auxiliary brakes even though much of the braking is done by the regen.
I am thinking you were asking about a kind of "parking ebrake". Yes, controller can do that but I would not go that route for two reasons: a) you will use power when the bike is parked on ebrakes; b) the bike will lose the parking brakes if the battery gets low and cuts out power.
Variable regen exists in prototype but still needs some kinks to be worked out. I may get to it after the dashboard functionality is fully released. ETA - a couple of weeks from now.
OV_ wrote:Finally cot bike running with this controller and new frame:
I'm planing to abandon rear disk breake. Is adjustable (with hall sensor) regen brake possible? If is, what is required to do? Open controller and some soldering + software update? How about ebrake that is active when key is off position?
Still holding order button for CA v3 and waiting for that display function. Can u give any eta?
