Industrial Motor gokart build
Quinc
Post by Quinc » Nov 27, 2017 2:31 am
Been tinkering with mini motos, mini bikes and razor dune buggies for the last couple years and wanted to get something a little more comfortable. I bought a Leeson motor off ebay for a great deal and after a year of searching I finally picked up a kart racing chassis for a decent price.
Plan:
48 volts
7200 rpms
10T drive sprocket
67T axle sprocket
#35 chain
11.5" tires
Goal:
Have fun and ride around neighborhood with kiddos
Motor:
Leeson
1HP
24vdc
3600 RPM
TEFC
Controller:
Kelly KDZ48400 24v-48v 400a controller
Batteries:
48v
Starting with SLA 12v 18AH. (I have a bunch of them from other projects, but might move on to lipo, leaf, or just larger sla's)
Kart:
Haase stage 2 (First time with a real gokart and learning as I go)
Quinc
Re: Industrial Motor gokart build
Post by Quinc » Nov 27, 2017 2:43 am
So far the kart is a little rough.. I took off the axle and cleaned it up added a sprocket hub and am now waiting on a new sprocket. And still need to figure out how to mount the seat. Once I have it how I like it, I will strip her back down and paint etc.
Tonight I started on building a bracket for the motor to attach behind the axle. My plan as of now is to put the batteries where the engine would normally go on the kart, and moving them however needed for balance and weight distribution. I am also trying to keep from welding or drilling the frame.
Quinc
Post by Quinc » Dec 06, 2017 2:16 pm
Kiddos' 4th bday was Saturday and also taking care of a 3m old so the build is starting off a little slow.
Ordered new rear axle bearings for her today and just got the cheapo 3pin Chinese foot throttle for it in the mail. Rather then "make" the foot throttle work I am going to go with a pull throttle.
Always a good sign when it comes new with rust.
Going to upgrade to this one:
https://www.ebay.com/itm/Hall-Effect-Pu ... SwLN5Wit3t
Not sure where the motor POS wire should go yet.
Kelly i bought off ebay mostly wired up:
Quinc
Post by Quinc » Dec 06, 2017 2:26 pm
Spent some time cleaning up the axle. She spins a hell of a lot smoother now with new bearings. Also a new sprocket hub and 67T #35 sprocket.
Getting closer!
Quinc
Post by Quinc » Dec 07, 2017 10:28 am
Motor mount is complete! Has the ability to go side to side and back-forth fairly easy. Used a 3/8" plate of aluminum.
And started on the battery tray:
Drunkskunk
Post by Drunkskunk » Dec 07, 2017 1:43 pm
Looks like fun. I've had cars with less stout brake rotors.
Had a good laugh at the "Kelly" controller diagram.
Monster Bike:https://endless-sphere.com/forums/viewto ... =6&t=38667
