Go Kart Conversion
Electric cars, trucks, ATVs, NEVs - things bigger than a motorcycle.
Go Kart Conversion
Postby mikebikerad » Sun Apr 29, 2012 9:55 pm
Just finished this project up. Hope this is the right section?!? And almost ready for new tires after the first run!!
65 volts 40 ah 20c LiPoly
D&D ES-15
Alltrax 450 amp turned to 100%
mikebikerad
Re: Go Kart Conversion
Postby TylerDurden » Sun Apr 29, 2012 10:31 pm
That's nice. :mrgreen:
Top speed?
Have a Nice Day,
TD
___________________________________________________________
FYI: Adding pictures?
Bored?... take a crack at the unanswered posts
Please post your Watts-at-speed in the survey.
TylerDurden
Postby mikebikerad » Sun Apr 29, 2012 10:48 pm
Current gearing it does ~40mph but I'm changing it this week to drag race a Tesla! looking for ~60mph top speed the brakes are not the best so I dont want to push it without regen
mikebikerad
Postby HumboldtRc » Sun Apr 29, 2012 11:40 pm
With the stock little 100cc 4 stroke motor that go kart would go at least 60mph, with maybe 8-10hp. You should order up gears so it will go over 100mph. Get a 30 tooth sprocket for the rear and a 19 or 20 tooth for the front. Then that thing will be fun!! I want to take it to Samoa drag strip and smoke some cars with it!!! I think they opened up for the season last week. Also you should get front breaks for it, then it would stop on a dime.
HumboldtRc
Postby hillzofvalp » Sun Apr 29, 2012 11:44 pm
Our club just finished first in a EV grand prix purdue hosts every year. We ran an AC-9 with a curtis controller. 18650s (free.99 test cells from Tesla sponsor) were packaged in all cell phase change material... fun race! we were .1 seconds from beating the best gas lap and we were only taking it easy. 15/56 gearing. next time may be running 13 or 14 tooth cause we weren't even topping out
hillzofvalp
Postby hillzofvalp » Sun Apr 29, 2012 11:49 pm
We're not allowed to take the kart in a parking lot for testing. Track only since it's a university affiliated club.---looks like it would be fun!
A member has the curtis controller that is twice the size of this one (600+A?) (Which he uses in his motorcycle).. we may throw it on and try it sometime at the track to see what kind of time we can get.
hillzofvalp
Postby mikebikerad » Mon Apr 30, 2012 1:33 pm
That thing looks sweet! are those roll cages required? I have gears in the mail for more speed.
mikebikerad
Postby hillzofvalp » Mon Apr 30, 2012 4:46 pm
Roll cages, safety harness, and head rest all required as its a university run event. Roll cage weighs nothing though. Battery pack is about 1/3 of kart weight at 95lbs. It was the most overkill kart I think a team could build from bare frame starting only 8 days prior. Magnesium wheels and a semi-pro driver were nice inclusions
hillzofvalp
Postby mikebikerad » Mon Apr 30, 2012 10:50 pm
Lets see some video of that thing on the track. Is the roll cage bolt on?
mikebikerad
Postby hillzofvalp » Mon Apr 30, 2012 11:34 pm
it is a bolt on aluminum cage. On the straights (which I don't have video of) we triple passed people consistently. I'll try to up tomorrow. We're trying to increase our ratio at the moment... May try 13/56 at 7000-8000 rpm
hillzofvalp
Postby hillzofvalp » Tue May 01, 2012 8:20 pm
the british team actually had an onboard camera.. check it out! you won't see my kart in this video because we're about to pass this guy.
hillzofvalp
Postby mikebikerad » Sun Jun 24, 2012 8:48 pm
New video posted of it in action. That track driving looks fun!
mikebikerad
Postby Arlo1 » Sun Jun 24, 2012 9:12 pm
Very cool stuff. But the roll cages make me want to cry... They are added unnecessary weight and not likely to make anything any more safe. A performance pavement kart is to be treated like a motorcycle you fall off you roll or slide and you are ok but when you are trapped inside you will likely smash knees and elbows and possibly other parts. And with the added weight you are more likely to roll!
Thanks Justin of http://www.ebikes.ca/
Also a thanks to Methy at http://www.methtek.com/ :)
And Dave who has some good deals on STUF
RC lipo and most other types of Lithium batteries you MUST know your individual cell voltages while charging and discharging.
Batteries of all kinds need respect they can burn your house down, so don't sleep with them under your bed or any other were you cant afford smoke or fire!
[color=#FF0000][b][size=150]Never above 4.2v never below 2.7v EVER!!!
Arlo1
Postby mikebikerad » Mon Jun 25, 2012 12:33 am
The only reason I added the cage was because I have this fear that the kart will go speeding underneaths a car or truck leaving my torso behind :shock: BUT i agree with you 100% The cage is also inhibiting the frame from flexing which has effected the handling/steering quite badly. You can see in the video when my front tire lifts off the ground considerably.... is that normal? I am no kart expert.
The cage saved me one time so far from hitting my shoulder/head hard but other than that just extra weight and nonsense.
mikebikerad
Postby Hillhater » Mon Jun 25, 2012 6:40 pm
mikebikerad wrote: The cage is also inhibiting the frame from flexing which has effected the handling/steering quite badly. You can see in the video when my front tire lifts off the ground considerably.... is that normal? .
Yes, the front wheel lifting is normal, and deliberately designed into the front geometry by inclining the steering "king pins" .
This is termed "Weight Jacking",.. and it will actually result in the inside REAR wheel lifting slightly when cornering fast.
This helps to eliminate the "push" or "understeer" that would otherwise result due to the lack of differential on the rear axle.
But also , yes ..that cage will also affect the handling, ( unless you mount it flexibly ) but you probably wont notice until you get your tyres warmed up and "working" normally on a clean race track.
Hillhater
1.21 GW
1.21 GW
Return to Large EV General Discussion
Who is online
Users browsing this forum: No registered users and 2 guests
