Isuzu trooper
koopdi
Is this model a good candidate for conversion?
4x4 Isuzu trooper 5speed.
Conversion to what, exactly?
For what specific use(s)?
Have you looked around to see who has already done a conversion like you want to do with that specific model, or anything similar?
Have you ever done a conversion of any type on any vehicle? (it's quite a lot of work, and usually a lot of money.)
If the main rationale for conversion is because the head gasket is blown and it's not worth the time/money/effort to fix it then absolutely not! An EV conversion would be a LOT more work and expense.
This works great on a blown head gasket, IF you follow the directions and do it correctly. If you just dump it in the radiator you're probably just going to make things worse. But I've used this on cars for several people and they go on driving them.
https://www.zoro.com/kw-head-gasket-repair-16-oz-reddish-brown-401016/i/G1855971/feature-product
http://www.evalbum.com/2376
http://www.evalbum.com/719
Some other Isuzus in the mix there too. The upside is a huge payload and lots of space. The downside is big cost and lots of weight to move.
