UPDATE: LIPO Goped ESR750 80-100 HXT w/ Kelly
Postby E-racer » Mon Aug 16, 2010 5:32 pm
After alot of the use of the search button here on ES I concocted the first stage of my RC ESR build. I made a quick set of adapter plates with the CNC plasma to throw the motor on the ESR. Now that I have a reliable/performance drive line I am going to build a new vehicle from the ground up. Like many others I started with sensorless Turnigy controllers that just could not hold up. Im very happy with the KBL and halls. I appreciate the wealth of info on this forum and thank everyone for their help! This is one fun ride!
This Video is @ 60% motor speed and 40% current limiting (I'm now at 80%/55% starting to think about active cooling)
http://www.youtube.com/watch?v=_NUuBaM0uFY
UPDATE: Scoot now had lipo and a mini Kelly KBS controller check last page.
Kona Stinky: custom swing arm w/ batteries
-13s3p Turnigy Li-po
-Turnigy 80-100 rewound 130kv (Burtie's optical board)
-Kelly KBL 48201
-Nuvinci Dev Kit
http://endless-sphere.com/forums/viewtopic.php?f=28&t=35341
Goped ESR750
-12s2p Turnigy Li-po
-Turnigy 80-100 HXT w/halls
-Kelly KBL 48201
http://endless-sphere.com/forums/viewtopic.php?f=35&t=20732
E-racer
Re: Goped ESR750 80-100 HXT w/ Kelly
Postby Whiplash » Mon Aug 16, 2010 6:18 pm
NICE! What's the top speed of those bad boys? How far can you go on a charge?
Power is a fascinating thing, the more you have, the more you want, but the real power is having the restraint not to use it all at once...............Um...Yeah..
The harder you work.....The luckier you get!!
"People who say it can't be done are often interrupted by those that have already figured out how to do it!"
Email me @ currentcycles@gmail.com
OR check out http://www.CurrentCycles.net
Whiplash
Postby E-racer » Thu Aug 19, 2010 1:21 pm
Top speed is about 45mph. They'll do about 6 miles riding conservatively @ 30ish mph. I want to do a pack of turnigy Lipo just haven't quite figured out how to charge them properly yet.
-Kelly KBL 48201
-Nuvinci Dev Kit
Goped ESR750
-Kelly KBL 48201
E-racer
Postby Whiplash » Thu Aug 19, 2010 2:43 pm
Wicked! 40 on a scooter is WAAAAYYY fast! LOL!
Whiplash
Postby etard » Sat Aug 21, 2010 3:39 am
That's badass man! You never clip that motor on the ground in tight turns right? I love the sound, real nice adaptation.
etard
Postby knoxie » Sat Aug 21, 2010 3:42 am
Really nice work!
That looks like so much fun!! I noticed from your video you are getting quite close to hitting the motor saver on that side? bet you must have scraped that along the ground on more than 1 occasion?
I have always fancied one of those scooters, now I have a son i have an excuse to buy one to play around with!! on the lipo front they are so easy and cheap to get now, get yourself over to hobbyking and grab a few packs, there are loads of options for you in terms of capacity, voltage etc, charging is so easy just use buzzers for low battery like others do, no need for fancy BMS.
Knoxie
Electric KMX 72V Lipo, USPD drive unit. BMX 72V, Puma BMC,
Raleigh 26 inch MTB Puma 50V Turnigy 25C Lipo 10AH, Trek MTB, X5 48V NIMH. Electric BMX
http://tinyurl.com/4vrmc8 http://tinyurl.com/3umm4n
knoxie
Postby liveforphysics » Sat Aug 21, 2010 4:58 am
Nicely done! A suggestion though, rather than looking towards additional cooling, since you're not using all available motor speed, just drop the teeth of the front sprocket, let the motor speed go to 100%, and the motor will spend more time in the higher efficiency area (these motors want high RPMs), and you will make a lot less heat. This is a fix to the heat problem that also increases range and performance. :)
For ebike parts, don't be a douche, buy from http://www.ebikes.ca or http://www.MethTek.com
Justin saved the forum at great personal expense! The man is a legend and a hero!
liveforphysics
Postby liveforphysics » Sat Aug 21, 2010 4:59 am
Also, I don't know what temps you're seeing, but that motor is designed to be just fine running at temps hotter than you want to rest your hand upon.
liveforphysics
Postby E-racer » Sun Aug 22, 2010 3:20 pm
Yes the motor has scrubbed a few times but I've gotten good at compensating for it. Ive got the 180kv version of the motor because I originally planned sensorless controllers. The ESR served as a great test bed for RC brushless stress testing. I assure anyone who doesn't believe these motors will hold up are wrong. With no suspension and the motor scrubbing the ground a couple times, plus a pretty serious wipeout the motor hasn't had any issues. My main use of the scoot is for on campus transportation. Standing up is the way I feel comfortable blasting around campus. With my knowledge gained on the ESR build I'm going to start from scratch on a new scoot stay tuned! Turnigy Lipo will 100% be powering the next scoot!
