24F Silent Controller 20kw 100-150v iOS/Android- $299>
ecross
Re: 24F Silent Controller 20kw 100-150v iOS/Android- $299>
Post by ecross » Mar 17, 2018 2:15 am
Hi
is fully variable regen or 2 step switch regen now on stock?
-still waiting for more then 12 weeks!
Thanks
NC 2805 mod.
H4080 mod.
4503 mod. 4504 mod.
LiIon Sony, Sanyo, Panasonic
Siemens 2000W travel charger
madin88
Post by madin88 » Mar 19, 2018 12:59 pm
Powervelocity.com wrote:
Mar 19, 2018 12:17 pm
Yes, supported in new modules as a beta feature.
Is it two step, or variable with a second throttle device?
amg03andrey@yahoo.com
Post by amg03andrey@yahoo.com » Mar 19, 2018 1:50 pm
Hey no emails from you at all come on at lest say that you don't want to do this, I'm tired waiting and waiting.
Do you have a controller that supporting 100AMPS contentious, and 10k.w to 15k.w super silent very very quiet controller that way it will be super silent BUT in same time I need it to be very powerful for the hub-motor that I'm getting 8K.W to 10K.W but do not over heat the hub-motor too, the goal is I need to achieve super fast acceleration from 0 to 60 whatever in couple second !!
Please get back to me, me and my team are waiting !!
Powervelocity.com
Post by Powervelocity.com » Mar 19, 2018 5:29 pm
The controller can be ordered from the website - no need to wait for me to respond on this. Acceleration does not solely depend on the controller or the battery, or motor. It's the combination of the aforementioned plus the total gross weight of the bike.
For the battery pack, I would need exact measurement requirements.
Powervelocity.com
Post by Powervelocity.com » Mar 19, 2018 5:35 pm
It's variable with a second throttle or whatever that can output 0.8-3.6v.
It works but will need further tuning via software as I didn't have a chance to extensively test it on a real bike. Therefore, I call it beta.
csc
Post by csc » Apr 06, 2018 4:38 am
Nice !
I'll soon have a qs273 4000 in the rear wheel.
If you had the possibility to make a 24F with BT, var regen, sensorless + sensored version, I'd buy it right away for sure.
csc
Post by csc » Apr 06, 2018 5:14 am
edit : moved to the 18f thread
ecross
Post by ecross » Apr 06, 2018 9:37 am
Hi
is fully variable regen now on stock?
-still waiting for more then xx weeks!
-a beta version is ok, will test the controller here, have big hills...
-send ASAP info to me
Thanks
NC 2805 mod.
H4080 mod.
4503 mod. 4504 mod.
Post by \ (•◡•) / » Apr 12, 2018 9:08 am
Hello, I have safely received my controller and wired it into my bike, But, the Bluetooth dash and programming functions don't seem to be connecting. I have tried on multiple devices to connect to the controller (all devices that don't have any issues connecting to other BT enabled things) I'm using you app and have checked that under setting> manage the Bluetooth scanner is enabled. also under >programmer it's reading as " looking for Bluetooth device..." at the top. So I opened the top lid of the controller and from what I can see the Arduino nano is not lighting up when the controller is powered on, although I of course don't know if the light has been programmed to always be on or not (i'm guessing it probably isn't). I can see there's a reset function on the Arduino as well but i'm scared to jam a metal object in there while its powered on. I can confirm that the controller is powering a CAv3 so the controller is defiantly powered on, the throttle is also giving power to the motor, which is causing it to turn a touch backwards and then give up, Which I would guess just has something to do with the programming of the controller that I need to change through the app. (btw the motor is also wired as recommended in the wiring diagram provided through your site)
Anyway hoping you have a simple solution to the issue. It would be a nightmare for me to remove the controller from my bike now that all the wires have been routed through small holes and the connectors have been re-crimped, I really should start checking things before I install them :lol: .
Anyway looking forward to your reply and getting the controller working.
Thanks
Powervelocity.com
Post by Powervelocity.com » Apr 12, 2018 7:48 pm
Please PM a picture of the module so I know which version you are talking about (there are a few of them). However, you should at least see one blinking red light on the module when it is powered up and not connected to from the app.
Also, what kind of an ignition you are using? I have seen some that cause the module to not start up.
Thanks
