Advanced ADAPTTO controllers and compatible products
Swede   100 mW
Re: The most advanced Adaptto Mini-E Controller + BMS
Post by Swede » Mar 31 2014 3:20pm
madin88 wrote:Why you guys do not make a call? They speak english well :)
keep in mind andreym unfortunately lost his flat in a fire short time ago. I think he is busy.
Merlin wrote:PLEASE !!! PLEASE !!! give us a PAS Mode.......
i also would like to see a integrated PAS mode in future. for now we can use a external PAS electronic and connect it between throttle and display.
dont think so complex :P
so you mean a Pas sensor V5 for exampel and connect it between throttle and dispaly and that will work?
Ohbse   10 kW
Post by Ohbse » Mar 31 2014 7:12pm
Ability to connect virtually any source DC as a battery charger. Controller can charge the battery from a DC source voltage higher than 12V and less than the battery voltage. The option is available when using the charger throttle (sold separately).
From the english translated version of the specs. Are there any limitations to charging current? I have two IBM server power supplies wired in series for 24v that I have pulled more than 60amps from successfully.
Scott   100 W
Post by Scott » Mar 31 2014 9:02pm
If 150 volt rated parts and FET’s were put into the E-Maxx I would definitely buy this controller.
For me it’s not only about power, but speed that higher voltage brings. I know that this controller allows for higher speed than normal ones but 80v even with this controller is not fast enough for me.
The selling part of this controller for me is the BMS integration and being able to see each cell on a screen. Also the ability to charge through it is amazing! I would just really like to see a 150 volt verson.
Trek Liquid 10 9c 48v 10ah, top speed 28.5 mph. 55.2 mph down a steep hill. - sold
Giant DH Team build http://endless-sphere.com/forums/viewto ... =6&t=51106 top speed 70 mph
Allex   1 GW
1 GW
Post by Allex » Apr 01 2014 2:16am
Ohbse: you can at least charge with 70A. But at yours 24V, the controller might get hot. It is better to have higher voltgage .
Cowardlyduck   100 MW
Post by Cowardlyduck » Apr 01 2014 4:52am
I think I will be keen to get one of these for my Fighter soon. Just got a few questions I haven't seen answers for yet.
What mounting options are there for the controller and display? What mounts does it come with?
What options are there for activating regen? Can you use a momentary button still like an Infineon based controller? What other option is there?
What are the plugs/connectors used? Would I be better of cutting them off and soldering on my own, or are the supplied connectors good quality, water resistant etc? Where would I get these connectors for the other end?
What length are the wires?
Cheers
Custom made 18650/21700 battery packs
Modified Stealth Fighter - Force air cooled motor @ 6KW, Adaptto Mini-E. 49AH, 52V 18650 - 2.5Kwhr
Cowardlyducks - Stealth Fighter Videos
BikeE recumbent commuter - 9C, 6Fet Grinfineon, internal 17AH, 52V, + on-board solar.
Ebike Garage - My YouTube Ebike ramblings.
High Power LiPo wiring harnesses - 4P - XT90, HXT4mm, 5.5mm. 200Amp+ capable. Global shipping.
Adaptto E-Drives Lab   100 W
Post by Adaptto E-Drives Lab » Apr 01 2014 5:44am
upek wrote:Andrey,
can you give me some information about my order?
I have replied you via PM.
For sales enquiries please contact us via: sales@adaptto.com
Technical questions: techsupport@adaptto.com
Web-site: http://adaptto.com/
Post by Adaptto E-Drives Lab » Apr 01 2014 8:15am
zombiess wrote:2 emails to them and zero response. Guess I'll be evaluating Kelly and Sabvoton they answer emails.
Hi Jeremy,
I have sent you 2 emails to you address jwolf@dodecahedronsolutions.com and it looks like you have not received them.
Could you please provide me with any alternative e-mail address for contact or send me a message to andy@adaptto.ru
Post by Adaptto E-Drives Lab » Apr 01 2014 8:21am
Ohbse wrote: From the english translated version of the specs. Are there any limitations to charging current? I have two IBM server power supplies wired in series for 24v that I have pulled more than 60amps from successfully.
