TylerDurden wrote:Here is a good place to start:
http://www.evalbum.com/type/BMW
http://www.evalbum.com/type/VOLV
E-racer wrote:Is $5k just for the motor/controller?
TylerDurden wrote:You can find entire EVs for about $5,000usd, but they might need work and/or batteries.
http://www.evtradinpost.com/
amberwolf wrote:The only real problem with brushless motors in cars is it seems difficult ot find inexpensive *reliable* controllers at the power levels you need for a car.Motors can be found cheap, in various EVs in junkyards and stuff. Often the controllers may be with them too but you wind up with the problem of reverse-engineering the controller to figure out a way to run it and to fake the sensor inputs to it so it will run without all the rest of the car it came from. Some poeple have even found ones from large buses and whatnot, for not too expensive...I just don't know if they ever got the controllers working.
DIY Electric car has a couple of good conversions of BMWs. One is by Crodriver, of course.But it is meant for a racer and not quite what you're after. The other is by JackBauer, over in Ireland, IIRC. It's probably like what you are trying to do.
Hillhater wrote:I assume you are aware of Jack Rickards blog ..EVTV..?
http://www.evtv.me/
Like him or not, there is a lot of good info on there.
The Mighty Volt wrote:E-racer wrote:Is $5k just for the motor/controller?
Yes, probably.
We need then to address the issue of the battery.
We want to build a car that is safe, reliable and always runs.
Top end is not a worry, but the kid brother wants to wheelspins. Probably 90Mph, 0-60mph in 6-7 seconds.
Jozzer wrote:That wont get you wheel spinning power really, if your on a budget you want a big old series motor. Look at the Netgain or Kostov motors.
I've got an 11" Kostov 250v motor with a Soltiton controller, fits your budget and makes tons of power (I've gotten 250KW into it with a stiff battery pack).
You could go with a 9" and a 500A Soliton jnr for a cheaper/lighter setup - though continuous power will be down a good bit.
There's no AC setup in that price range that will give you tyre slipping torque..
Steve
E-racer wrote:I wonder if anyone has used a wrecked Tesla Roadster as a donor for an EV conversion.
The Mighty Volt wrote:Hi Brentis, thanks for your recommendations and your time.
I've been reading about AC Induction a lot, these Brushed DC options, how reliable are they? How long can I expect Brushes to last??
Thanks again.
Brentis wrote:The Mighty Volt wrote:Hi Brentis, thanks for your recommendations and your time.
Thanks again.
Cheers.
In general, Brushed motors are as reliable as the amount of power you put to them![]()
The harder you run them, the hotter they get. Excess heat will use up the brushes quickly.
As evidenced in Emoto racing, sustained high power "burns" up the brushed bikes Agni, Perm, Etek, etc.
If you are looking for a street/commuter car, that can do burnouts.
A big brushed motor will do fine. Especially if you utilize a manual gearbox.
Quite a few conversion use only 2 3 4 gears.
1st applies to much toque & spins![]()
The ? you should think about & decide.
And I believe to be most important, is the "Roller"
What vehicle do you want to convert? & why?,
That will start to determine how much power you will need for 0-60 in 6-7sec & 90mph.
& which motor/controller/battery combo can achieve the goals.
Good luck on your journey
fechter wrote:A big brushed motor will probably be the most economical and the brush maintenance is not too difficult or expensive.
Harold in CR wrote:+1 on the Jack Bauer guy. He makes controllers, makes high amperage chargers, has a couple EV's running, AND, seems to be the king of scrounge. I believe he is presently into an AC conversion. DIYelectriccar.com is his usual hangout, besides the ecomodder site. He is always advising guys on these sites. You would benefit greatly from the DIYelectriccar site, also.
I can't imagine a better person for you to contact, being IN Ireland and all.
Return to Large EV General Discussion
Users browsing this forum: No registered users and 1 guest
