vanilla ice wrote:Make a mold of the body so we can make kitcar EV1's.
That is a great idea.
The New GeeEmm EeVee-Wun.
TylerDurden wrote:vanilla ice wrote:Make a mold of the body so we can make kitcar EV1's.
evdriver wrote:Seriously, you have bigger issues to deal with.
(1) Look under the dash, drivers side, kickpanel. Yeah, all that dangling crap is where the BTCM used to be.![]()
(2) Now go over the passenger side and look in the same area. A ghost of where the HTCM once resided.
There's a couple more surprises lurking too.![]()
And after all that; you can't drive it on the streets.
JCG wrote:Well... it's not so bad as all that. I'll be able to operate without the BTCM, as standard brakes still work (no ABS functionality though), and the repaired inverter has inputs I can use to directly connect potentiometers to run traction and regen braking signals.
evdriver wrote:It's not just ABS. There are no standard brakes on the EV1. The EV1 uses 4 wheel electric brakes. The two front wheels also include a small emergency hydraulic backup (without assist) that GM's lawyers demanded be included just in case the EV1 brake by wire system failed. You'll need both feeties on the brake pedal to stop it using those front only emergency backup hydraulics.
Don't get me wrong, I applaud your effort. Posting that you'll operate it without a safe and functional brake system makes it difficult to take your efforts seriously.
The EV1 braking and steering systems are both unique in that they are electro-hydraulic systems. The front disk brakes are hydraulically actuated and powered by electrically driven pistons (12-volt power); the rear drums are electrically actuated (12-volt power).
JCG wrote:... It's not easy working by myself in a discipline that's not my own, on a vehicle that was sitting forgotten in a garage because the original investigators gave up trying to find a place to work on it (and had no interested students). But I do want to find success in the end.
vanilla ice wrote:Tiiight car!
IIRC from the brochure the 88-91 crx was .29 and the 88-91 civic hatch was .31.. probably a little on the optimistic side.
AndyH wrote:JCG - You might enjoy reading this. Enjoy! Andy
High Performance APU Series Hybrid Electric Vehicle KLK331.pdf
From Craig Osterday, the designer of the EV1's brake system.
"The EV1 did have Hydraulic front brakes (standard hydraulic aluminum
calipers), but they were pressurized by a modified ABS6 actuator, which was
activated by the PFE (pedal force emulator). This provided hydraulic
pressure to the front calipers. It was still brake-by-wire, as there was no
direct hydraulic linkage between the pedal and the calipers. The ABS6 was a
motor - ball screw actuator which Delphi used to make, and was on many GM
vehicles. The rear brakes were all electric, using a motor/ball screw
actuation to expand the drum linings (the drum was a special
carbon/metallic/aluminum composite for weight savings. Hope this helps.
And it was a very high-tech car, and a blast to drive. (It even would lay
rubber). The weak link was the batteries. I drove it home when it was 25F,
and barely made the 20 mile drive before the batteries died. Thank goodness
it had REGEN braking to help the charge."
There were about 40 of them that were gutted and donated to museums and universities (Smithsonian has the only intact donated EV1). Three universities: BYU, University of WI, Madison, and W. WA Univ (above) have all rebuilt theirs, but all as pure EVs so far.
Can't wait to see what happens with this one!
Return to Large EV General Discussion
Users browsing this forum: No registered users and 2 guests
