6F 2kW SW Controller 100V dual sensored/less iOS/Android $99
Powervelocity.com
Post by Powervelocity.com » Jul 24, 2017 4:02 am
I know guys you have been waiting long enough but I am finally living up to the promise: the 6F version of sinewave controllers is now available for immediate orders.
These are the smallest in the family of controllers seen here:
https://endless-sphere.com/forums/viewt ... 31&t=81020
here https://endless-sphere.com/forums/viewt ... 31&t=75888
and here: https://endless-sphere.com/forums/viewt ... 31&t=85156
These controllers retain all of the features of the bigger brothers as discussed in the threads quoted above PLUS they can operate with or without hall sensors. In sensored mode, they will run motor super quietly thanks to sinewave modulation. In sensorless mode, they will switch to trapezoidal modulation which will add a little wheeze while spinning a motor. With or without sensors, a smooth start from standstill is there.
No special configuration is needed to switch between the modes: just connected sensors if you want sinewave and don't connect them if you want square wave and/or otherwise don't have sensors available on your motor.
Those who ever got stranded on the road with burned hall sensors would appreciate the feature.
If that's not enough, I build these controllers with the best 100v mosfets available today: AOT290L. Conservatively rating them at 2kw, but they can do probably even better than that.
Just a quick overview of the features: 3 programmable positions for speed and current, soft and hard start, cruise control, adjustable regen braking(sensored only), flux weakening (sensored only), CA connector, and much more.
Bluetooth programming is available as an external add-on for $49.
Also, 12F and 18F versions are now available with AOT290L mosfets and dual sensored/sensorless mode.
Inquire via PM.
Last edited by Powervelocity.com on Jul 25, 2017 1:22 am, edited 5 times in total.
madin88
Re: 6F 2kW Sine Controller 100V sensored/less iOS/Android -
Post by madin88 » Jul 24, 2017 12:14 pm
nice to see the 6F is available now
Powervelocity.com wrote: No special configuration is needed to switch between the modes: just connected sensors if you want sinewave and don't connect them if you want square wave and/or otherwise don't have sensors available on your motor.
thats awesome!
i wonder if it works with 60° and 120° hall sensor loacation?
btw: i was searching for AOS290L Mosfet and couldn't find anything... could it be the AOT290L?
- Votec V-FR frame / MXUS 3T / 17" Mitas MC11 / Adaptto Max-E / 20s12p 25R -> approved as L1e moped and fully road legal in EU :)
- Vector white / MXUS 4T / 24" Hookworms / Adaptto Max-E / 22s11p 25R
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
Powervelocity.com
Post by Powervelocity.com » Jul 24, 2017 1:39 pm
Yeah, 60 or 120 degrees settable from a smartphone.
Thanks for the correction - it's AOT290L mosfets from Alpha and Omega Semiconductor (AOS). That's where the confusion comes from. Fixed now in the original post.
madin88 wrote:nice to see the 6F is available now
thats awesome!
paxenon
Re: 6F 2kW SW Controller 100V dual sensored/less iOS/Android
Post by paxenon » Aug 01, 2017 12:02 pm
Sent you PM about 18fet version.
cal3thousand
Post by cal3thousand » Aug 01, 2017 12:43 pm
Would love to see the traces
Get a Cycle Analyst and a Multimeter, you're still a noob if you don't have at least one of each.
Planning on posting questions or buying anything on this site? Put up your country (at minimum) on your profile. This is a worldwide forum and we haven't reached clairvoyance.
coolbobjoe
Post by coolbobjoe » Aug 26, 2017 4:32 pm
? nice pics?
liveforphysics
Post by liveforphysics » Sep 14, 2017 5:04 am
CSD19506KCS.
Possible to build using that FET to make a controller for 16s max?
Or the 100v version.
http://www.ti.com/product/csd19536kcs
miuan
Post by miuan » Sep 14, 2017 8:03 am
Hi! Are these available in Europe?
Basia
Post by Basia » Nov 10, 2017 4:22 am
Is it possible to buy a 6f controller with bluetooth? Is it possible to send to Russia?
you can PM me with all the details of the 6 fet controller?
999zip999
Post by 999zip999 » Nov 10, 2017 4:04 pm
What is the amp rating ?
Basia
Post by Basia » Nov 13, 2017 4:18 am
what is included in the set? With Alarm/GPS ?
Basia
Post by Basia » Nov 15, 2017 12:51 am
do you have 6fet controllers? why do not respond to messages? I want to buy it
IanM
Re: 6F 2kW SW Controller 100V dual sensored/less iOS/Android $99
Post by IanM » Mar 10, 2018 4:50 am
Hi, are the 6fet controllers still available? I would like to try one with the bt interface for a new project I am planning.
IanM
Post by IanM » Mar 12, 2018 3:07 pm
PM sent.
cwah
Post by cwah » Mar 22, 2018 3:29 am
Does it have variable regen?
cwah
Post by cwah » Mar 22, 2018 4:43 pm
What would be the cost with variable regen shipped to UK?
Can the controller be made waterproof?
What's the dimension and weight?
Thankz
Powervelocity.com
Post by Powervelocity.com » Mar 22, 2018 6:18 pm
The new modules will become available in two weeks. That's when I have information on pricing for var. regen.
Controllers are water resistant which means you can ride in rain but not install it on submarines.
Thankz
cwah
Post by cwah » Mar 24, 2018 9:50 am
does the controller also has auto-tune? So there is no need to check which hall combination works?
