adrian_sm wrote:First up. That is an awesome build. It is so compact, I love it. But I don't think that motor will last. Even with a little fan attached to it, it will struggle. You will need to either go for a bigger motor, or limit the current going to it, which will also obviously limit the power you can get from it.
nyx wrote:Here is the motor i selected :
http://www.hobbyking.com/hobbyking/stor ... duct=14740
It as a 450KV and can reach 1000W
swbluto wrote:I regularly run the same motor at 25 mph and I climb hills with it, and it's not burning up anytime soon. The hottest it gets is to 150 degrees which is far away from its temperature limit (Which is something like 300-400 degrees).
adrian_sm wrote:nyx wrote:Here is the motor i selected :
It as a 450KV and can reach 1000Wswbluto wrote:I regularly run the same motor at 25 mph and I climb hills with it, and it's not burning up anytime soon. The hottest it gets is to 150 degrees which is far away from its temperature limit (Which is something like 300-400 degrees).
Really you use that little guy at 25mph, and hills. No current limits?
I assume those temps are in farenheit.
ferias77 wrote:Looking at all the motors available to Hobbyking, I found this :
http://www.hobbyking.com/hobbyking/stor ... oduct=4651
2 times lighter than the 63-74 170 with a Kv of only 206 ! But 43 A max... I don't know if it would fit.swbluto wrote:I regularly run the same motor at 25 mph and I climb hills with it, and it's not burning up anytime soon. The hottest it gets is to 150 degrees which is far away from its temperature limit (Which is something like 300-400 degrees).
swbluto, with what vehicle and what voltage do you use de 63-74 motor? Is it the 170 Kv? Do you use a freewheel? I think I won't use any freewheel for the first design, but I would like to be sure not to burn the ESC when the motor is not running...
Eric
swbluto wrote:Quick specs:
29 volt LiFePO4 battery; 8 inch pneumatic wheels; 63-64 230 kV motor; and 15/80 gear reduction ratio. It's a belt drive without a freewheel. Be sure to turn off the "brake feature" in the ESC.
adrian_sm wrote:You might be interested in this remote shunt mod for the watt meter.
http://endless-sphere.com/forums/viewto ... 76#p320027
- Adrian
Return to Stand-up E-scooters and E-skateboards
