SKATEBOARD video & gps 23 mph
Re: SKATEBOARD video & gps 23 mph
Postby cal3thousand » Wed May 30, 2012 2:28 pm
This is sooo cool. I now have another toy that I need to make :)
Will you be able to supply any of those parts for those interested in making one?
#1: Diamondback Menona 700c (Commuter)
M/C: e-BikeKit geared rear w/BB7 with 12FET 40A Infineon ebikes.ca
GM 48V LiFePO4 10Ah racked; moving to 12S Turnigy 10Ah framed
+ Speedict, XC30TK disc, Alex Adventurer 700c Disc, Tektro 180mm hyd. with 42mm Kenda Urban
#2: Norco VPS Six DH (Fun) WIP
M/C: Clyte HT3525 (Thanks Meth!!!) http://Methtek.com with Lyen 18FET 24S Regen
Battery: 24S Turnigy 10Ah frame (ABS)
#3: Wifey Bike, Giant eSuede fully customized WIP
cal3thousand
Postby papo2110 » Wed May 30, 2012 7:03 pm
EZRUN 150 amp car esc
It has proportional brake
I weigh 180 pounds it stops
With no problem
papo2110
Postby papo2110 » Wed May 30, 2012 7:07 pm
I am running on 6s 5000 mah battery
Going to try 7s 5000 mah battery
Should be very fast will post video and gps
papo2110
Postby papo2110 » Thu May 31, 2012 6:21 am
drive
photo 1.JPG (115.83 KiB) Viewed 1485 times
photo 2.JPG (110.15 KiB) Viewed 1485 times
photo 3.JPG (106.92 KiB) Viewed 1485 times
papo2110
Postby rcelegans » Thu May 31, 2012 10:03 am
Hey Papo
thanks for posting the close up pictures. I see that you have a threaded shaft on the motor that holds the small gear. Can you give me the specks on the shaft and where did you get the shaft from? My motor came with a 10mm shaft and was wondering how easy to change the shaft on these motors? I see a cotter pin holding the shaft in place is this all I have to remove to change the shaft?
thanks!
rcelegans
Postby papo2110 » Thu May 31, 2012 12:40 pm
yes and the set screws the shaft is from the car gas lifter it is 10 mm has a thread for the ball link you have to grind down
to fit the (D) cut on the gear http://www.ebay.com/itm/NEW-11-Tooth-D- ... 359e9464c3
papo2110
Postby rcelegans » Thu May 31, 2012 8:51 pm
Thanks for the ebay link!
I have been thinking of running a belt drive since that is what I already have on my skateboard and I assume it is more quiet. It has 44 "teeth" on the wheel side and I am thinking about using one of these gears using the Shaftloc system but not sure how many teeth I should put with the C6354-250KV outrunner motor. With the Shaftloc system I can just add the gear right on to the motor shaft (10mm):
http://www.sdp-si.com/web/email/shaftloc/index.htm
Cheers!
Exkate wheel and belt
rcelegans
Postby rcelegans » Thu May 31, 2012 8:57 pm
btw the gear on the 400W (450W?) brushed motor has 19 teeth so I guess I should have less than this with the above brushless motor? I"m not sure how the brushed motor compares with the C6354-250 out runner?
gear on motor side
rcelegans
Postby papo2110 » Tue Jun 05, 2012 7:35 am
board
photo 1.JPG (141.85 KiB) Viewed 1431 times
photo 2.JPG (135.73 KiB) Viewed 1431 times
papo2110
Postby sflinux » Sun Jun 10, 2012 8:36 am
Hi,
Thanks for posting. Your board looks sick. Did you make or buy the cog for the drive wheel? If you bought it, would you please share the source?
Thanks.
sflinux
Postby Sentient AI » Mon Jun 25, 2012 6:01 pm
How does the motor on the back-wheel work out?
I'm not sure that a fixed 2-wheel with a single motor would make the turning lopsided in a way.
I'm visualizing the the front of the fuzion scooter, http://fuzionscooter.com/.
Just trying to figure out the different parts I would hypothetically need to make a (freewheel) kick scooter, since I'm not sure how it would work out with a fixed drive.
Sentient AI
Postby sk8norcal » Wed Jun 27, 2012 2:13 pm
the fixed drive have a drag from the cogging,
I think I would like the wheel to freewheel.
are you thinking about powering that fuzion scooter?
I have the original one,
used to be called a QuadCarver.
http://www.skatesonhaight.com/The-Quadc ... -p/qcp.htm
http://wackyboards.blogspot.com/2009/07 ... arver.html
sk8norcal
Postby Sentient AI » Wed Jun 27, 2012 8:42 pm
Yeah, I'm thinking of just sticking a relatively low-power motor (still going to figure out the amps/volts) onto one of the front wheels of a razor-esqe type build (may or may not recycle pieces), except with the whole build being more of a tricycle (Two wheels front, one larger (or smaller, not sure how it would effect it yet) wheel in the back that's on a freehinge on an axle). Just need to figure out the general pieces and their functionality before I jump into anything I can't pull off.
