What is the Difference Between Electronic and Electric?
Things related to the E-S Wiki
LockH   100 GW
Post by LockH » Oct 11 2015 10:48am
Seen here, for example:
http://www.wisegeek.org/what-is-the-dif ... ectric.htm
there is a subtle difference between the correct usage of each word.
and "Electric has to do with the general concept of electricity."
and "... electronic is a term that is descriptive of devices that are powered by electricity."
Anyway... after using electricity all my life this question occurred to me in reading this instructables "12V-180kV: A Battery Powered Marx Generator (and introduction to electronics)"
... and until now zero mention of the "Marx Generator" on ES either, that I could find.
Tks :)
L
viewtopic.php?f=3&t=57408
viewtopic.php?f=15&t=60564
spinningmagnets   100 GW
Re: What is the Difference Between Electronic and Electric?
Post by spinningmagnets » Oct 11 2015 11:31am
I don't know the proper differences between electronic and electric, but as an outside observer, I would say that the common brushless ebike controller is stuffed full of electronic components, but a simple brushed controller could (in my mind) be comfortably called an electrical device. Perhaps it has to do with the processing of inputs and outputs using low voltage in a programmable chip?
LockH   100 GW
Post by LockH » Oct 11 2015 11:49am
Hehe... Ya. We tap about "electric bikes" when it seems we're more about "electronic bikes". Amusing.
Post by spinningmagnets » Oct 12 2015 6:50am
This may be splitting hairs, but by my definition, the brushless ebike hub-motor is "electric", but the hall sensors are "electronic", and...the controllers are electronic devices, whether sensored or sensorless...
The battery is electric, but the BMS is electronic?...
cal3thousand   1.21 GW
1.21 GW
Post by cal3thousand » Oct 12 2015 6:34pm
To me, if there are logic devices within the electrical, then it is electronic.
Get a Cycle Analyst and a Multimeter, you're still a noob if you don't have at least one of each.
Planning on posting questions or buying anything on this site? Put up your country (at minimum) on your profile. This is a worldwide forum and we haven't reached clairvoyance.
pgpete   100 µW
100 µW
Post by pgpete » Aug 03 2016 9:13am
Electrical systems are about electric energy systems used to produce and distribute power output
Electronic systems are about electronics designed used to produce, process and distribute information.
Electrical systems use electronics . ( and vice versa. )
Stealth Franken-Fighter
RLT   10 kW
Post by RLT » Aug 03 2016 5:06pm
cal3thousand wrote:To me, if there are logic devices within the electrical, then it is electronic.
Yep. That is pretty much the way I always thought about it. If it uses old school vacuum tubes or semiconductors it is electronic.
If it is only wires, and/or any combination of mechanical switches , resistors capacitors and inductors, it is just electric..
Toorbough ULL-Zeveigh   100 MW
Post by Toorbough ULL-Zeveigh » Jan 31 2020 5:17pm
the real actual Electronics is called Chemistry full stop
