Nucular electronics - complete kit for ev! [beta]
VasiliSk   100 W
Post by VasiliSk » Jan 12 2016 3:01pm
Nucular controller 12F
[+] photos
Maximum power 10 000W (80V+)
Nominal power 5 000W (80V+)
Voltage range 35-90V
Phase max 250A
Battery max~150A
Supply out: 12V 1A, 5V for sensors, each line 100mA PPTC
Bluetooth 4.0
Limiting temperature +80°C
Phase wires 8AWG XT150
Battery wires 10AWG XT90
Size without wires 86*43*125
Weight 525g
Control modes: Square, sensorless, FOC, charger
Temperature and hardware overcurrent protection
Sleep current less 300uA
Thermo Nucular controller 24F
Maximum power 20 000W
Nominal power 10 000W
Voltage range 20-90V
Phase max 500A
Battery max ~300A
Phase wires 6AWG terminals
Battery wires 8AWG XT150
Size without wires 86*43*185
Micro Nucular controller 6F
[+] photos
Maximum power 4 000W
Nominal power 2 000W
Phase max 120A
Battery max~70A
Phase wires 10AWG 5mm bullets
Battery wires 12AWG XT60
Casing size 88*70*32mm
Controllers features:
Fast auto-configuration, hall angle compensation. No need to find right wires combination
Minimum wires, you can connect everything to Display, but controller also have inputs if you need
Pedal Torque sensor (better work - in progress) supported
Speed, torque, or speed+torque control
Charger mode - use any DC source, just connect one phase wire to charge your battery
It is really frosty, not so easy to heat up controller if installed on the airflow (betatesters feedback :) )
CAN bus with supply 12V 1A (Working on LEVCAN open source protocol!)
Analog throttle, analog brake or switch brake, instant response, configurable slope (dA/dt).
Digital or analog halls, motor temperature sensor (TMP35/36, KTY83/84, PT1000, NTC10K 3950)
Speed switch 1-2-3
Two PWM in/out
Enable button or switch, or with bms
Reverse, cruise inputs
We constantly update the software, if you have any ideas or needs - tell me!
Info Display
[+] pictures
LCD 3" 240*128 FSTN
RGB Buttons
Supply in 8-15V
USB Charger 5.2V 2A with universal driver
English menu
MicroSD slot for software updates
Desc:
Shows charge, speed, power, currents, cell voltages and etc..
Displays information from all devices on CAN bus, updates their software and configures them.
It has light sensor and integrated accelerometer.
A lot of inputs, configurable functions.
Handy back panel for wires inputs. No need for waterproof connectors outside.
Universal GoPro mount, in kit there is steer tube adapter.
Integrated heater for winter use.
Plans for future:
16S Micro Nucular BMS extreme small size for scooters - testing
24S Nucular BMS for any kind controller - planned
Thermo Nucular Controller 24F - testing... (approx. 500~600$, ETA middle of 2019)
CAD-model controller casing
CAD-model of LCD
Wiki, schematics and software updates
Youtube updates playlist (with english subtitles)!
Display price 85$
Micro Nucular controller 6F price 150$
Nucular controller 12F price 285$
Thermo Nucular controller 24F price 465$
Shipping is 40~50$ depends on country and quantity
I have also different throttle types, 48V3000W 2kg telecom PSU for charging through motor, waterproof julet 6pin connectors (for halls) for sale. Please tell me where you want to connect control, controller or display.
[+] Accessories
You can ask me in Telegram @vasilisks Nucular electronics chat
Inform me if you need one, there is a big queue, i will note you and contact when ready to ship.
neptronix   100 GW
Re: Designing of 12F 100kERPM Sensored/Sensorless controller
Post by neptronix » Jan 13 2016 10:15am
My suggestion is to sell it to the public. That controller sounds effin' awesome. :)
parabellum   10 MW
Post by parabellum » Jan 13 2016 10:38am
Awesome! :D
Is it trapezoidal?
VasiliSk   100 W
Post by VasiliSk » Jan 13 2016 12:25pm
(archived)
Since finally i've got some results, it's time to get feedback :)
I'm designing 12F high efficiency controller, capable of running 100kERPM in sensorless/sensored mode. Up to 200A 30sec and 120A continious phase current with proper cooling.
Main advantage - using high switching speed of mosfets, proper designed power plane - low inductance, direct phase current control (capable of current request response almost instant), overcurrent protection (but not overregen :twisted: ), temperature protection, dual sided cooling for mosfets. Fits in 9F infineon casing. Futher it will take up even less space
phase currents:
It is 100V mosfet and capable to run up to ~90V. I've seen 7200W from this installed on my Adventure Bike, it kicks ass when you release brake with full throttle.
As for now im succeed running sensorless in less than 60 ERPM and up to 100kERPM stable, but got some problems from higher amps on my "cromotor", current recovery lasts for too long sometimes. Also i have no test bench, so i'm run all test on my ass :D
Also implemented as for now step-up converter mode (charge battery through motor or any other inductance). In plan using bluetooth or wifi for configuring and flashing new softwares.
Suggestions?
neptronix i should adopt it to mass production first. there is a small bunch of problems.. moving in this way:
parabellum yep. maybe later there will be sine wave avaible (DTC-SVM, FOC or simple sine PWM) but not now.
Punx0r   100 GW
Post by Punx0r » Jan 13 2016 7:14pm
Does it have voltage or current throttle?
