.
skyliner
10 µW
10 µW
Postby grindz145 » Wed Jun 27, 2012 6:30 am
Hmm that looks pretty similar. I HAVE to get one of these.
http://www.endless-sphere.com/forums/viewtopic.php?f=18&t=19548 - Ebike Nerd Podcast
Thanks to Justin @ ebikes.ca! Go there, buy stuff. Support the Revolution :D
grindz145
Postby AmpeD » Thu Jun 28, 2012 3:42 am
im a bit of a noob, but should i get this or the hyperion 1420. going to using 12s lipo
AmpeD
10 µW
10 µW
Postby jonescg » Thu Jun 28, 2012 4:07 am
If you want to balance all of them at once, get the Hyperion. If you don't mind plugging and unplugging half the pack after an hour or so, one of these would work fine. Cost is about the same, really.
Voltron the Electric RG250 - Dual Agnis, Kelly 1200A controller, 6 kWh of A123 cells from Cell_Man and a shitty old chassis from 1985 :| Top speed 180 km/h, max current 600 A @ 100 V.
VoltronII 8)
Say no to spaghetti junction LiPo! Assembled Hi-power LiPo packs of any size!
Come on Casey! If you want prototype racing, throw your leg over something with lithium in it :D
jonescg
Postby knoxie » Thu Jun 28, 2012 4:43 am
Yes in theory you could disconnect the serial link between the packs, bridge the taps and then parallel balance the whole pack with the balancer but then of course you must remember to disconnect them before you make the serial connection again :lol: been there done that and melted balance wires.
Electric KMX 72V Lipo, USPD drive unit. BMX 72V, Puma BMC,
Raleigh 26 inch MTB Puma 50V Turnigy 25C Lipo 10AH, Trek MTB, X5 48V NIMH. Electric BMX
http://tinyurl.com/4vrmc8 http://tinyurl.com/3umm4n
knoxie
Postby nechaus » Fri Jun 29, 2012 6:57 pm
After watching that video..im glad i got 2 of them
It does a much better job than my big icharger..
Like first time charge its going to be fairly well balanced depending on each cell condition
Magic pie Dual Suspension
Peak 6kw Air cooled
Kelly controller (mini kbs series, smaller than a coke can, can do 80+ battery amps peak, Favorite small controller. Really punchy)
20s 16ah
60 kmh,
Safe, Beautiful handling.
nechaus
Postby full-throttle » Wed Jul 18, 2012 11:20 pm
Hyena wrote:
drewjet wrote:I would be very careful about that. I use FMA Balance Pro chargers (similar). The negative for the first cell is not isolated, so if you hook them up to the same power supply one of them goes BOOM!
Correct you are good sir, I just tested it and found it is as you say. So they're only isolated within themselves as a 6S balance charger. So if you want to run 2 units you'd need to use 2 seperate power supplies.
The unit I've got is def isolated between the power supply and the pack.
full-throttle
Postby Hyena » Wed Jul 18, 2012 11:41 pm
Curious...
Is yours the same as mine or the FMA drewjet posted about ?
I only tested the first demo unit I got, I have another one here that just arrived from the the main batch so I'll have to check that.
www.HyenaElectricBikes.com
Aussie high powered and custom e-bike kits
My build and HD video thread__. My youtube channel
Hyena
10 GW
10 GW
Postby full-throttle » Thu Jul 19, 2012 12:51 am
Same as yours. The PCB revision is A04.
It's nicely made. Wonder how it goes long term.. :roll:
full-throttle
Postby ashwright » Sat Jul 21, 2012 2:42 am
Hi,
Can these be used to charge a 5S battery. Assuming you leave on 'cell' unplugged?
Ash
ashwright
Postby Hyena » Sat Jul 21, 2012 4:48 am
Yep, because they're isolated on each channel they'll charge anything from 1 to 6 cells at full current.
Hyena
10 GW
10 GW
Postby ashwright » Sat Jul 21, 2012 6:08 am
Cool, then I would like one as well.
ashwright
Postby Arlo1 » Sat Jul 21, 2012 9:12 am
Very cool.
And Dave who has some good deals on STUF
[color=#FF0000][b][size=150]Never above 4.2v never below 2.7v EVER!!!
Arlo1
Postby MattyCiii » Sat Jul 28, 2012 6:04 pm
Mine just arrived. Which is to say, it arrived in the USA a long time ago, then the US Post Office teased me dancing about for a signature for a couple weeks, then I was away. Apart from the BS of the delivery agent, the product came fast and well packed.
Coincidentally, 6 bricks of 6s LiPo arrived at the same time. Damn it's a tease... I wasn't smart enough to get a 12v MeanWell at the same time (I know there are clones out there but I'll buy the real deal I think). So, I'll test the new LiPo with he usual cellogs, and I'll charge/balance them up with my Hyperion... as I anxiously await the prerequisite power supply so I cam play with my new toy!
1st build: Dahon Jetstream folding bike. Quick, reliable, capable of 30mph. Light enough to lift, folds for easy transport by car/bus/train.