-Kelly KBL 48201
-Nuvinci Dev Kit
Goped ESR750
-Kelly KBL 48201
E-racer
Postby E-racer » Thu Sep 02, 2010 4:48 pm
School is starting up so its time to start on my new scoot! I have a Marzocchi Fork w/ hydraulic brakes off a Husqvarna 50cc dirtbike 10" wheels. I will be using the Kelly KBL off my ESR and an 80-100B. The scooter has 5" of travel front and rear. Its folds by releasing the shock mount on the swing arm. Im planning on using 4 Turnigy 6s 5000mah Long packs for 44V10Ah. The downtube and swing arm will be 4130 chromoly and the deck will be aluminum. I will be using a CNC plasma for all the plates. Stay tuned for 3D models in the next few weeks. Should I put this new build in its own thread or leave it here?
-Kelly KBL 48201
-Nuvinci Dev Kit
Goped ESR750
-Kelly KBL 48201
E-racer
Postby knoxie » Fri Sep 03, 2010 2:16 am
hey 8) sounds awesome!! new build thread may be a better idea! looking forward to seeing it come to life!! so want myself a scooter as well!!
knoxie
Postby Uncle D » Fri Sep 03, 2010 3:10 am
Pretty cool design for a scooter.
Was just trying to understand how the deck will sustain your weight while being independent of the swing arm.
Uncle D
Postby E-racer » Fri Sep 03, 2010 6:45 pm
The deck is contrained to the down tube when the scoot is unfolded. folded the deck and swing arm will stack next to each other while the rear shock is folded up in the swing arm.
-Kelly KBL 48201
-Nuvinci Dev Kit
Goped ESR750
-Kelly KBL 48201
E-racer
Postby E-racer » Sun Sep 05, 2010 10:17 pm
I've decided the ESR has proven to be completely reliable under hard abuse. My ultimate goal was to eventually build a small motorcycle |I can commute 4 miles to school on. Ive ditched the idea of the scoot and gone to a lightweight street bike using DH MTB equipment. The RC airplane lightweight and performance compared to a modern DH MTB's similar attributes seems like a complete win to me.
BUILD THREAD: viewtopic.php?f=28&t=24228
FUTURE Stand Ups,
The ESR will be getting retired. Its Kelly controller (KBL48201) is going to my E-Bike, and its frame the garbage can. The frame has been the weakest link in the ESR project. My friends and I have broken 3 of them :-(. With that being said I have a Goped GSR25 that is itching for a Brushless. Im planning on swapping that GSR with 12s 5ah of lipo and a kelly ebike controller http://kellycontroller.com/kbs4812150a24-48v-mini-brushless-dc-controller-p-528.html Basically a lightweight HP power board.
-Kelly KBL 48201
-Nuvinci Dev Kit
Goped ESR750
-Kelly KBL 48201
E-racer
Postby Whiplash » Sun Feb 20, 2011 9:21 pm
Did you ever finish this beast?
Whiplash
Postby E-racer » Wed Mar 09, 2011 5:31 pm
Whiplash wrote:Did you ever finish this beast?
The ESR is done. I decided to build the Kona Stinky instead of the DH scoot though. The 80-100 has impressed me enough to be confident in building a reliable commuter powered by that motor.
-Kelly KBL 48201
-Nuvinci Dev Kit
Goped ESR750
-Kelly KBL 48201
E-racer
Postby E-racer » Mon Apr 25, 2011 9:59 pm
Phase 2 is complete. Scoot now has 12s2p HK Lipo and a Kelly mini brushless controller (KBS) the scooter now requires no deck spacers :-D
This is in 6s configuration.
-Kelly KBL 48201
-Nuvinci Dev Kit
Goped ESR750
-Kelly KBL 48201
E-racer
Re: UPDATE: LIPO Goped ESR750 80-100 HXT w/ Kelly
Postby Whiplash » Tue Apr 26, 2011 8:23 am
Great! How does it run?
Whiplash
Postby rodgah » Tue May 24, 2011 7:34 pm
the video sounds like you are using regen for braking?
if so i noticed that it is adjustable (amount of regen) is it enough to lock the back wheel or is it rather weak even at max settings?
cheers
Common Sense isn't so common........
Image Image Image
rodgah
Return to Stand-up E-scooters and E-skateboards
Who is online
Users browsing this forum: No registered users and 4 guests