VasiliSk   100 W
Post by VasiliSk » Jan 14 2016 12:49am
it is capable of current + speed, or only current control. Working on tesla-style driving, where you need only throttle to start/stop
neptronix   100 GW
Post by neptronix » Jan 14 2016 3:33am
Prove that it can drive some nearly impossible motor to drive, like the colossus motors from the Croatian crew, or one of hobbyking's larger rotomaxes, then offer up a few samples for sale... and go from there.
These large RC motors with high RPM capabilities and high pole counts are currently just waiting for the right ebike-sized controller to be exploited.
parabellum   10 MW
Post by parabellum » Jan 14 2016 8:43am
VasiliSk wrote:the only high pole count motor i have to test ERPMs
http://www.youtube.com/watch?v=6RcsN_ZUSRE
Predator 30-8
http://www.youtube.com/watch?v=nKp6QjuzmMM
these was made on old pcb
Was 124000erpm controller or voltage limited? What is the practical erpm limit for your controller?
circuit   100 kW
Post by circuit » Jan 14 2016 9:28am
neptronix wrote:These large RC motors with high RPM capabilities and high pole counts are currently just waiting for the right ebike-sized controller to be exploited.
Rotomax, at least 150cc, is actually quite nice and no too hard to drive. Inductance is 17uH, which is still manageable by most cheapo controllers.
smart and Tiny BMS solution
Visit my blog. Personal projects: Clean Peugeot conversion | Ultralight enduro
Any and all information, such as texts, specifications, drawings or other material that I post are to be used only as a reference for personal, non-commercial projects ONLY. Any republication for personal or commercial needs must be agreed on individually. Use of any information, that I post, for commercial purposes is strictly prohibited.
neptronix   100 GW
Post by neptronix » Jan 14 2016 9:58am
Predator 30-8
super impressive, bro! now, let's see it with a load on it.. :twisted:
neptronix   100 GW
Post by neptronix » Jan 14 2016 10:02am
I remember checking ES for a year or so to see if anyone was actually using them... and didn't find anything.
So anyway; easy to drive, you say? who's running one at full tilt on this forum?
SjwNz   100 W
Post by SjwNz » Jan 27 2016 4:42am
I am only running the Rotomax 50cc motor at 3kw with my DIY controller but would like to play with the 150cc some time in the future.
Good work on your Controller, I want to try Sensor-less sometime.
VasiliSk   100 W
Post by VasiliSk » Feb 15 2016 9:59am
some progress on dyno. soon i will get real data from rv160s
peters   100 W
Post by peters » Feb 15 2016 1:58pm
On your video I saw STM Studio for a second. Which uC are you using if it's not a secret?
I just started to experiment with STM32F3DISCOVERY board and hope its 72MHz will be enough for sensorless FOC in C.
macribs   1.21 GW
1.21 GW
Post by macribs » Feb 15 2016 5:53pm
The future of e-biking looks bright, amazing work.
VasiliSk   100 W
Post by VasiliSk » Feb 16 2016 2:08am
peters wrote:On your video I saw STM Studio for a second. Which uC are you using if it's not a secret?
it is cheap stm32f103. i not planning to run FOC on this board, it is much more expensive in hardware
kiwifiat   100 W
Post by kiwifiat » Feb 20 2016 4:27pm
The STM32F103 has more than enough power to run FOC in sensorless mode. Download the free IAR EWARM and ST's Motor Control Workbench http://www.st.com/web/catalog/tools/FM1 ... m32100-pr1# and you can compile the FOC code that includes field weakening in under the 32K limit for the code size restricted EWARM. A cheap fleebay STLink usb dongle and a cheap USD4.46 Maple Mini clone (STM32F103CBT6) and you are on your way. I am playing about with ST's patented single shunt FOC topology now which if successful should make for a very low cost FOC controller.
“You never know if quotes on the internet are genuine.” - Abraham Lincoln
VasiliSk   100 W
Post by VasiliSk » Mar 09 2016 4:14pm
LCD is coming... it is gonna be multilanguage and custom font supported :)
VasiliSk   100 W
Post by VasiliSk » Mar 22 2016 3:07am
Got this data from RV160 short using trapetzoidal control
7 pole pair
25 wire turn on tooth, 6 wires in parallel D0.8mm
Delta commutation, virtual wire cross-section 5,2 mm2
80mOhm
300uH
33.36kV (RPM/V)
0.22kA (Nm/A)
this gives me 39.6Nm on shaft of motor with 180 phase amps
VasiliSk   100 W
Post by VasiliSk » Apr 21 2016 8:59am
I've run some tests on rv160s motor. On this graph horisontal - rpm, vertical - power consumption...
as you can see when motor runs 4k+ RPM, power rises above 1kW!! I have find out that main problem of such losses is a big bearing, it is heats up instantly when motor spinning 4k.
Here is explanation vid: https://youtu.be/qTRJ4jqASRA it is in russian, but easy to understand where is problems
So i replaced this original NSK 6814 bearing to NTN 6814, cover now spins much longer!!
And finally some photo of RV160s
magnet width 25mm... winding NOT 6 parallel wire, but 5. im quite dissapointed with this motor
straby187   1 mW
Post by straby187 » Apr 21 2016 8:25pm
Can you verify the lamination thickness?
VasiliSk   100 W
Post by VasiliSk » Apr 22 2016 1:30am
64 laminations with overall thickness 22.8mm, this gives about 0.35 per lam