EDIT: Man, I'm abusing parentheses.
Sentient AI
Postby acevan » Mon Sep 17, 2012 9:35 pm
Im attempting to do this very thing 1wd on a colt 95x mountain board, I have everything planned and the board in hand but am struggling to come up with a easy solution for mounting my motor. There are 2 threads in the rear trucks for the brake system, any ideas would be helpful, my only option of as now is n weld in a custom made motor mount plate like you did, but I am not sure how I can get this motor mount made. how can I easily and cheaply get this part manufactured? or is there a electric 15"-18" wide pre made mountain board truck?
acevan
Postby papo2110 » Mon Nov 12, 2012 1:57 pm
going faster might be 25 27 mph with new gear set up let you know on next video
http://www.youtube.com/watch?v=vnpp4tJefyI&feature=plcp
Last edited by papo2110 on Mon Nov 12, 2012 1:58 pm, edited 1 time in total. View post history.
papo2110
Postby papo2110 » Mon Nov 12, 2012 2:02 pm
new pic
photo 1.JPG (138.08 KiB) Viewed 910 times
photo 2.JPG (157.51 KiB) Viewed 910 times
papo2110
Postby papo2110 » Mon Nov 12, 2012 2:06 pm
stay tune my next build crazy
papo2110
Postby sk8norcal » Mon Nov 12, 2012 3:34 pm
those Cindrich decks are pretty crazy looking,
but IMO, aluminum does not make good skateboard decks..
he make cnc skate trucks also...
sk8norcal
Postby Scruffoid » Sat Nov 17, 2012 2:43 am
So does having a longer board stop death wobbles or something.
Always remember as a kid going down the steep hills and losing it.
Always enjoy the pics.
Wayne
Hyena Electric Ebike Kit
Crystalyte 3525 Pimped out / 12 FET infineon / xie chang board with 4110 Fets / 22S3P - 90V/15AH Lipo
4KW (45A limited) - 67Km/Hr Max
Build Thread - http://endless-sphere.com/forums/viewtopic.php?f=6&t=38000&p=553791#p553791
Scruffoid
Postby sk8norcal » Sat Nov 17, 2012 3:22 am
yes, longer wb usually means more stablity at speed,
but that's only part of it,
notice the "longboard' trucks, they are less prone to wobbles than the traditional design trucks.
rider skills matter also.
current dh speed record is over 80+mph
sk8norcal
Postby realmattb » Sat Nov 17, 2012 11:44 pm
Hi guys! This is an awesome thread. It inspired me to build my own board last week. I am using the Mamba Monster ESC and a NTM 380kv 50x60mm motor rated at 90a with 5000mAh 6S lipo rated at 20C.
I am using a belt drive with timing pulleys and a simple aluminum motor mount very similar to Papa2110, but I can't weld so it is just bolted on for now. The pulley ratio is 16teeth on the motor and 50teeth on the 75mm wheel.
The thing REALLY moves and can accelerate so fast I've fallen off about 20 times. I will post some videos and pictures here shortly, I just got finished it about 24 hours ago.
Anyway, my motor stutters and is really loud when starting from a dead stop. I tried adjusting literally every option on the mamba monster with the programming software and still no luck. Would love some input from you guys so that I might make this thing work a bit better.
The only thing I can think of is that the "20C" rating of the battery won't provide enough current upon starting from a dead stop. BUT I don't have another battery to test on and would prefer not to spend the money if it isn't going to solve the problem.
Basically I just want it to be smooth so I can have my wife and friends ride it too without worrying and also as quite as possible.
Also if anyone has any suggestions please let me know, I am always looking for new ideas and builds :)
Thanks for your help. Have a great night.
realmattb
Postby sk8norcal » Sun Nov 18, 2012 12:09 am
sk8norcal
Postby papo2110 » Mon Nov 19, 2012 7:35 am
We had a similar problem lower gearing 40c
Battery more power
papo2110
Postby papo2110 » Mon Nov 19, 2012 7:48 am
photo 1.JPG (148.96 KiB) Viewed 854 times
photo 2.JPG (149.05 KiB) Viewed 854 times
papo2110
Postby papo2110 » Wed Nov 21, 2012 8:39 am
IN THE WORKS
photo 1.JPG (124.07 KiB) Viewed 835 times
photo 2.JPG (116.1 KiB) Viewed 835 times
papo2110
PreviousNext
Return to Stand-up E-scooters and E-skateboards
Who is online
Users browsing this forum: No registered users and 2 guests
