StandUp Scooter with CVP transmission
Postby Astropower » Wed Apr 04, 2012 2:11 am
Hello Everyone,
I would like to share everyone with you my little work,
List of my scooter parts:
Simple Ballon wheels scooter
16 Cells of 40152 LiFePO4 15Ah
58V 4A Charger
25A BMS
20A Controller
Brushless motor 1.2Kw
NuVinci N171 Hub
DC to DC
12 inch rims
12 inch tires
140mm Disk + Calipers
25# Chain, 19tooth motor sprocket + 54 tooth Hub sproket
thumb throttle + Aluminum Brakes,
See the pictures:
Astropower
Re: StandUp Scooter with CVP transmission
Postby Astropower » Wed Apr 04, 2012 2:15 am
25# Heavy Duty Chain
19 Tooth Motor Sprocket
54 Tooth Hub Sproket
Gear Ratio 1 : 2.84
Astropower
Postby Astropower » Wed Apr 04, 2012 2:20 am
12 Inch Wheel
+ 12X2.75 Inch Wheel, Heavy Duty 65PSI
Astropower
Postby Astropower » Wed Apr 04, 2012 2:26 am
NuVinci N171, Automatic CVP Transmission Hub, Ratio 1:1 to 1:3.5.
Comes with USB Program controller.
Great Product.
http://fallbrooktechnologies.com/
Astropower
Postby Astropower » Wed Apr 04, 2012 2:30 am
My Cells,
16 Cells of 40152 Size, LiFePO4 3.2V 15Ah, 150A(10C) Discharge 45A(3C) Charge.
51.2V @ 15Ah Total.
Astropower
Postby Astropower » Wed Apr 04, 2012 2:32 am
[youtube][/youtube]Brushless motor, 1.2KW on 47.5V
1280 RPM, Aluminum Cooling.
Astropower
Postby Astropower » Wed Apr 04, 2012 2:35 am
DC to DC
from 60-42VDC to 12VDC 10A (120W)
to run the Hub controller and LED Light (soon).
you can see in the picture the Hub controller.
Astropower
Postby Astropower » Wed Apr 04, 2012 2:37 am
Brushless controller,
I will change the electronic to support 35A instead of 20A.
for long Life run.
Astropower
Postby Astropower » Wed Apr 04, 2012 2:48 am
The main Problem is with this Hub,
Because the Hub should fit to 36 spokes rims, usually it for 26' 24' 21' inch rims,
to fit 12 inch rim, it litte problem, the Hub is about 9' inch size,
so i buy simple curved sprokes rim,
i broke the curved sprokes, and i design some part to fit between the Hub and Rim, By CNC Cuting.
Astropower
Postby Astropower » Wed Apr 04, 2012 2:53 am
another one,
the hub is very wide,
Astropower
Postby Astropower » Wed Apr 04, 2012 2:56 am
the NEW Part, after CNC Design
Astropower
Postby Astropower » Wed Apr 04, 2012 2:59 am
another one
Astropower
Postby Astropower » Wed Apr 04, 2012 3:02 am
Connect to the Hub
Astropower
Postby Astropower » Wed Apr 04, 2012 3:03 am
Part 2
Astropower
Postby Astropower » Wed Apr 04, 2012 3:04 am
Now need to connect the Rim
Astropower
Postby Astropower » Wed Apr 04, 2012 3:06 am
After lot of work
Astropower
Postby Astropower » Wed Apr 04, 2012 3:09 am
different side view
fit Perfect
Astropower
Postby Astropower » Wed Apr 04, 2012 3:12 am
Done
Astropower
Postby Astropower » Wed Apr 04, 2012 3:14 am
Complete 1
Astropower
Postby Astropower » Wed Apr 04, 2012 3:16 am
Complete 2
Astropower
Postby Astropower » Wed Apr 04, 2012 3:30 am
Now, the original scooter chassis have problem with wide wheels,
so i made some changes,
looks ugly now, becasue it not finish yet.
I will Update soon...
Astropower
Postby agniusm » Wed Apr 04, 2012 4:41 am
This is looking fabulous. great work mare. what kind of speeds/range you expect? I am just finishing my stand-up scooter project, meduza project. was wanderin if you could throw in a link for dc-dc converter. also how much was the motor/controller combo? cheers, nice project, thumbs up
agniusm
Postby Astropower » Wed Apr 04, 2012 6:12 am
Thank you for your reply,
the maximum speed is about 42.5Km/h (26.4MPH) in theory.
it will depend finally on the total weight.
simple calculation.
the range i hope it will be more then 40Km (25 miles).. and again, i will know for sure only after real test drive.
but for sure, In low speed or hills, i will save a lot of energy compare to the normal scooter in the market, thanks to the transmission.
about the DC to DC, this is the item that i bought :
http://www.ebay.com/itm/DC-DC-Converter ... 3a68fb8c0f
this is the controller:
http://www.aliexpress.com/fm-store/3138 ... -s-EV.html
about the motor, i dont have information on the web, it cost me about 150USD.
Thank again for your support.
Astropower
Postby Astropower » Thu Apr 05, 2012 1:46 am
Hello,
Yesterday i build caliper device.
Astropower
Postby Lebowski » Thu Apr 05, 2012 2:28 am
cool stuff :D nice project !
Lebowski
Next
Return to Stand-up E-scooters and E-skateboards
Who is online
Users browsing this forum: No registered users and 3 guests
