SKATEBOARD video & gps 23 mph
Re: SKATEBOARD video on the way
Postby EBJ » Sat Apr 07, 2012 4:29 pm
nice grip tape pattern. I like how "hidden" the electronics are from above.
EBJ
Postby papo2110 » Sat Apr 07, 2012 8:47 pm
23 mph did not push full speed it fast very fast it will hit 27 mph if you are brave
photo 2.PNG (120.64 KiB) Viewed 2119 times
papo2110
Postby papo2110 » Sat Apr 07, 2012 9:09 pm
Last edited by papo2110 on Tue Mar 05, 2013 4:37 pm, edited 1 time in total. View post history.
papo2110
Re: SKATEBOARD video & gps 23 mph
Postby EBJ » Sat Apr 07, 2012 11:23 pm
awesome! congrats.
EBJ
Postby Scruffoid » Sun Apr 08, 2012 1:38 am
Sweet. Nice looking work there.
Hyena Electric Ebike Kit
Crystalyte 3525 Pimped out / 12 FET infineon / xie chang board with 4110 Fets / 22S3P - 90V/15AH Lipo
4KW (45A limited) - 67Km/Hr Max
Build Thread - http://endless-sphere.com/forums/viewtopic.php?f=6&t=38000&p=553791#p553791
Scruffoid
Postby bzhwindtalker » Sun Apr 08, 2012 5:46 am
I will have to build one of these one day! Awesome BTW
bzhwindtalker
Postby sk8norcal » Wed Apr 11, 2012 11:43 am
that looks fun!
i want one...
sk8norcal
Postby papo2110 » Thu Apr 19, 2012 9:09 am
eskateboard Cosmetics the board is running great fast 5000 mah battery getting 5 miles
papo2110
Re: SKATEBOARD new video & gps 23 mph
Postby papo2110 » Sun Apr 22, 2012 10:20 am
11
Last edited by papo2110 on Tue Mar 05, 2013 4:38 pm, edited 2 times in total. View post history.
papo2110
Postby papo2110 » Wed May 09, 2012 8:23 am
mods
papo2110
Postby papo2110 » Wed May 09, 2012 8:31 am
brothers board
papo2110
Postby papo2110 » Wed May 30, 2012 7:02 am
board before the surgery
papo2110
Postby papo2110 » Wed May 30, 2012 7:03 am
after the surgery
papo2110
Postby papo2110 » Wed May 30, 2012 7:06 am
working hard
photo 2.JPG (110.91 KiB) Viewed 824 times
photo 1.JPG (96.51 KiB) Viewed 824 times
papo2110
Postby rcelegans » Wed May 30, 2012 2:03 pm
Excellent work on your skateboard! I have an Exkate Raptor 4 and have been using 6S 5000mA batteries and a mamba monster ESC and it runs fine with the brushed motor and I have the same Turnigy out runner motor and have been thinking of putting this motor on but wasn't sure. Glad I found this site and your posts!
Is there regenerative braking -or braking capabilities with this motor?
Also can you takes some pictures of the gear on motor shaft? I want to know how you mounted it on the shaft.
I noticed that on your brother's motor the gear is on the other end can you take some close ups of that.
Awesome work!
rcelegans
Postby cal3thousand » Wed May 30, 2012 2:28 pm
This is sooo cool. I now have another toy that I need to make :)
Will you be able to supply any of those parts for those interested in making one?
#1: Diamondback Menona 700c (Commuter)
M/C: e-BikeKit geared rear w/BB7 with 12FET 40A Infineon ebikes.ca
GM 48V LiFePO4 10Ah racked; moving to 12S Turnigy 10Ah framed
+ Speedict, XC30TK disc, Alex Adventurer 700c Disc, Tektro 180mm hyd. with 42mm Kenda Urban
#2: Norco VPS Six DH (Fun) WIP
M/C: Clyte HT3525 (Thanks Meth!!!) http://Methtek.com with Lyen 18FET 24S Regen
Battery: 24S Turnigy 10Ah frame (ABS)
#3: Wifey Bike, Giant eSuede fully customized WIP
cal3thousand
Postby papo2110 » Wed May 30, 2012 7:03 pm
EZRUN 150 amp car esc
It has proportional brake
I weigh 180 pounds it stops
With no problem
papo2110
Postby papo2110 » Wed May 30, 2012 7:07 pm
I am running on 6s 5000 mah battery
Going to try 7s 5000 mah battery
Should be very fast will post video and gps
papo2110
Postby papo2110 » Thu May 31, 2012 6:21 am
drive
photo 1.JPG (115.83 KiB) Viewed 1312 times
photo 2.JPG (110.15 KiB) Viewed 1312 times
photo 3.JPG (106.92 KiB) Viewed 1312 times
papo2110
Postby rcelegans » Thu May 31, 2012 10:03 am
Hey Papo
thanks for posting the close up pictures. I see that you have a threaded shaft on the motor that holds the small gear. Can you give me the specks on the shaft and where did you get the shaft from? My motor came with a 10mm shaft and was wondering how easy to change the shaft on these motors? I see a cotter pin holding the shaft in place is this all I have to remove to change the shaft?
thanks!
rcelegans
Postby papo2110 » Thu May 31, 2012 12:40 pm
yes and the set screws the shaft is from the car gas lifter it is 10 mm has a thread for the ball link you have to grind down
to fit the (D) cut on the gear http://www.ebay.com/itm/NEW-11-Tooth-D- ... 359e9464c3
papo2110
Postby rcelegans » Thu May 31, 2012 8:51 pm
Thanks for the ebay link!
I have been thinking of running a belt drive since that is what I already have on my skateboard and I assume it is more quiet. It has 44 "teeth" on the wheel side and I am thinking about using one of these gears using the Shaftloc system but not sure how many teeth I should put with the C6354-250KV outrunner motor. With the Shaftloc system I can just add the gear right on to the motor shaft (10mm):
http://www.sdp-si.com/web/email/shaftloc/index.htm
Cheers!
Exkate wheel and belt
rcelegans
Postby rcelegans » Thu May 31, 2012 8:57 pm
btw the gear on the 400W (450W?) brushed motor has 19 teeth so I guess I should have less than this with the above brushless motor? I"m not sure how the brushed motor compares with the C6354-250 out runner?
gear on motor side
rcelegans
Postby papo2110 » Tue Jun 05, 2012 7:35 am
board
photo 1.JPG (141.85 KiB) Viewed 1303 times
photo 2.JPG (135.73 KiB) Viewed 1303 times
papo2110
Postby sflinux » Sun Jun 10, 2012 8:36 am
Hi,
Thanks for posting. Your board looks sick. Did you make or buy the cog for the drive wheel? If you bought it, would you please share the source?
Thanks.
sflinux
PreviousNext
Return to Stand-up E-scooters and E-skateboards
Who is online
Users browsing this forum: No registered users and 3 guests
