Here is my Sidewalker micro electric.
I'm using it to go to work almost every day: http://ionelanton.com/ewalker/index.html
Specs: 14kg, 33km/h, +15km range
kunkurus wrote:
kunkurus wrote:I need the hose clamp to tighten the 80 tooth sprocket on the 16 tooth sprocket because the screws don't fit perfectly.
kunkurus wrote:@agniusm
The 80 tooth sprocket is mounted on the 16 tooth sprocket of the rear wheel. The 16 tooth sprocket is mounted on the free wheel.
The 16 tooth sprocket is mounted between two nuts: 80 tooth sprocket - nut - 16 tooth sprocket -nut.
The rear wheel is positioned at 1 cm left of the longitudinal axis because otherwise there is not space for the chain and sprocket.
The motor is powerful enough to start from standstill, but I find that a kick start is more comfortable.
For a second build, I would use another sprocket for the motor. Instead of 11 tooth (33km/h) I'd use a 14 tooth (~42km/h).
For the rear wheel I'd use a scooter rim. I'd try http://tncscooters.com/index.php?route=product/product&path=62&product_id=236 with a freewheel assembly: http://tncscooters.com/index.php?route=product/product&path=63_114&product_id=389
Yesagniusm wrote:So basicaly u would fit freewheel assembly on to the rim and then 80 tooth sprocket would fit directly on to the freewheel?
80 tooth sprocketagniusm wrote:which sprocket have u used on.
Direct fit, but you need to make a hole in the shaftagniusm wrote: the rc motor? is there direct fit or you need to make an adapter.
I don't know what to say, I don't have the dimensionsagniusm wrote: also what do ya think about those band breaks? i thought if i can get all the stuff from one place would save on expencive shipping.
milesinfront wrote:I like it!
How does your throttle work?
Kin wrote:Nice
Have you considered painting on some liquid electrical tape? I just don't like to see exposed connections :p
Return to Stand-up E-scooters and E-skateboards
Users browsing this forum: chefkoch and 1 guest