2nd build: RC powered 2009 Norco A-Line. Top speed 31mph. Built like a tank, it's resistant to Boston potholes, can stop on a dime, easily goes up/down curbs when necessary.
3rd build (just started): Scratch build ultimate utility bike.
MattyCiii
Postby Dudeofdoom » Sun Jul 29, 2012 6:39 am
Mine arrived bout two weeks ago,Iv'e got a power supply but no LIPO.
It seems a nice made bit of kit though.
It slipped thru the UK customs an attracted no duty which was a 'Brucy' Bonus' :D
DoD
Dudeofdoom
Postby cwah » Sun Jul 29, 2012 2:38 pm
Is it a charger that charge from the balance plug?
If I have 10 x 4s lipo, can I parallel all my balance plug and bulk charge from there?
Find out best events to do in London: http://www.whatonlondon.co.uk/
cwah
Postby Kin » Sun Jul 29, 2012 6:14 pm
MattyCiii wrote:Coincidentally, 6 bricks of 6s LiPo arrived at the same time. Damn it's a tease... I wasn't smart enough to get a 12v MeanWell at the same time (I know there are clones out there but I'll buy the real deal I think). So, I'll test the new LiPo with he usual cellogs, and I'll charge/balance them up with my Hyperion... as I anxiously await the prerequisite power supply so I cam play with my new toy!
Not to get off topic, but if you're just using it as a power supply, you can usually pick up and mod a server power supply or PC power supply for 12v usage, for much cheaper than a meanwell.
If you are going to use the +/- %10 of the meanwell, then it's better to get a meanwell.
New to endless-sphere? Notice a lot of signatures recommending Ebike.ca? That's because it's the best place for a quality and manageable, (but still 'real'), first build. Justin is a solid supporter of electric bike development, and a good source of equipment.
My hat off a thousand times to the green people that effectively run this forum. The ES Mods are superb.
Kin
Postby MattyCiii » Sun Jul 29, 2012 7:15 pm
Thanks!
I actually decided to take a chance on a pair of 12v 20A LED power supplies from Hong Kong. So, I'll be waiting like 3 weeks for them now.
MattyCiii
Postby Hyena » Sun Jul 29, 2012 7:57 pm
cwah wrote:Is it a charger that charge from the balance plug?
Yep, though it's not bulk charging as such, it's charging each individual channel so there's no risk of overcharging. As stated it's an isolated high current balance charger.
As long as all 4S packs are at a similar state of charge when you parallel them it's no problem. If one is full and one is flat it'll try and dump massive current between the 2 batteries (through the balance tap wires) before you even connect the charger so just be aware of that.
The supplied balance board is only 4P so you'd need to parallel them up with a seperate board, or jam the connections into the 5S and 6S ports as well.
As for power supplies, at a squeeze you could get by with 20 amps at 12v.
Pulling max power (8 amps per channel) powered @ 12.5v I've measured it draws just over 19 amps.
If your supply is adjustable turning it up to 13v @ 20a should be fine. Infact I think these recommend 15v input, but what ever.
Your standard 320 or 350w meanwell will put out plenty of juice and not be running right at the limit. Or use a server PSU as stated, they're usually cheaper and available locally to get you going quicker. I'm using a server PSU on mine - it can do 50a so will power 2 of these at a time.
Oh and these chargers aren't just good for lipo, I threw some lipo balance tap wires onto some old lifepo4 packs on the weekend and used the charger to kick those rapidly back into balance too. And unlike other chargers that will have give an error message if a cell is too low (or absent in this case where I soldered only 5 wires of a 6S plug onto a 4S battery) it'll just charge up what it sees, levelling off the good cells and then sitting there trying to pull up a weak cell (if you leave it)
Hyena
10 GW
10 GW
Postby cwah » Mon Jul 30, 2012 3:33 am
Thanks Hyena, that seems to be a nice little balancing unit.
I was thinking of bulk charging my lipo in parallel this way, but as a second thought I realised that my lipo main wires are series. So main wires in series + balance plug in parallel = short!
So not yet the best bulk charging solution for my pack yet. But may still get one later to balance the packs.
cwah
Postby Hyena » Mon Jul 30, 2012 4:28 am
You can still use it, just on each parallel sub pack at a time. Probably a chore for main charging but for balancing or topping up it'd be good.
Hyena
10 GW
10 GW
Postby Arlo1 » Wed Aug 01, 2012 9:42 am
I just ordered one of the ones from deals extream I will let you know how it works out.
Arlo1
Postby Hyena » Thu Aug 02, 2012 10:38 pm
I'm sure they're all much the same. You know what our chinese friends are like :wink:
Also I thought I'd post this here for clarification as I've received a few PMs about it.
These charge ONLY through the balance taps, no connection to the main discharge leads, so they can be left permanantly in series with other packs if you want. Power supply in, balance tap out. That's in. The main discharge leads are dangling in the breeze :P
Hyena's super awesome isolated high current balance charger of doom(tm) LOL
Charging at up to 8 amps ONLY though the balance taps.
Hyena
10 GW
10 GW
PreviousNext
Users browsing this forum: mwkeefer and 3 guests