There are limitations to PSU current you can use with charging coils. Smaller one are rated at 30amps PSU current and large one = 70amps.
PSU voltage does not affect this limitaion,so for maximum charging power it is recommended to use the PSU with voltage closer to minimal doscharged battery voltage.
ex. you use 20s lipo - it is 84v hot of the charger and ~60v minimal voltage if it is perfectly balanced and you discharged it to 3v per cell, So the PSU should be 50-60 volts for maximum efficiency.
You still can use your 24volts psu but limit input current(not battery current) to the maximum allowed for the chosen charging coil.
And obviously Mini-E controller will become pretty hot when charging with 70a psu current, and will probably limit charging current to prevent overheating itself. So optimal configuration for mini-e would be 30a charging coil and 50v 30a psu, Givin you 1.5kw if charging power and not overheating your equipment.
Post by Adaptto E-Drives Lab » Apr 01 2014 8:24am
Scott wrote:If 150 volt rated parts and FET’s were put into the E-Maxx I would definitely buy this controller.
We are planning to make small batch of 100+ v rated controllers, however I cannot tell you exact time when they will be available.
Post by Adaptto E-Drives Lab » Apr 01 2014 8:37am
zombiess wrote: 92V max, that is NOT A SAFE VOLTAGE for an IRFP4468. You max safe voltage is going to be around 80V fully charged and even that only gives you a 20% safety margin which would be the bare minimum for a commercial product IMO. If you switch to an IRFP4568 and 150V capacitors you end up with a much better controller.
you forgot about the voltage sag, when you use 92v hot of the charger battery, after you apply 100+amps of load in most e-bike configurations, you will barely get 85+ volts,
fets are working fine in this cases, no problems so far.
We know most commercial controllers are limited to much lower voltage (usually 75% of maximum fets rating) but unfortunately most people in e-bike world does not want to use this products...
So we made a compromise - set a safe voltage limits according to our tests and allowed each person to decide if he\she wants to use unlocked firmware at his\her own risk of use the default one and get the warranty.
As we told before, we are planning to produce small batch of 100v+ rated controllers in future, and I will inform you once they available.
Do you have details on how the BMS is working? You using the LTC6803 chips?
No LTC chips were used. We are using MSP ultra low power micro-controller for BMS boards.
Could you post some detailed photos of the internals. I'm interested in seeing the driver layout and power stage designs. You can PM or email me if you don't want to make them public.
Regards and the best of luck with sales,
Jeremy
P.S. I emailed you about pricing last night. jwolf@dodecahedronsolutions.com
I have sent you 2 emails to the address you provided, but got no reply. Please contact me at andy@adaptto.ru
ALLVLTS   100 mW
Post by ALLVLTS » Apr 01 2014 8:46am
Count me in for a 150V rated controller.
Allex   1 GW
1 GW
Post by Allex » Apr 01 2014 9:01am
Cowardlyduck wrote:I think I will be keen to get one of these for my Fighter soon. Just got a few questions I haven't seen answers for yet.
Cheers
They come with one mounting option, see pic:
http://endless-sphere.com/forums/viewto ... 00#p872803
You migh have to change to a longer screws you you use a tapered handlebar, like me.
You can use a regular on/off button for regen. Or use a hall sensor for variable regen. In the menu you have lots of values for regen operarion(ex. smooth regen that applyies softly on a button push).
The connectors are good. Big XT150 for phases and charge. And waterproof connectors for the dispay, BMS and halls.
You get a complete package with alla connectors(for other end) needed to install it on your old bike.
The lenght is minimal from the controller itself so you probably have to extend them or extend your motor/pshase cables.
Merlin   1 MW
Post by Merlin » Apr 01 2014 9:59am
iam in too for a max-E with 125v.
But i like also a 150v version for using 35S Lipos (147v HOC) :mrgreen:
AND DONT FORGET A PAS :P
Merlin   1 MW
Post by Merlin » Apr 01 2014 10:00am
madin88 wrote: i also would like to see a integrated PAS mode in future. for now we can use a external PAS electronic and connect it between throttle and display.
