Advanced ADAPTTO controllers and compatible products
mahoma30   100 mW
Re: Advanced ADAPTTO controllers and compatible products
Post by mahoma30 » Oct 08 2019 3:04am
Adaptto send me a Answer:
Hello!
On the main controller (master) there is a special 4PIN wire connected to the brain board in a special way.
The secondary (slave) controller is standard, the 2WD function must be enabled in the menu. To communicate with the main controller, data transfer via the BMS connector is used. This is not a CAN bus, and transmission is not via CAN.
The connecting wire for connecting the master controller and connecting the BMS at the same time, this is an ordinary double wire connected in parallel, you can make it yourself, there are two female connectors in parallel connected to one male connector, the main thing is not to confuse the wire numbers according to the diagram.
You can connect the main and secondary controllers directly through the BMS connector.
mahoma30   100 mW
Post by mahoma30 » Oct 10 2019 12:49pm
hello,
somebody can tell me which settings I can make with Adaptti midi-e for power settings( eco/normal/boost )
Got 18x Yuasa LEV40 cells ( nomin 3,7V) and a mid-hubmonster engine.
The settings I've tried at the moment don't give a satisfactory result yet. As a further option I have a mini-e for the 2WD adjustment.
Rio   10 µW
10 µW
Post by Rio » Dec 11 2019 5:19am
Looking for help connecting Adaptto screen to controller. The four pin connector has been removed.
Wires from the controller: White, Yellow, Green, Brown, and two shorter red wires (unsure if red wires were connected)
Wires from screen: Brown, Blue, Black, White
Rio   10 µW
10 µW
Post by Rio » Feb 17 2020 2:54am
display controller
brown green
white white
black brown
blue yellow
- red
- red
The company answered my email; I am very grateful
