SKATEBOARD video & gps 23 mph
Postby papo2110 » Mon Feb 27, 2012 2:55 pm
motor TURNIGY C6364-280 KV
SHOULD BE FAST VERY FAST
papo2110
Re: SKATEBOARD
Postby sk8norcal » Thu Mar 01, 2012 5:05 am
we seen all the RC motors on mountainboards or carveboard, all air rubber tires...
but haven't seen it on a skateboard or longboard, till now...
sk8norcal
Re: SKATEBOARD
Postby papo2110 » Fri Mar 02, 2012 6:18 pm
E SKATEBOARD
photo 2KK.JPG (95.87 KiB) Viewed 4821 times
photo 4X.JPG (103.45 KiB) Viewed 4821 times
photo 3JJK.JPG (102.87 KiB) Viewed 4821 times
photo 1.JPG (102.96 KiB) Viewed 4821 times
photo 3.JPG (95.03 KiB) Viewed 4821 times
photo 1N.JPG (106.7 KiB) Viewed 4821 times
photo 4.JPG (89.31 KiB) Viewed 4821 times
photo 5.JPG (85.54 KiB) Viewed 4821 times
photo 2.JPG (130.03 KiB) Viewed 4821 times
papo2110
Re: SKATEBOARD
Postby EBJ » Fri Mar 02, 2012 9:47 pm
if what I am seeing is a single motor to drive both rear wheels,
then you will want to re-consider that.
Your skateboard will not turn if that is the case.
Other than that, looks great. That sprocket looks unique, where did you get it ?
and I imagine you have another piece on the front of the wheel that is used to "sandwich" the wheel in order to keep the sprocket secure ?
EBJ
Re: SKATEBOARD
Postby Beachcruzer » Fri Mar 02, 2012 10:51 pm
Very cool. How fast?
Beachcruzer
Re: SKATEBOARD
Postby papo2110 » Sat Mar 03, 2012 1:52 pm
EBJ wrote:if what I am seeing is a single motor to drive both rear wheels,
1 weel drive was going to make it 2 wheel drive
papo2110
Re: SKATEBOARD
Postby EBJ » Sat Mar 03, 2012 6:48 pm
looks like you may have already done so,
but if not,
try and design it such that the sprocket can be mounted to any of the wheels,
that way you can "rotate" the wheels as the driven-one gets worn out faster.
EBJ
Re: SKATEBOARD
Postby sk8norcal » Sat Mar 03, 2012 7:33 pm
I think there was a guy on here that drove both wheels with one motor,
i will find the link, maybe only works on dirt...
ran across this,
using a randal comp truck with floating "free spin'' axle,
http://www.alibaba.com/product-free/106 ... _Axle.html
anyways Papo, I am excited to see that you are working on this,
what wheel is that?
another alternative is using the wheels with the belt cogs that are cheaply available for e-boards.
(or the expensive electrifly, really huge, http://wackyboards.blogspot.com/2009/10 ... board.html )
I was thinking of going the easy route and using existing e-board trucks and mounting a brushless motor on it....
not sure how much they sell that back truck for...
sk8norcal
Re: SKATEBOARD
Postby sk8norcal » Sun Mar 04, 2012 1:55 am
sk8norcal wrote:I think there was a guy on here that drove both wheels with one motor,
stielz
viewtopic.php?f=35&t=28463&start=15
i seem to remember some gas boards that also use a solid axle...
edit:
http://www.gopednation.com/forum/showth ... 902&page=3
http://wackyboards.blogspot.com/2010/01/motoboard.html
sk8norcal
Re: SKATEBOARD
Postby papo2110 » Tue Mar 06, 2012 9:19 am
papo2110
Re: SKATEBOARD
Postby papo2110 » Wed Mar 07, 2012 9:42 am
e skateboad
photo 1.JPG (100.81 KiB) Viewed 4698 times
photo 2.JPG (144.32 KiB) Viewed 4698 times
papo2110
Re: SKATEBOARD
Postby papo2110 » Thu Mar 08, 2012 10:03 am
E-skateboard
photo 1.JPG (144.32 KiB) Viewed 4655 times
photo 2.JPG (134.75 KiB) Viewed 4655 times
papo2110
Re: SKATEBOARD
Postby sk8norcal » Thu Mar 08, 2012 1:00 pm
sick!!!
r u gonna weld that plate to the hanger ?
sk8norcal
Re: SKATEBOARD
Postby papo2110 » Sat Mar 10, 2012 4:05 pm
sk8norcal wrote:sick!!!
Going to have it welded
papo2110
radio mod
Postby papo2110 » Thu Mar 15, 2012 9:58 am
took radio apart making a new case much much smaller
papo2110
Re: SKATEBOARD
Postby grindz145 » Thu Mar 15, 2012 10:43 am
E-skateboards just don't get old to me. I can see a well-designed version as a true urban mobility alternative for >3 mile or so.
http://www.endless-sphere.com/forums/viewtopic.php?f=18&t=19548 - Ebike Nerd Podcast
Thanks to Justin @ ebikes.ca! Go there, buy stuff. Support the Revolution :D
grindz145
Re: SKATEBOARD
Postby papo2110 » Fri Mar 16, 2012 7:24 pm
finished remote
papo2110
Re: SKATEBOARD
Postby papo2110 » Fri Mar 23, 2012 4:38 pm
the weld job
let me know what you think
papo2110
Re: SKATEBOARD
Postby EBJ » Fri Mar 23, 2012 8:05 pm
Looks great. Should hold up nicely.
Are you gonna paint it white or leave the cool "burn-marks" ?
EBJ
Re: SKATEBOARD
Postby papo2110 » Fri Mar 23, 2012 8:36 pm
EBJ wrote:Looks great. Should hold up nicely.
test it then paint
papo2110
Re: SKATEBOARD video
Postby papo2110 » Mon Mar 26, 2012 7:55 pm
rc motor
photo 4.JPG (110.28 KiB) Viewed 4406 times
photo 5.JPG (128.27 KiB) Viewed 4406 times
papo2110
Re: SKATEBOARD
Postby papo2110 » Mon Mar 26, 2012 7:57 pm
Last edited by papo2110 on Tue Mar 05, 2013 4:36 pm, edited 1 time in total. View post history.
papo2110
Re: SKATEBOARD
Postby sk8norcal » Mon Mar 26, 2012 8:17 pm
sick! mount that sucker up!
I wonder how much advantage 2wd have over 1wd for urethane wheels....
sk8norcal
Re: SKATEBOARD
Postby Uvedovle » Tue Mar 27, 2012 4:17 am
I'm looking for 2wd for offroad purposes, maybe you don't need it for you skate...
Good job!
Uvedovle
Re: SKATEBOARD
Postby papo2110 » Sat Mar 31, 2012 7:47 am
skateboard almost ready
papo2110
Next
Return to Stand-up E-scooters and E-skateboards
Who is online
Users browsing this forum: No registered users and 3 guests