How does it work?
does it work with a ThunBB also?
dnmun   100 GW
Post by dnmun » Apr 01 2014 10:33am
why are you guys so anal about the PAS and demanding 150V? if greg can make 20S go 50mph, why would you think you need 150V as though it were just another trapezoidal pwm controller?
what is wrong with using a throttle like everybody else?
seems like you guys are using andreym for a pissing contest imo.
Post by Adaptto E-Drives Lab » Apr 01 2014 10:48am
Merlin wrote:But i like also a 150v version for using 35S Lipos (147v HOC) :mrgreen:
Pas on a 150v controller? Have you thought about your cadence?
zombiess   100 MW
Post by zombiess » Apr 01 2014 12:08pm
dnmun wrote:why are you guys so anal about the PAS and demanding 150V? if greg can make 20S go 50mph, why would you think you need 150V as though it were just another trapezoidal pwm controller?
I am not bringing it up as a pissing contest but as a legitimate design issue for user's who run 100v setups which is easily resolved by changing parts to appropriately rated ones so there is safety margin.
Saying a controller is OK at 92v because of voltage sag is very poor spec writing I have a 100v pack with good batteries that only sags 3v at 175a discharge and I know I am not alone. I don't know why they are so reluctant to change parts when it should be easily within their ability, the cost difference is virtually nothing and the amperage handling will stay the same. With 100v rated MOSFETs this is safe at 80v max which is good for the majority. I have a motor I run at 75v I would like to try it on, bit I prefer the flexibility of going to higher voltage.
I don't think anyone who has put a scope on the drain to source and watched the switching and overshoots which can be quite high would agree that it is OK to push the limits like this.
Merlin   1 MW
Post by Merlin » Apr 01 2014 12:25pm
i make it easy for you...
the world doesnt end behind portland.
for a streetlegal mode you need in some countries a PAS.
(Countries is like your town....just a bit bigger...there live other people.....they dont care
that you pay in dollar or sing "...the land of the free and the home of the brave!"
they had his own laws....)
and it doesnt matter that you drive a 15KW monster or a 500w bmx bike.
when it is electric, you have to pedal that the motor spins.
a throttle is allowed to 6kph.
did i have to explain what happen when police just stops you because your bike is so nice?
dont think so.....
i dont want to PISS him. i want just THAT SIMPLE FEATURE in this awesome controller package.
thats all.
i want to have an option for real speed. when it is ok for portland to drive 50mph, hey everyone has it needs....
maybe you dont want to go faster or your balls cant get it....no matter. it is your own decision ...
i bet a pair of bigger balls for you that it takes only 24h after offering "the small batch of 100v+ MAX-E's"
and it is sold out.
cal3thousand   1.21 GW
1.21 GW
Post by cal3thousand » Apr 01 2014 12:30pm
There's a reason that this is on this forum and not on it's own website. It's for discussion and requests and sharing input.
If Andreym doesn't want to include PAS, we should know about it, so those needing it can shop elsewhere. He also sees the demand for 100+volts and is working to please us.
It's only a pissing contest if those members that are asking aren't really in the ballpark for those features. Zombiess is certainly in the ballpark to ask for 100V+, see his builds.
I ALREADY have equipment for 24S and would like it to transfer easily. That will make the transition MUCH easier to do
Get a Cycle Analyst and a Multimeter, you're still a noob if you don't have at least one of each.
Planning on posting questions or buying anything on this site? Put up your country (at minimum) on your profile. This is a worldwide forum and we haven't reached clairvoyance.
Merlin   1 MW
Post by Merlin » Apr 01 2014 12:33pm
Adaptto E-Drives Lab wrote: Pas on a 150v controller? Have you thought about your cadence?
i feel really missunderstand....
i dont want ONLY a PAS.....i need a PAS for the legal commute.
mode 1: legal
1000w, 25kph, no throttle works, just the pas
mode 2: daily commute
3500w, no speed limit, pas and throttle works
to bring the same feature like CAv3....the PAS runs with 750w only and pushing the throttle overrides to 3,5KW
mode 3: offroad
10kw, no speed limit, pas is off, throttle works
madin88   1 GW
1 GW
Post by madin88 » Apr 01 2014 1:53pm
Merlin wrote: How does it work?
PAS only controls the throttle signal to the controller. Or what did you think?
Merlin wrote: i feel really missunderstand....
mode 1: legal
mode 3: offroad
you have watched the GreyP ebike movie?
IT WILL NEVER BE LEGALl! No matter what preset you have set it to.
You need a license, number plate and insurance for such a heavy, high powered bike and it requires to wear a helmet (no, not a bicycle helmet).
- 10kW belt drive with Neumotor 8057: [url]viewtopic.php?
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
madin88   1 GW
1 GW
Post by madin88 » Apr 01 2014 2:05pm
zombiess wrote: Saying a controller is OK at 92v because of voltage sag is very poor spec writing I have a 100v pack with good batteries that only sags 3v at 175a discharge and I know I am not alone. I don't know why they are so reluctant to change parts when it should be easily within their ability, the cost difference is virtually nothing and the amperage handling will stay the same. With 100v rated MOSFETs this is safe at 80v max which is good for the majority.
im not very good in electrical engineering, but isn't there already a safeness in these electrical components? I mean if the FETs and CAP's are rated for 100V and the safeness is about 10% (only a guess) than they will survive 110V without damage. Or i am wrong?
The bad thing is not battery voltage alone, but more the high voltage spikes which occur at very high phase amps. because of this Adaptto limits the current (in normal firmware) if voltage is over 92V. Ifsome want to push the controller to the max with the unlocked firmware, they suggest to add some LOW ESR caps as near as possible to the controller case to smoothen low and high frequency voltage ripple.
Ariane   10 kW
Post by Ariane » Apr 01 2014 2:42pm
Guys,
AndreyM, try to sale a great product at great price to build a fastest ebike at 20s. No infineon controller sales by Zombiess are Sine wave controller … same for Kelly.
So I don’t know what Zombiess Is trying to do here… exactly. For the people asking about pass buy an infineon controller (12 Mosfets or 9 fets) installed with the pass system of your choice with a Mac motor and don’t be afraid if the police arrest you.
Now get back to AndrewM sales post, there’s s allot of products here for an ebike in the 1000 to 3500 Watts range.
BlackArrow
Merlin   1 MW
Post by Merlin » Apr 01 2014 3:19pm
madin88 wrote: PAS only controls the throttle signal to the controller. Or what did you think?
so, please show me the easy external PAS solution for any controller.
i dont know any solution for it.
whats about the greyp movie?
i dont have a greyp bike.
it is NOT illegal to drive a DIY ebike that fits the law.
limited to 25kph, PAS and throttle just to 6kph and a maximum CONTINUE Motor power about 250w.
(what continue power means i dont have to explain for you)
no retail pedelec on market has only 250 MAXIMUM Motor Power.
it IS Illegal to drive THAT bike that can "convert" by a click or a hidden switch to something that has more Power or no Speedlimit.
when not, no matter if you drive a 11Kg Cro Hub or a 2Kg geared.
bionx? deactivate internal controller and push 3KW to it......oh...a sticker on the hub said only 250w.....totally legal huh?
i dont care if there comes a 150v version.
I like the 98v version allready. i had no Problem driving only 20s. I Just want to drive 65mph minimum. Shame on me....
Give me a Hub that runs with 60v 100kph....will buy it. i would be happy with 60v....i had alot more charging options.
The big difference between Kelly or Infineon is just the sinewave and some extra features (yes theyre cool)
alot of others on the market..right...but no sinewave....
communication is poor. thats why (maybe) alot people ask in this or other topics...because they had questions and get no answer...
no time? cmon....take a look at lyen.....
hes a one man show and had allready selled near thousand controllers. had a normal job and if you ask, you get answeres....
but it is ok....just buying and no questions please....
madin88   1 GW
1 GW
Post by madin88 » Apr 01 2014 3:53pm
Merlin wrote: it IS Illegal to drive THAT bike that can "convert" by a click or a hidden switch to something that has more Power or no Speedlimit.
do what you want. the cops will tell you cool guy what is illegal and what not :wink:
i would say a ebike set to 250W and 25kmh with the OPTION to unlimited speed / 10kW power is illegal in germany.
these guys from Adaptto E-Drives Lab mainly act in the very big board in russia. you better should be thankful they ship it to us in the whole world :wink:
